Why the difference between these two button reading programs in PASM and SPIN
I am working on a Propeller Professional Development Board using button Zero and LED 9. Both programs work as coded, but with this one puzzling result. When I run the PASM code and while it is waiting for the a button press the LED is dimly lit. When you press and hold the button the LED is brightly lit as you would expect. Release the button and the LED returns to the dimly lit state. The SPIN code works as well, but the LED is off until the button is pressed and held. I'm returning to working with PASM because I am beginning a project which needs it. I was reviewing some learning/practice code I had worked with for some time and rediscovered this old problem I never got figured out.
Tony
CON _clkmode = xtal1 + pll16x ' Enable External Crystal and PLL X 16 _xinfreq = 5_000_000 ' External Crystal Frequency 5Mhz PUB Main {Launch cog to run Propeller Assembly code} cognew(@entry, 0) 'Launch new cog DAT org 0 'Begin at Cog RAM address 0 entry mov dira, LED 'Set pin 9 to output loop waitpeq Button, Button 'Wait till button is pressed xor outa, LED 'Turn on LED waitpne Button, Nobutton 'Wait till button is released xor outa, LED 'Turn off LED jmp #loop 'Loop LED long |< 9 Button long 0 Nobutton long |< 0
CON _clkmode = xtal1 + pll16x ' Enabled External Crystal and PLL X16 _xinfreq = 5_000_000 ' External Crystal Frequency VAR OBJ PUB Main dira[9] := 1 repeat waitpeq(%0, %1, 0) outa[9] := 1 waitpne(%0, %1, 0) outa[9] := 0
Tony
