How do I solder teensy chips?
I have an AS5055 chip that measures 4mm square with four leads dividing the middle 2mm on each side, smaller than I can measure. With regular surface mount devices I can usually solder directly or attach wires to each lead first. These are too small for anything I've got. I saw one strategy to put bits of solder on a printed circuit board and somehow heat the whole chip. Even that looks risky this small.
Also, if I make a tiny soldering iron by heating a small PCB drill bit red hot with a Radio Shack soldering torch, it doesn't hold the heat long and even that isn't really small enough. What do people use? Thanks.
Most of them use solder paste on the circuit board.
Once you have the solder paste in place with the chip on top, you can heat it with a hot air rework station.
I've also seen people use electric hot plates and toaster ovens to heat up the boards.
I've wondered if it's posible to use conductive paint to make connections to small chips.
My idea is to glue the chip upside down to a board and then paint a trace from the chip to point where it would be easier to make a connection.
The evaluation boards may be an option (or not)
Any link on solder paste? I know about flux paste but I don't know what solder paste is.
I hope your idea for conductive paint works! Looks good. It may require a one hair paintbrush. :-)
Maybe one could glue wires to the sides of the chip then paint the connections and skip the board.
bad, it's QFN and it's harder to inspect a good solder job.
Use solder paste, very very little of it.
http://search.digikey.com/us/en/products/SMD291AX/SMD291AX-ND/1160002
Then put it in a oven, skillet or use hot-air reflow station.
You may have to reheat it with hot-air and press down on it.
http://electronics.mcmelectronics.com/?N=&Ntt=solder+paste&x=0&y=0
Thanks, I'm Duane's consulting employer for this project. I was still looking around for other bits of information until it works, but it looks like he's got it handled.
The evaluation boards are as usual way overpriced to use on a regular basis and in this case too large. I'd like something the size of these pots http://search.digikey.com/us/en/products/EVW-AE4001B14/P12426CT-ND/637165
I assume it's more solid than paint when done, if done right. With paint you can see your work.
You wouldn't want to use paint on anything other than a prototype (I'm not sure it would even work for a prototype).
Solderpaste is used on almost all surface mount production. It's usually pretty strong.
I'll find their electric skillet tutorial and post a link here.
I found the Kester.com website lists distributors for their Kester Easy 256 product listed in the tutorial. I don't see any instructions on how to make the solder mask or where to get the plastic or metal films. I suppose they are same as used for silk screening. It would still take ultra tiny solder mask holes to do it that way but since that's the only way less costly than ordering a custom chip...
BTW, somewhere I read of a possibility of running the solder paste through some print head. That would be nice.
You just carefully smear some paste on the pad with the syringe.
But with QFN, very little of it. I get a 75% sucess rate first time.
One question, what if you cut a square hole in the PCB to just fit the 4mm chip then glue it so the leads are at the same surface as the PCB copper? Can you then smear the solder paste over the crack between chip and board to get a good visible solder joint?
What I like to do is to use a QFN pad that is little larger than recommended smt layout.
As your IC does have exposed side pads (though not fully exposed) maybe the solder paste will cling to the sides.
Not sure what you mean, QFN pad? I had to double check on the sides, they are so small. If anything would stick there it would seem more likely to be some kind of tiny spot welder like they use to attach carrier wires inside chips.
http://www.youtube.com/watch?v=Aq5ydeWWr4A
(SN62RA10BAS86-25G CARTRIDGE - SOLDER PASTE, 62/36/2 SN/PB/AG 179°C 25G)
The reason being is that:
a) It's the lowest temperature paste that I could find.
b) It's no clean solder (which is a BIG DEAL imho if this is your first time around the block).
I use a $30 electric skillet from target to bake my boards.
http://www.youtube.com/watch?v=ihoX7x0RBz8
The only thing I would do differently is to place just enough of the 'glue' at either end of the IC chip for easy removal after soldering, rather than a gob right underneath.
