Spinneret setup help — Parallax Forums
WildatheartWildatheart Posts: 195
edited 2012-03-21 10:51 in Accessories
I've been trying to get my Spinneret up and running, but I can't seem to get beyond "GET /index.htm Write 404 Error". I do have the "Hello World" file (index.htm) on the SD card.
My Spinneret is listed in the D-Link's list of "LAN COMPUTERS" at 192.168.0.120, and I can also get a 0 or 1 ms ping response through my D-Link Router test.
Changes to HTTPServer example are as folows:
mac.....................byte $00, $08, $DC, $16, $F2, $06
subnet.................byte 255, 255 ,255, 0
gateway..............byte 192, 168, 0, 1
ip........................byte 192, 168, 0, 120
port.....................word 5000
remoteIp.............byte 72, 222, 244, 139
I can post screenshots of the D-Link settings if it will help.
Thanks for your help. Gordon
  • Mike GMike G Posts: 2,702
    edited 2012-03-17 14:25
    The 404 error is coming from the Spinneret. You can ping the Spinneret. So I doubt it's connection or router configuration.
    Try formatting the SD card and copying the files over again. BTW, what kind of SD card are you using?
    What URL are you typing into the browser address bar?
  • WildatheartWildatheart Posts: 195
    edited 2012-03-17 18:01
    Following your advice, I reformated the 4gb SanDisk and saved the Hello World again. No cigar. Believing that I once read that 2gb might be the max size, I went to Fry's, bought a new Patriot 2gb card, formated it, and saved index.htm to it. Same thing - the PST running on my laptop indicates and counts each ping made from my desktop.
    I'm using URL in IE7or8 http://192.168.0.120:5000/
    I should mention that below
    clsd open lstn estb clwt cling udps
    is
    0000-0000-0111-0000-0000-0000-0000
    not
    0000-0000-1111-0000-0000-0000-0000
    as shown in the tutorial
    The format options used were
    File System - Fat32
    Allocation Unit Size 32kb
    I should also ask, is it reasonable for the Spinneret to exhaust a fresh 9v battery in less than an hour of usage?
    edited 2012-03-17 18:27
    According to the documentation the Spinneret draws 175mA while idle. A typical 9V battery capacity is around 500 mAh.
    500/175 = 2.8 hours under no load. So draining a 9V battery in an hour is very achievable.
    Post your running source code.
    Describe your connections.
    Yada, yada, yada...
    edited 2012-03-17 20:10
    Thanks for your help, Mike.
    Spinneret connections:
    [HP laptop running PST, USB]<--->[Prop Plug on Spinneret]
    [Spinneret CAT5]<--->[DLink Router LAN port #2]
    [Spinneret J6]<--->[9volt battery]
    Entering 192.168.0.120:5000 on desktop PC IE produces screenshot PST (not yet attached)
    [php]
    CON
    _clkmode = xtal1 + pll16x
    _xinfreq = 5_000_000
    MAX_PACKET_SIZE = $5C0 '1472 '$800 = 2048
    RxTx_BUFFER = $800 '$600 = 1536
    TEMP_BUFFER = $600 '$5B4 = 1460
    TCP_PROTOCOL = %0001 '$300 = 768
    UDP_PROTOCOL = %0010 '$200 = 512
    TCP_CONNECT = $04 '$100 = 256
    DELAY = $05
    #1, ErrorConnect, ErrorVersion, ErrorChecksum, ErrorProgram, ErrorVerify
    #0, Shutdown, LoadRun, ProgramShutdown, ProgramRun
    #0, DONE, PUT, CD
    DAT
    mac byte $00, $08, $DC, $16, $F2, $06
    subnet byte 255, 255 ,255, 0
    ip byte 192, 168, 0, 120
    gateway byte 192, 168, 0, 1
    port word 5000
    uport word 5050
    remoteIp byte 72, 222, 244, 139
    remotePort word 80
    emailIp byte 0, 0, 0, 0
    emailPort word 25
    status byte $00, $00, $00, $00
    rxdata byte $0[RxTx_BUFFER]
    txdata byte $0[RxTx_BUFFER]
    udpdata byte $0[TEMP_BUFFER]
    fileErrorHandle long $0
    debug byte $0
    lastFile byte $0[12], 0
    closedState byte %0000
    openState byte %0000
    listenState byte %0000
    establishedState byte %0000
    closingState byte %0000
    closeWaitState byte %0000
    lastEstblState byte %0000
    lastEstblStateDebug byte %0000
    udpListen byte %0000
    tcpMask byte %0111
    udpMask byte %1000
    fifoSocketDepth byte $0
    fifoSocket long $00_00_00_00
    debugSemId byte $00
    debugCounter long $00
    stringMethods long $00
    closingTimeout long $00, $00, $00, $00
    udpLen long $00
    time byte "00/00/0000 00:00:00", 0
    httpDate byte "Wed, 01 Feb 2000 01:00:00 GMT", 0
    globalCache byte $0
    VAR
    long StackSpace[20]
    long P31, P30, LFSR, Ver, Echo
    OBJ
    Socket : "W5100_Indirect_Driver"
    pst : "Parallax Serial Terminal"
    SDCard : "SD2.0_FATWrapper"
    Request : "Request"
    Response : "Response"
    str : "StringMethods"
