VNC server for the propeller,possible?
Tubular
Beau's AndroidVNC recommendation has me thinking - how hard would it be to write a VNC server application for the propeller?
VNC ("Virtual Network Computing") relays the display buffer of the server to a viewer, and relays the keyboard/mouse events from the viewer back to the host (ie the Propeller).
VNC is based on the RFB protocol initially developed by Olivetti. At first glance It doesn't look all that scary (at least version 3.3), but perhaps there is devil in the detail. Does anyone have any experience with the protocol?
It would be possible to use an Ethernet<>Serial converter to handle the network side, so the propeller would just have to handle the serial stream and encoding/decoding. The Spinneret may also be a possibility.
There are VNC hosts and viewers available for pretty much every platform, including smartphones.
I did something similar for "PropMonitor", but only transmitted the screen buffer, not the raw pixel data.
Sending the screen as pixels would be too slow, I think...
But, something like this that also sent back mouse and keyboard input is a great idea.
