Remote Xbee Bird Feeder moniter
I wanted to extend my camera control box whose motion sensor I was using to take pictures of visitors to the bird feeder. I wanted to be able
to see when the motion sensor went off from inside my computer room. XBEEs!
I didn't want to make the xbee a permanent addition to the camera control box because I don't have room in the case and it was really only going to
be used in this one application. So I tied the detection pin of the motion sensor to the digital pin 0 of the xbee.
And the other Xbee's matching pin outputs to my demoboard connected to my computer. It uses a gps module to timestamp each time the
motion sensor gets hit and displays this through the parallax serial terminal with a running total of how many hits.
[video=youtube_share;1S1r80QW6Zc]
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 CON Status = 0 led = 1 VAR long x,myhour OBJ Debug : "Parallax Serial Terminal" GPS : "GPS_Float_Lite" PUB Start GPS.Init 'start GPS for timestamp debug.start(57600)'to send info to computer serial window '-----set to inputs dira[status]~ 'from xbee motion sensor connection '-----set to outputs dira[led]~~ 'red led to show motion detected outa[led] := 0 waitcnt(clkfreq*6 + cnt) 'give GPS time to set-up x:=0 repeat if ina[status] == 0 'if motion detected x++ debug.str(string("TimeStamp: ")) myhour := GPS.Long_Hour - 4 'set to eastern time debug.dec(myhour) debug.str(string(":")) debug.dec(GPS.Long_Minute) debug.str(string(" Total Hits: ")) debug.dec(x) debug.str(string(13)) outa[led] := 1 'turn on red led on demo board for four seconds waitcnt(clkfreq*4 + cnt) outa[led] := 0Any shots of birds?
So far only one bird and a gang of squirrels visit the feeder.
Typical
I've gotta say, that is the best photography idea I've heard of for photoing birds.