    rtc : "S35390A_RTCEngine"
    PUB Initialize | id, size, st
    debug := 1
    SDCard.Start
    stringMethods := str.Start
    Request.Constructor(stringMethods)
    Response.Constructor(stringMethods, @txdata)
    pst.Start(115_200)
    pause(200)
    'Mount the SD card
    pst.str(string("Mount SD Card - "))
    SDCard.mount(fileErrorHandle)
    pst.str(string("OK",13))
    pst.str(string("Start RTC: "))
    rtc.RTCEngineStart(29, 28, -1)
    pause(200)
    pst.str(FillTime)
    'Start the W5100 driver
    if(Socket.Start)
    pst.str(string(13, "W5100 Driver Started", 13))
    pst.str(string(13, "Status Memory Lock ID : "))
    pst.dec(Socket.GetLockId)
    pst.char(13)
    if(debugSemId := locknew) == -1
    pst.str(string("Error, no HTTP server locks available", 13))
    else
    pst.str(string("HTTP Server Lock ID : "))
    pst.dec(debugSemId)
    pst.char(13)
    'Set the Socket addresses
    SetMac(@mac)
    SetGateway(@gateway)
    SetSubnet(@subnet)
    SetIP(@ip)
    ' Initailize TCP sockets (defalut setting; TCP, Port, remote ip and remote port)
    repeat id from 0 to 3
    InitializeSocket(id)
    Request.Release(id)
    pause(50)
    ' Set all TCP sockets to listen
    pst.char(13)
    Socket.Listen(id)
    pst.str(string("TCP Socket Listener ID : "))
    pst.dec(id)
    pst.char(13)
    pause(50)
    ' Initialize UDP socket(s)
    InitializeUPDSocket(id)
    pause(50)
    pst.str(string("UDP Socket Listener ID : "))
    pst.dec(id)
    pst.char(13)
    pst.Str(string(13,"Started Socket Monitoring Service", 13))
    cognew(StatusMonitor, @StackSpace)
    pause(250)
    pst.Str(string(13, "Initial Socket States",13))
    StackDump
    pst.Str(string(13, "Initial Socket Queue",13))
    QueueDump
    Main
    PUB Main | packetSize, id, i, reset, j, temp
    'HTTP server service
    'GetMyIp(0)
    'SendTestEmail(0)
    pst.str(string(13,"//////////////////////////////////////////////////////////////",13))
    repeat
    repeat until fifoSocket == 0
    bytefill(@rxdata, 0, RxTx_BUFFER)
    if(debug)
    Start of Request
    ",13))
    'QueueDump
    pause(DELAY)
    else
    pause(DELAY)
    ' Pop the next socket handle
    id := DequeueSocket
    if(id < 0)
    next
    if(debug)
    pst.str(string(13,"ID: "))
    pst.dec(id)
    pst.str(string(13, "Request Count : "))
    pst.dec(debugCounter)
    pst.char(13)
    'StackDump
    packetSize := Socket.rxTCP(id, @rxdata)
    'if(debug)
    'pst.str(string(13, "packetSize : "))
    'pst.dec(packetSize)
    'pst.str(string(13, "strsize(@rxdata) : "))
    'pst.dec(strsize(@rxdata))
    'else
    'pause(DELAY)
    reset := false
    if ((packetSize < 12) AND (strsize(@rxdata) < 12))
    repeat i from 0 to 5
    'Wait for a few moments and try again
    waitcnt((clkfreq/500) + cnt)
    'if(debug)
    'pst.str(string("retry["))
    'pst.dec(i)
    'pst.str(string("]: "))
    'pst.char(13)
    ' pause(100)
    if(packetSize > 12)
    quit
    if(i == 10)
    'Clean up resource request
    Request.Release(id)
    Socket.Close(id)
    reset := true
    if(debug)
    pst.str(string(13,"* Read Failure *",13))
    if(reset)
    next
    Request.InitializeRequest(id, @rxdata)
    if(debug)
    pst.str(string("Content-Length : "))
    pst.dec(Request.GetContentLength(id))
    pst.char(13)
    if(debug)
    pst.str(string("QueryString: "))
    pst.str(Request.GetQueryString(id))
    pst.char(13)
    if(debug)
    pst.char(13)
    HeaderLine1(id)
    'toString(id)
    else
    pause(DELAY)
    ' Process router
    Dispatcher(id)
    'Clean up request resource
    Request.Release(id)
    ' This starts the close process -> 0x00
    ' use close to force a close
    Socket.Disconnect(id)
    bytefill(@txdata, 0, RxTx_BUFFER)
    if(debug)
    'StackDump
    'pst.char(13)
    'QueueDump
    pause(DELAY)
    else
    pause(DELAY)
    debugCounter++
    GotoMain
    PRI GotoMain
    Main
    PRI QueueDump
    pst.str(string("FIFO["))
    pst.dec(fifoSocketDepth)
    pst.str(string("] "))
    pst.hex(fifoSocket, 8)
    PRI StackDump | clsd, open, lstn, estb, clwt, clng, id, ulst
    repeat until not lockset(debugSemId)
    clsd := closedState
    open := openState
    lstn := listenState
    estb := establishedState
    clwt := closeWaitState
    clng := closingState
    ulst := udpListen
    lockclr(debugSemId)
    pst.char(13)
    repeat id from 3 to 0
    pst.dec(id)
    pst.str(string("-"))
    pst.hex(status[id], 2)
    pst.str(string(" "))
    pause(1)
    pst.str(string(13,"clsd open lstn estb clwt clng udps", 13))
