Opa4227
Hello everyone,
I am working with the OPA4227 on a project that requires an op amp that will read extremely small voltages.... typical input voltage from the particular sensor going to it is 20 mV. I have it wired in a typical non-inverting negative feedback configuration (use this all the time so I'm 99% sure it isn't wired incorrectly. The issue I am having is that the op amp when fed a voltage below ~ 0.5 V only puts out 0.07 V. As soon as I get to ~0.5 V, the op amp jumps to the positive rail (4.25 V). I have the circuit set for a gain of 11. Also, something strange in that the two inputs, which should be pulled to the same voltage (right?) never reach the same level. I haven't only tested the one chip, but several different ones, so I know it is not just a defective unit. I am completely stuck on this one as I've never had op amp issues before so any advice is greatly appreciated!
Some DIY options:
-- 2 battery packs hooked together (+) to (-), with ground in the middle.
-- DIY from a center tapped transformer with a couple of diodes and capacitors to make the (+) and (-) with respect to the center tap.
-- Use the single ended supply along with something like an ICL7660 voltage inverter. You feed +5V in on one pin, and -5V comes out on another pin, with respect to a common ground. There are many ICs available for that purpose.
-- Buy a DC-DC power supply. Many are available and many different power ratings. For example, you could buy one in a DIP14 package that takes 5V at the input and provides +/- 12V at the output at 1 watt. E.g. DCP010512 from Texas Instruments/Burr Brown, about $10.
The single-supply op-amps I use primarily for DC precision are the LTC1051 or the LTC2055. They are "autozeroing" op-amps meant for precision at DC and low frequencies, and the offset is less than 5 microvolts.
Another good option I forgot to mention is a virtual ground. A separate op-amp is DC biased from a single supply so that it puts out say V/2 at its output, and you use that as the common reference point for your circuit. I keep on hand a few dedicated virtual ground chips (3-lead TO92), the TLE2426 and TLE2425.
