Report on ExpressPCB
Hi folks,
There has been a bit of activity regarding PCB production lately. Thought I'd report on a recent personal experience with ExpressPCB.
I use quite a few TTL-RS232 converters in my projects and usually build them up as needed; many times on perfboard or veroboard. Recently, I decided to build a small board to use a MAX233 or ST232 to speed up the process.
The circuits are very simple so I jumped right to the layout software supplied by ExpressPCB. This is first time I've used the flat rate service giving 3 boards for $51. To keep costs down, only tinned traces and plated through holes are included. Solder mask and silkscreen layer are available at extra cost. The size of the board allowed me to put 4 converters on each of the 3 three included boards.
I pressed the "order" button Tuesday afternoon and the boards arrived Friday about noon via international courier. Quality was excellent and the circuits worked correctly.
I also have a small bandsaw that works well for this kind of thing.
Cheers,
Shows a company with no customer support.
For cutting I recommend putting a line of drill holes (some pcb manufacture will not allow it)
and then later go down the line with this saw, the drill line will help keep it straight and aid in the weak power of the saw.
http://www.harborfreight.com/4-inch-mighty-mite-table-saw-93211.html
For prototype where I only need 3 boards delivered in 4 days for $85, I don't know of any other (U.S) place that take gerbers that can do that.
They don’t have a phone number, they admit they have spam filter on their email in box so you are not sure if you reach them.
I'm not gone design first with their software and then later do it over in diptrace when I'm ready to order more with a regular pcb manufacture.
That is something one must consider if you are laying out a prototype that you may want to have made in quantity by another pcb manufacturer. On the other hand it is a prototype so you have the opportunity to correct any mistakes and improve the final layout by re-doing the layout. Of course that could be more work than it's worth if it is a complex board.
BTW - I also emailed them asking for a quote at one point and received an answer from them. Of course the answer was for me to submit the pcb layout to their software/web site for pricing.
How are you doing?
We can take Gerber files and properly can be a solution for your works. We are specifying in fabricating PCBs.
Judy