    pst.bin(clsd, 4)
    pst.bin(open, 4)
    pst.bin(lstn, 4)
    pst.bin(estb, 4)
    pst.bin(clwt, 4)
    pst.bin(clng, 4)
    pst.bin(ulst, 4)
    pst.char(13)
    PRI StatusMonitor | id, tmp, value
    repeat
    Socket.GetStatus32(@status[0])
    ' Encode status register states
    closedState := openState := listenState := establishedState := {
    } closeWaitState := closingState := 0
    case(status[id])
    $00: closedState |= |< id
    closedState &= tcpMask
    $13: openState |= |< id
    openState &= tcpMask
    $14: listenState |= |< id
    listenState &= tcpMask
    $17: establishedState |= |< id
    establishedState &= tcpMask
    $18,$1A,$1B: closingState |= |< id
    closingState &= tcpMask
    $1C: closeWaitState |= |< id
    closeWaitState &= tcpMask
    $1D: closingState |= |< id
    $22: udpListen |= |< id
    udpListen &= udpMask
    if(lastEstblState <> establishedState)
    value := establishedState
    repeat while value > 0
    tmp := DecodeId(value)
    if(tmp > -1)
    QueueSocket(tmp)
    tmp := |< tmp
    tmp := !tmp
    value &= tmp
    lastEstblState := establishedState
    lockclr(debugSemId)
    ' Initialize a closed socket
    if(closedState > 0)
    id := DecodeId(closedState)
    if(id > -1)
    InitializeSocket(id & tcpMask)
    'Start a listener on an initialized/open socket
    if(openState > 0)
    id := DecodeId(openState)
    if(id > -1)
    Socket.Listen(id & tcpMask)
    ' Close the socket if the status is close/wait
    ' response processor should close the socket with disconnect
    ' there could be a timeout so we have a forced close.
    ' TODO: CCheck for a port that gets stuck in a closing state
    'if(closeWaitState > 0)
    'id := DecodeId(closeWaitState)
    'if(id > -1)
    'Socket.Close(id & tcpMask)
    'pause(100)
    return
    PRI GetTcpSocketMask(id)
    return id & tcpMask
    PRI DecodeId(value) | tmp
    if(%0001 & value)
    return 0
    if(%0010 & value)
    return 1
    if(%0100 & value)
    return 2
    if(%1000 & value)
    return 3
    return -1
    PRI QueueSocket(id) | tmp
    if(fifoSocketDepth > 4)
    return false
    tmp := |< id
    'Unique check
    ifnot(IsUnique(tmp))
    return false
    tmp <<= (fifoSocketDepth++) * 8
    fifoSocket |= tmp
    return true
    PRI IsUnique(encodedId) | tmp
    tmp := encodedId & $0F
    repeat 4
    if(encodedId & fifoSocket)
    return false
    encodedId <<= 8
    return true
    PRI DequeueSocket | tmp
    if(fifoSocketDepth == 0)
    return -2
    tmp := fifoSocket & $0F
    fifoSocket >>= 8
    fifoSocketDepth--
    lockclr(debugSemId)
    return DecodeId(tmp)
    PRI ResetSocket(id)
    Socket.Close(id)
    PRI ChangeDirectory(id) | i, found
    'Return if the directory is not found
    ifnot(FileExists(Request.GetPathNode(id, i)))
    return false
    'Handle directory structure for this Request
    if(Request.GetDepth(id) > 1)
    repeat i from 0 to Request.GetDepth(id)-2
    found := SDCard.changeDirectory(Request.GetPathNode(id, i))
    return true
    PRI FileExists(fileToCompare) | filenamePtr
    'Start file find at the top of the list
    SDCard.startFindFile
    'Verify that the file exists
    filenamePtr := SDCard.nextFile
    repeat while filenamePtr <> 0
    if(str.MatchPattern(filenamePtr, fileToCompare, 0, false ) == 0 )
    return true
    return false
    PRI StaticFileHandler(id) | fileSize, i, headerLen, temp, j
    'pst.str(string(13,"Static File Handler",13))
    SDCard.changeDirectory(@approot)
    'pst.char(13)
    'Make sure the directory exists
    ifnot(ChangeDirectory(id))
    'send 404 error
    WriteError(id)
    return
    ' Make sure the file exists
    ifnot(FileExists(Request.GetFileName(id)))
    'send 404 error
    WriteError(id)
    return
    ' Open the file for reading
    SDCard.openFile(Request.GetFileName(id), "r")
    fileSize := SDCard.getFileSize
    'WriteResponseHeader(id)
    'BuildHeader(extension, statusCode, expirer)
    headerLen := Response.BuildHeader(Request.GetExtension(id), 200, false)
    Socket.txTCP(id, @txdata, headerLen)
    if fileSize < MAX_PACKET_SIZE
    ' send the file in one packet
    SDCard.readFromFile(@txdata, fileSize)
    Socket.txTCP(id, @txdata, fileSize)
    else
    ' send the file in a bunch of packets
    repeat
    SDCard.readFromFile(@txdata, MAX_PACKET_SIZE)
    Socket.txTCP(id, @txdata, MAX_PACKET_SIZE)
    fileSize -= MAX_PACKET_SIZE
    ' once the remaining fileSize is less then the max packet size, just send that remaining bit and quit the loop
    if fileSize < MAX_PACKET_SIZE and fileSize > 0
