Does Propeller USB communication exist without surface mount FTDI?
Guys,
I'm probably hunting a unicorn here, but...
Is there a through-hole solution for Propeller-to-USB communication without the requirement of PropPlug, (or equiv)?
OBC
OBC
I'd be highly grateful if someone found a link to this...
OBC
OBC
Rationale behind this is I once put a FT232 chip on a PCB and spent ages trying to solder it. All my boards have a D9 female socket and a Dip16 Max3232. Another advantage there is you can add a second serial port by just adding one more D9 socket.
cheers
tubular
There are objects that do USB on the prop. Both Brad and Micah have posted code.
You can do lo speed usb to serial with a ATtiny45/85, I have a few tiny 85's around, I can program 1 and send it to you if you want to try it.
http://www.recursion.jp/avrcdc/cdc-232.html#usage
that would make it easy to solder a NON-DIP-spacing-device?
For example to use the new FTDI FT230X-Chip? http://www.ftdichip.com/Support/Documents/DataSheets/ICs/DS_FT230X.pdf
best regards
Stefan
