Better way to do this code function?
xanatos
Hi there,
I have the following code that gets each digit as it is being input to a keypad (via EDE1144). It displays the digits, "growing" the input characters from the left-side of the display as in:
1
12
123
1234
123456 (of course, not on multiple lines... I think you get what I'm saying)
I need to capture the six-digit number that is entered as two Words that I subsequently PUT to SPRAM (and write to EEPROM in another slot, I'm using a BS2px), so I make the two words via positional multiplication.
This all WORKS very well, but it takes up a LOT of lines of code. Every time I look at this, I think to myself that there MUST be a more efficient way of doing the task. I'd like to stuff a few more functions in this program slot, and with this albatross in the middle of it all, I fall short on space.
It's all that d6=d5, d5=d4, d4=d3 stuff that seems just ... lame. And the multiple SEROUT LCDs... Works like a champ... just bloated, I think.
Is this the only way, or is there a better way that does all the same functions (especially capturing the top 3 digits as a word, and the bottom three digits as another word)???
Code below... thanks for any thoughts/ideas...
Dave
PS., the GOSUB just captures the SERIN data from the EDE1144 when the Data Valid line goes low, and stores the output in a var called keyIn. It also checks it for # and *, since I have special functions assigned to those keys.
1
12
123
1234
Dave
GOSUB getKeyIn
IF keyIn = 14 THEN dispChar = "*"
IF keyIn = 15 THEN dispChar = "#"
IF (keyIn < 10) THEN
IF (keyCount = 1) THEN
d1 = keyIn
SEROUT LCD, LcdBaud, [$FE, $45, $40, DEC1 d1, " "]
ELSEIF (keyCount = 2) THEN
d2 = d1
d1 = keyIn
SEROUT LCD, LcdBaud, [$FE, $45, $40, DEC1 d2, DEC1 d1]
ELSEIF (keyCount = 3) THEN
d3 = d2
d2 = d1
d1 = keyIn
SEROUT LCD, LcdBaud, [$FE, $45, $40, DEC1 d3, DEC1 d2, DEC1 d1]
ELSEIF (keyCount = 4) THEN
d4 = d3
d3 = d2
d2 = d1
d1 = keyIn
SEROUT LCD, LcdBaud, [$FE, $45, $40, DEC1 d4, DEC1 d3, DEC1 d2, DEC1 d1]
ELSEIF (keyCount = 5) THEN
d5 = d4
d4 = d3
d3 = d2
d2 = d1
d1 = keyIn
SEROUT LCD, LcdBaud, [$FE, $45, $40, DEC1 d5, DEC1 d4, DEC1 d3, DEC1 d2, DEC1 d1]
ELSEIF (keyCount = 6) THEN
d6 = d5
d5 = d4
d4 = d3
d3 = d2
d2 = d1
d1 = keyIn
SEROUT LCD, LcdBaud, [$FE, $45, $40, DEC1 d6, DEC1 d5, DEC1 d4, DEC1 d3, DEC1 d2, DEC1 d1]
ENDIF
ELSEIF (keyIn = 14) THEN ' 14 = * (Abort and go to beginning)
'SEROUT LCD, LcdBaud, [$FE, $45, $40, dispChar, " "]
'PAUSE 500
keyCount = 0
GOSUB redoReps 'Main
ELSEIF (keyIn = 15) THEN '15 = # (Accept entry and go to next op)
'SEROUT LCD, LcdBaud, [$FE, $45, $40, DEC1 d6, DEC1 d5, DEC1 d4, DEC1 d3, DEC1 d2, DEC1 d1, dispChar]
'PAUSE 500
keyCount = 0
TRKREP = (100 * d6) + (10 * d5) + d4
TRKREP2 = (100 * d3) + (10 * d2) + d1
IF whichTrack = 1 THEN
PUT 16, Word TRKREP
WRITE 16, Word TRKREP
PUT 26, Word TRKREP2
WRITE 26, Word TRKREP2
ENDIF
EXIT
ENDIF
instead of shifting each number into a different variable.
Thanks again,
Dave
I agree that the array would be a good way to go. Another could be to build up the variables and display them in place. The following accumulates 4 decimal digits first into a word and then two more into a byte, and at each step displays the accumulation. (I think it would?!) Chars 14, 15 are special case.
[SIZE=1][FONT=courier new]wx VAR WORD ' high 4 digits bx VAR BYTE ' low 2 digits, together 000000 to 999999 idx VAR NIB buildDouble: wx=0 bx=0 FOR idx=0 TO 3 ' build a word wx range 0000 to 9999 GOSUB getkeyin IF keyIn>9 THEN specialCase wx = wx * 10 + keyIn SEROUT LCD, LcdBaud, [$FE, $45, $40, DEC wx] NEXT FOR idx=4 TO 5 ' build byte bx range 00 to 99 GOSUB getkeyin [/FONT][/SIZE][SIZE=1][FONT=courier new] IF keyIn>9 THEN specialCase [/FONT][/SIZE][SIZE=1][FONT=courier new] bx = bx * 10 + keyIn SEROUT LCD, LcdBaud, [$FE, $45, $40, DEC wx] ' first 4 digits SELECT idx CASE 4 SEROUT LCD, LcdBaud, [DEC wx,DEC1 bx] ' one digit CASE 5 SEROUT LCD, LcdBaud, [DEC wx,DEC2 bx] ' two digits ENDSELECT NEXT[/FONT][/SIZE]Thanks everybody, I was successful in reducing that mess down. Between using the array and some artful for/next looping in a gosub, I turned that mess into six lines of main code and a four line gosub. Works like a champ! Thanks for all your help, my code looks much better now! But now I have an even wierder issue - in my next post! :-)
Thanks again,
Dave