    quit
    ' Bailout
    if(i++ > 1_000_000)
    WriteError(id)
    quit
    SDCard.closeFile
    return
    PUB WriteError(id) | headerOffset
    pst.str(string(13, "Write 404 Error",13 ))
    headerOffset := Response.BuildHeader(Request.GetExtension(id), 404, false)
    Socket.txTCP(id, @txdata, headerOffset)
    return
    PUB SetTcpSocketMaskById(id, state) | tmp
    tmp := |< id
    if(state == 1)
    tcpMask |= tmp
    else
    tmp := !tmp
    tcpMask &= tmp
    PUB IsolateTcpSocketById(id) | tmp
    tmp := |< id
    tcpMask &= tmp
    PUB GetCommandRegisterAddress(id)
    return Socket#_S0_CR + (id * $0100)
    PUB GetStatusRegisterAddress(id)
    return Socket#_S0_SR + (id * $0100)
    PRI SetMac(_firstOctet)
    Socket.WriteMACaddress(true, _firstOctet)
    return
    PRI SetGateway(_firstOctet)
    Socket.WriteGatewayAddress(true, _firstOctet)
    return
    PRI SetSubnet(_firstOctet)
    Socket.WriteSubnetMask(true, _firstOctet)
    return
    PRI SetIP(_firstOctet)
    Socket.WriteIPAddress(true, _firstOctet)
    return
    PRI StringSend(id, _dataPtr)
    Socket.txTCP(id, _dataPtr, strsize(_dataPtr))
    return
    PRI SendChar(id, _dataPtr)
    Socket.txTCP(id, _dataPtr, 1)
    return
    PRI SendChars(id, _dataPtr, _length)
    Socket.txTCP(id, _dataPtr, _length)
    return
    PRI InitializeSocket(id)
    Socket.Initialize(id, TCP_PROTOCOL, port, remotePort, @remoteIp)
    return
    PRI InitializeSocketForEmail(id)
    Socket.Initialize(id, TCP_PROTOCOL, port, emailPort, @emailIp)
    return
    PRI InitializeUPDSocket(id)
    Socket.Initialize(id, UDP_PROTOCOL, uport, remotePort, @remoteIp)
    return
    PRI HeaderLine1(id) | i
    pst.str(Request.GetMethod(id))
    pst.char($20)
    i := 0
    repeat Request.GetDepth(id)
    pst.char($2F)
    pst.str(Request.GetPathNode(id, i++))
    'Chance to do some processing before sending the response
    PRI Dispatcher(id)
    'if(strcomp(Request.GetName(id), string("index")))
    'Index(id)
    if(strcomp(Request.GetName(id), string("post")))
    Post(id)
    if(strcomp(Request.GetName(id), string("upload")))
    Upload(id)
    if(strcomp(Request.GetName(id), string("ajax")))
    Ajax(id)
    if(strcomp(Request.GetName(id), string("getdir")))
    GetDir(id)
    return
    if(strcomp(Request.GetName(id), string("gettime")))
    GetTime(id)
    return
    if(strcomp(Request.GetName(id), string("upsite")))
    UploadSite(id)
    return
    return
    PRI Index(id)
    pst.str(string(13, "Index Processor", 13))
    pst.str(string("led := "))
    pst.str(Request.Get(id, string("led")))
    pst.char(13)
    pst.str(string("this := "))
    pst.str(Request.Get(id, string("this")))
    pst.char(13)
    return
    PRI Post(id)
    pst.str(string(13, "**************************", 13))
    pst.str(@rxdata)
    return
    'tempMask := tcpMask
    'IsolateTcpSocketById(id)
    PRI Upload(id) | tempMask, strt, end, rxBytes, bodyPtr, bytesRead, i, packetSize, j, dataS, dataE, bodySize, bodyE, temp
    AppendLog(@rxdata)
    bytefill(@boundary1, 0, 64)
    i := 0
    j := 0
    dataE := 0
    bytesRead := 0
    ifnot(strcomp(Request.GetMethod(id), String("POST")))
    return
    'pst.str(string(13, "Content Length: "))
    rxBytes := Request.GetContentLength(id)
    'pst.dec(rxBytes)
    'pst.char(13)
    'pst.str(string(13, "@rxdata Length: "))
    'pst.char(13)
    'Content-Type: multipart/form-data; boundary=
    'Get the mutlipart boundary
    'pst.str(string(13, "Get start of boundary= "))
    strt := str.MatchPattern(@rxdata, @multipart, 0, false)
    strt += strsize(@multipart)
    'pst.hex(strt, 4)
    'pst.str(string(13, "End of boundary= ") )
    end := str.MatchPattern(@rxdata, @crlf, strt, true)
    'pst.hex(end, 4)
    'pst.str(string(13, "Buffer boundary") )
    bytemove(@boundary1, @rxdata+strt, end-strt)
    'pst.str(string(13, "Boundary: "))
    'pst.str(@boundary)
    'pst.str(string(13, "Boundary Len: "))
    'pst.dec(strsize(@boundary))
    'Find the body and see if we need to grab more stream data
    'pst.str(string(13, "Find body data: "))
    strt := str.MatchPattern(@rxdata, @crlf_crlf, 0, true)
    bodyPtr := strt + strsize(@crlf_crlf)
    'pst.hex(bodyPtr, 4)
    'pst.str(string(13, "Body length: "))
    bodySize := strsize(@rxdata)-bodyPtr
    'pst.dec(bodySize)
    'Get the filename being uploaded
    'pst.str(string(13, "Find the start of filename"))
    'Find filename="upload.txt"
    strt := str.MatchPattern(@rxdata, @fn, strt, false)
    if(strt == -1)
    'pst.str(string(13, "Filename not found!"))
