Is my Quickstart DOA?
ctwardell
I bought a Quickstart a couple weeks ago, along with a GG Prop Platform USB and just got around to working with them yesterday.
The PP USB works fine, as well as the C3 that I already had, but the Quickstart is not being found by the Propeller Tool V1.3.
I tried on both my desktop and laptop running W7 64 bit, as well as a VM running 32 bit XP.
The blue and red LED's blink when first connected, the green power LED is on, and I measure 3.3V at the power pins beside the header.
Any ideas on anything to check or try?
C.W.
C.W.
sometimes I have to hit F10/F11 multiple times or unplug the usb connector and plug it back in.
I'm not using a hub.
If you put a 10K pull up on P30 like mindrobots suggested, does the problem go away?
C.W.
It is connected directly.
C.W.
Tried external power, no joy.
Checked for clock at XO, no joy.
I'm assuming at this point it was a DOA.
Bummer.
Thanks for help.
C.W.
Phil,
I forgot about that possibility.
C.W.
Yeah, I think that is all that is left to do.
C.W.
But...when ilook in hardware alas, com port 10 is in use and turning on and off with that bd
Also the blue and red board lights are a flashin.
Also the yellow box in the corner of the program software says it is verified and loaded
THEN the no propeller chip found on any serial port shows up with checked com port 10.
I removed the driver and reloaded it from site download
Tried the 10k ohm thing from 30 to 3.3
Nuthin but must be doable.
Hi there. Welcome to the forum.
If the port is in use on your computer it's probably because a program has it opened.
Sometimes programs can get stuck even if they are not open on the desktop.
Check with your task manager in windows or top in linux for common program names.
--Steve
Com port 10 is responding to the propeller!
When I plug it in, com &lpt shows a usb usage on 10
When I unplug it, device mn goes silent on use of 10.
Its the propeller! Then im told its not! Wrong answer by the error msg!
Verstehen?
I found that if I hold the board and push in on the USB connector while checking for the device, or downloading a program, I can get it to work.
I tried two different cables and get the same result with each. Both cables work for my C3 and GG Prop USB
C.W.
Ouch. RMA time?
Did you use the support portal? http://support.parallax.com/index.php?/Core/Default/Index
@stargazer2050,
Maybe you should visit the support portal? It's hard to understand what's happening just by forum posts.
Yep, got an RMA, it's going back to the mothership for inspection.
C.W.
try to change the usb cable.
moreover if you have another PC test the board with this second one.
You can also try the current pc with a linux live and bst.
Recently I also had a faulty hub giving a lot of troubles, not only with the propeller.
Massimo
Never thought about using a 10k pull-up on p30. I give that a try.
Renee
Went back to radio shack today and the guy swapped out my board and cable.
Hooked it up and worked good then froze again within five times.
Called tech support, they said it can be the cable but to change the latency (in hardware advanced) down below 16.
Also go to ftdichip.com and get latest com drivers.
Did all that and I put it to bed for the day working good.
Itll die tomorrow but were gittin somewhere and it doesnt hav 2be perfect.
Hard to imagine, but I've had "Not found" issues on a couple Quickstart boards recently on one computer...
Though it was an intermittent problem before so it's hard to tell.
Does the QuickStart use a cheap mini-usb receptacle?, or what is the problem?
I had this problem before on this computer with all Prop boards with an old Prop tool...
Prop Tools since 1.2.6 or so fixed it... But, I have noticed the problem coming back with Quickstarts, which is really interesting...
No way the connector is the difference. Maybe there's a ns delay in the logic buffer the Quickstart uses that makes it borderline on some computers...
BTW: My current trick is to immediatly when I get the "Not Found" message, try again. If I'm fast enough the second time, it works...
BTW2: I also recently rebooted (which I don't do very often) at that also seems to have fixed the problem...
I'm having dejavu though, because this is exactly what used to happen to me on this computer with older versions of the Prop Tool...
I have a few other computers that have never had a problem with any Prop board.... Very strange...
— David Carrier
Parallax Inc.