    'Try to handle MAC POST
    pause(200)
    if(strt == -1)
    return
    'pst.str(string(13,"filename pointer: "))
    'pst.hex(strt, 4)
    'Point to the first letter after the double quote
    strt += strsize(@fn) + 1
    'pst.str(string(13, "Find the end of filename"))
    'Find the ending double quote = $22
    end := str.MatchPattern(@rxdata, @doublequote, strt, true)
    'pst.str(string(13,"End filename pointer: "))
    pst.hex(end, 4)
    if(end-strt > 12)
    'pst.str(string(13, "File name is longer than 12 chars"))
    return
    'pst.str(string(13, "Write file name to buffer"))
    Set(@uploadfile, strt+@rxdata, end-strt)
    'pst.str(string(13, "filename: "))
    'pst.str(@uploadfile)
    'Drill into the first boundary to get the file content
    '@crlf_crlf should be after the file name in the header
    'pst.str(string(13, "Find file data start: "))
    strt := str.MatchPattern(@rxdata, @crlf_crlf, end, true)
    if(strt == -1)
    strt := 0
    else
    strt := strt + strsize(@crlf_crlf)
    dataS := strt
    bytesRead := strsize(@rxdata)-dataS
    'pst.hex(dataS, 4)
    ' Check for an end boundary
    end := str.MatchPattern(@rxdata, @boundary, strt, true)
    'pst.str(string(13, "Find file data end: "))
    'pst.hex(end, 4)
    if(end == -1)
    dataE := 0
    else
    dataE := end-1
    bytesRead := end-strt
    'write file content to the SD card
    'does the file exist? Yes = delete/create; no = create
    'pst.str(string(13, "change directory"))
    SDCard.changeDirectory(@uploadfolder)
    'pst.str(string(13, "File Exists?"))
    if(FileExists(@uploadfile))
    'pst.str(string(13, "YES File Exists - DELETE"))
    SDCard.deleteEntry(@uploadfile)
    'pst.str(string(13, "Create file"))
    SDCard.newFile(@uploadfile)
    'pst.str(string(13, "Open file"))
    SDCard.openFile(@uploadfile, "w")
    'do we a boundary in the 2K buffer?
    if(end > -1)
    dataE := end
    ' Write data within boundaries if everything fits in the buffer
    ' the loop spans the 2k buffer
    'pst.str(string(13, "Write to file"))
    if(bytesRead > 0)
    SDCard.writeData(@rxdata+dataS, bytesRead)
    rxBytes := rxBytes - bodySize
    ' pst.str(string(13, "Bytes Left: "))
    pst.dec(rxBytes)
    'pst.str(string(13, "Looping"))
    repeat while rxBytes > 0
    if(packetSize > 0)
    'For the most part, I'm see 1460 byte packets in FF
    'Let's see if we hit a boundary
    'and hope the boundary is not split between packets
    end := str.MatchPattern(@rxdata, @boundary, 0, true)
    if(end == -1)
    SDCard.writeData(@rxdata, packetSize)
    else
    'pst.str(string(13, "Writing end of data"))
    pst.str(@rxdata+end-2)
    SDCard.writeData(@rxdata, end-2)
    rxBytes := rxBytes - packetSize
    'pst.str(string(13, "Bytes Left: "))
    pst.dec(rxBytes)
    pause(200)
    i := 0
    else
    i++
    pause(200)
    if(i > 100)
    quit
    'pst.str(string(13, "loops : "))
    pst.dec(j)
    'pst.str(string(13, "rxBytes : "))
    pst.dec(rxBytes)
    'pst.str(string(13, "Close file", 13))
    SDCard.closeFile
    'Reset the tcpMask
    'tcpMask := tempMask
    bytefill(@uploadfile, 0, 12)
    return
    PRI UploadSite(id) | rxBytes, bytesRead, packetSize, i, j, command
    packetSize := 0
    i := 0
    command := PUT
    'We're expecting a HTTP PUT
    ifnot(strcomp(Request.GetMethod(id), String("PUT")))
    return
    'pst.char(13)
    'pst.str(@rxdata)
    'pst.char(13)
    'Initail handshake
    pst.str(string(13, "Send Greeting"))
    StringSend(id, string("Hello from Spinneret!",13,10))
    'Authenticate
    ifnot(Authenticate(id))
    return
    'Get first level target directory
    GetDirectory(id)
    'Repeat until we get the QUIT command from the client
    repeat until command == DONE
    'Initailize
    [ Debug ]
    ", 13))
    bytefill(@binFile, 0, 12)
    pause(100)
    ' Get a filename and size
    GetUploadFileName(id)
    rxBytes := GetFileSize(id)
    'if the file exists then delete the file and create a new file
    if(FileExists(@binFile))
    SDCard.deleteEntry(@binFile)
    SDCard.newFile(@binFile)
    SDCard.openFile(@binFile, "w")
    pst.str(string(13, "File Upload in process"))
    j := 0
    'Reads the file stream and write to the SD Card
    j++
    ' Get byte stream
    if(packetSize > 0)
    'Write byte stream to the SD card
    StringSend(id, string("OK - Write"))
    pst.dec(rxBytes)
    pause(100)
    i := 0
    else
    i++
    pause(100)
    if(i > 100)
    StringSend(id, string("TIMEOUT"))
    SDCard.closeFile
    quit
    ' Diagnotics - Loop counter
    pst.dec(j)
    SDCard.closeFile
    command := GetHttpFileTxCommnad(id)
    'change directory
    if(command == CD)
    GetDirectory(id)
    'CD to root and get out of here
    pst.str(string(13, "Done!!!", 13))
    return
    PRI Authenticate(id) : ok | packetSize
    ''Username
    ok := false
    pst.str(string(13, "Wait for username"))
    repeat
    pause(200)
    if(packetSize > 0)
    quit
    pst.str(string(13, "Received Username"))
    pst.char(13)
    pst.str(@rxdata)
    if(strcomp(@rxdata, string("username")))
    StringSend(id, string("OK - Authenticated"))
    ok := true
    else
    StringSend(id, string("QUIT - No Dice"))
    bytefill(@rxdata, 0, 50)
    return
    PRI GetUploadFileName(id) | packetSize
    ''Get file name
    pst.str(string(13, "Wait for filename"))
    repeat
    pause(200)
    if(packetSize > 0)
    quit
    pst.str(string(13, "Received Filename: "))
    pst.str(@rxdata)
    bytemove(@binFile, @rxdata, strsize(@rxdata) #> 12)
    StringSend(id, string("OK - Received Filename"))
    return
    PRI GetFileSize(id) : rxBytes | packetSize
    pst.str(string(13, "Get file size"))
    repeat
    pause(200)
    if(packetSize > 0)
    quit
    pst.str(string(13, "Received File Size: "))
    rxBytes := str.ToInteger(@rxdata)
    pst.dec(rxBytes)
    StringSend(id, string("OK - Received File Size"))
    return
    PRI GetDirectory(id) : rxBytes | packetSize
    bytefill(@binDir, 0, 8)
    pst.str(string(13, "Get directory"))
    repeat
    pause(200)
    if(packetSize > 0)
    quit
    pst.str(string(13, "Received Directory: "))
    StringSend(id, string("OK - Received Directory"))
    bytemove(@binDir, @rxdata, strsize(@rxdata))
    pst.str(@binDir)
    pst.str(string(13, "Change Directory "))
    SDCard.changeDirectory(@binDir)
    pst.str(string(13, "Change Directory Success"))
    return
    PRI GetHttpFileTxCommnad(id) : again | packetSize
    pst.str(string(13, "Upload another file?"))
    repeat
    pause(200)
    if(packetSize > 0)
    quit
    pst.str(string(13, "Received Command: "))
    pst.str(@rxdata)
    if(strcomp(@rxdata, string("QUIT")))
    StringSend(id, string("OK - Bye"))
    again := DONE
    if(strcomp(@rxdata, string("PUT")))
    StringSend(id, string("OK - Put File"))
    again := PUT
    if(strcomp(@rxdata, string("CD")))
    StringSend(id, string("OK - Change Directory"))
    again := CD
    pst.str(string(13, "File Command: "))
    pst.dec(again)
    return
    PRI GetTime(id) | ptr, headerOffset
    ptr := @udpdata
    'FillTime
    FillHttpDate
    bytemove(ptr, string("<p>"),3)
    ptr += 3
    bytemove(ptr, @httpDate, strsize(@httpDate))
    ptr += strsize(@httpDate)
    'bytemove(ptr, @time, strsize(@time))
    'ptr += strsize(@time)
    'bytemove(ptr, string(" (GMT-7)"), 8)
    'ptr += 8
    bytemove(ptr, string("</p>"),4)
    ptr += 3
    headerOffset := Response.BuildHeader(Request.GetExtension(id), 200, false)
    StringSend(id, @udpdata)
    bytefill(@udpdata, 0, TEMP_BUFFER)
    return
    PRI GetDir(id) | filenamePtr, ptr, headerOffset, cmd, qfile
    'pst.str(string(13, "GetDir", 13))
    ptr := @udpdata
    'pst.str(string(13, "change dir", 13))
    cmd := Request.Get(id, string("cmd"))
    if(strcomp(cmd, string("d")))
    qfile := Request.Get(id, string("file"))
    SDCard.deleteEntry(qfile)
    'pst.str(string(13, "startFindFile", 13))
    filenamePtr := 1
    if(strcomp(filenamePtr, string(".")) or strcomp(filenamePtr, string("..")) or strsize(filenamePtr) == 0)
    next
    'pst.str(filenamePtr)
    'pst.char(13)
    'pst.dec(strsize(filenamePtr))
    'pst.char(13)
    bytemove(ptr, string("<a href='uploads/"),17)
    ptr += 17
    bytemove(ptr, filenamePtr, strsize(filenamePtr))
    ptr += strsize(filenamePtr)
    bytemove(ptr, string("'>"),2)
    ptr += 2
    bytemove(ptr, string("</a>  "),16)
    ptr += 16
    ptr += 17
    bytemove(ptr, string("'?cmd=d>delete</a>"),18)
    ptr += 18
    bytemove(ptr, string("<br>"),4)
    ptr += 4
    'pst.char(13)
    'pst.str(@udpdata)
    'pst.char(13)
    'pst.str(string(13, "send header", 13))
    'pst.str(string(13, "send data", 13))
    return
    PRI AppendLog(logToAppend)
    if(FileExists(@logfile))
    'pst.str(string(13, "LOG: open file for writing", 13))
    SDCard.openFile(@logfile, "A")
    else
    'pst.str(string(13, "LOG: Create new file", 13))
    SDCard.newFile(@logfile)
    SDCard.writeData(string(13,10,"
    Start "),14)
    SDCard.writeData(FillTime, 19)
    SDCard.writeData(string("
    "),6)
    SDCard.writeData(@crlf_crlf, 2)
    'pst.str(string(13, "LOG: Append", 13))
    SDCard.writeData(logToAppend, strsize(logToAppend))
    End "),10)
    "),6)
    'pst.str(string(13, "LOG: Close file", 13))
    SDCard.closeFile
    PRI Set(DestAddress, SrcAddress, Count)
    bytemove(DestAddress, SrcAddress, Count)
    bytefill(DestAddress+Count, $0, 1)
    PRI Ajax(id)
    pst.str(@rxdata)
    return
    PRI FillTime | ptr, num
    'ToString(integerToConvert, destinationPointer)
    '00/00/0000 00:00:00
    ptr := @time
    rtc.readTime
    FillTimeHelper(rtc.clockMonth, ptr)
    ptr += 3
    FillTimeHelper(rtc.clockDate, ptr)
    ptr += 3
    FillTimeHelper(rtc.clockYear, ptr)
    ptr += 5
    FillTimeHelper(rtc.clockHour , ptr)
    ptr += 3
    FillTimeHelper(rtc.clockMinute , ptr)
    ptr += 3
    FillTimeHelper(rtc.clockSecond, ptr)
    return @time
    PRI FillHttpDate | ptr, num, temp
    'Wed, 01 Feb 2000 01:00:00 GMT
    ptr := @httpDate
    rtc.readTime
    temp := rtc.getDayString
    bytemove(ptr, temp, strsize(temp))
    ptr += strsize(temp) + 2
    ptr += 3
    temp := rtc.getMonthString
    ptr += strsize(temp) + 1
    ptr += 5
    ptr += 3
    ptr += 3
    return @httpDate
    PRI FillTimeHelper(number, ptr) | offset
    offset := 0
    if(number < 10)
    offset := 1
    str.ToString(@number, @tempNum)
    bytemove(ptr+offset, @tempNum, strsize(@tempNum))
    PRI toString(id) | i
    pst.str(string("
    ",13))
    pst.str(string("Version : "))
    pst.str(Request.GetVersion(id))
    pst.char(13)
    pst.str(string("QueryString : "))
    pst.char(13)
    pst.str(string("Method : "))
    pst.char(13)
    pst.str(string("Depth : "))
    pst.dec(Request.GetDepth(id))
    pst.char(13)
    i := 0
    pst.dec(i)
    pst.str(string(". Name : "))
    pst.char(13)
    pst.str(string("FileName : "))
    pst.str(Request.GetFileName(id))
    pst.char(13)
    pst.str(string("Name : "))
    pst.str(Request.GetName(id))
    pst.char(13)
    pst.str(string("Extension : "))
    pst.str(Request.GetExtension(id))
    pst.char(13)
    pst.str(string("Content-Len : "))
    pst.char(13)
    PRI Pause(Duration)
    waitcnt(((clkfreq / 1_000 * Duration - 3932) #> 381) + cnt)
    return
    DAT
    approot byte "\", 0
    placeholder byte "<!--[content]-->", 0
    tempFile byte "temp.htm", 0
    defaultpage byte "index.htm", 0
    logfile byte "log.txt", 0
    cacheFile byte "cache.txt", 0
    binFile byte "filename.bin", 0
    binDir byte "director", 0
    loadFile byte "led0.bin", 0
    FS byte "/", 0
    fn byte "filename=", 0
    doublequote byte $22, 0
    crlf byte 13, 10, 0
    crlf_crlf byte 13, 10, 13, 10, 0
    uploadfile byte $0[12], 0
    divider byte "----", 0
    uploadfolder byte "uploads", 0
    tempNum byte "0000",0
    multipart byte "Content-Type: multipart/form-data; boundary=",0
    boundary byte $2D, $2D
    boundary1 byte $0[64]
    hashboundary byte "123ABC",0
    loadme file "TogglePin0.binary" [/php]
    [php]
    <html>
    <head>
    <title>Hello World</title>
    </head>
    <body>
    Hello World!
    </body>
    </html>
    [/php]
    I have 4 or 5 screenshots but I'll have to figure out how to attach them if they'd help.
    edited 2012-03-18 08:05
    WildAtheart, you changed the SD Driver.
    The latest HTTPServer is using Kye's 3.0 driver.
    SDCard        : "S35390A_SD-MMC_FATEngineWrapper"
    Load the "proven to work" default HTTPServer to verify network configuration.
    http://code.google.com/p/spinneret-web-server/source/browse/#svn%2Ftrunk%2FMultiSocketServer_MikeG%2FTutorialSourceArchives%2Fspin
    Then troubleshoot the SD driver changes you made to HTTPServer.
    Suggestions:
    Get yourself a wal-wart power supply. I'm using an old 5V cell phone charger.
    Post configuration and any changes made to original source code when posting a problem.
    edited 2012-03-19 11:24
    I have no clue how the SD driver was changed - it was possibly downloaded from an earlier version of the httpServe. I've had the Spinneret for nearly a year, and because of the seeemingly complex nature of the thing I've only now risked trying to use it. But with a little help any amature can have fun with it. Thanks for yours!
    Now then... yes, the wall-wart is a must! I believe HTML5 isn't fully operational yet, but I tried it anyway and am able to serve up the page at...
    It works 100% of the time from my Windows desktop and laptop, but I get timeouts and a blank screen on my Ipad in about 14 out of the 15 attempts. Is it possible to adjust a timing setting in either the Ipad or the server?
    A button press on the page gives an indication of the responsiveness of the Spinneret. It's pretty fast!
    edited 2012-03-19 12:22
    Sorry, must be old code. I'm guessing you loaded the latest?
    What data is displayed in PST? Is the Spinneret locking up? How many images or links do you have on the page? Is the connection over WiFi?
    All browsers behave differently. You'll have to do some troubleshooting to figure out the problem. You might have to write a little Spin to target the issue or print more information to PST.
    I do not have an iPad so I'd be shooting in the dark.
    edited 2012-03-19 19:51
    My excitement to believe that I was up and running was short lived - my daughter told me that 192.168.0.120:5000 was my internal LAN address. It seems I should be using
    http://72.222.244.139 to open this project to the WWW. Not sure.
    In any case, the attached shows the PST after 1 attempt on my Iphone. Although all objects on the page don't show - probably because its mobile - I can serve up a reasonable representation of the page on the phone. But maybe the Iphone is still connecting through LAN. My Windows IE browser does open the full page and the resulting effect is noted in the attached.
    I'll leave the Spinneret connected if anyone would like to check it from the outside. But gee whiz, there are hundreds of options in the DLink settings so I wouldn't think that I'd break out and into the WWW any time soon.
    1024 x 640 - 107K
  • TumblerTumbler Posts: 323
    edited 2012-03-19 20:36
    Working here in Belgium.
    You forgot the port number (:5000)in your link
    630 x 463 - 76K
    edited 2012-03-19 21:10
    That's it! I'd like to get a couple more confirmations before marking this thread resolved. My daughter in Denver just tried it again and it didn't work for her. May I ask what browser you're using?
    Thanks for noting the missing 5K http://72.222.244.139:5000
    edited 2012-03-19 21:29
    Tested it with IE9 and safari
    edited 2012-03-20 06:07
    If Tumbler can hit your page, your router configuration is correct.
    Suggestion, make your test page as simple as possible. No graphics, no css, no HTML5, just a simple "Hello World".
  • MoskogMoskog Posts: 556
    edited 2012-03-20 06:12
    Access to 72.222.244.139 denied. Requests to port 5000 are restricted.
  • max72max72 Posts: 1,155
    edited 2012-03-20 14:58
    Working from Italy with android.
    Massimo
    edited 2012-03-20 22:01
    I can hit the page too.
    edited 2012-03-21 09:37
    Works for me TODAY from:
    OS X Lion 10.7.3 - Firefox 11.0
    OS X Lion 10.7.3 - Safari 5.1.4
    WIN 7 - Firefox 11.0
    WIN 7 - IE 9
    Fedora 16 Linux - Firefox 11.0
    iPhone 4GS WiFi IOS 5.1 - Safari
    iPhone 4GS 4G IOS5.1 - Safari
    Yesterday, it was not working for me at all from anything I tried.
    It appears that my Spinneret is accessable worldwide so now its on to learning some more about the Spinneret and html.
    I continue to use html5 at this time so it seems IE9, Safari 5. and... is required to fully view the page.
    My version 1 Ipad still has a little problem with reliable connection but I think that's the problem of the older Ipad itself.
    Thanks to all who helped with what I perceived as a daunting task.
