"No propeller chip found on any serial port. Proto board stopped being recogni
I received a Propeller Proto Board and Prop Plug last week, and created a couple simple programs and they loaded/ran fine.
I took the board home for the weekend, to work on it more, and it is not recognized in the Propeller Tool or BST.
I tested the prop plug by opening up a terminal program on that com port and shorting together rx and tx on the prop plug.· All characters echo as expected.
The blue LED also lights when doing this, and when trying to program with BST.
I verified the 4 header pins (gnd,rst,tx,rx) had continuity to Vss, Pin 7 of the propeller chip and P30/31 of the propeller chip.
Any ideas on what might be wrong, or anything else to check?
thanks
bill
thanks
bill
Are you using a different (slower) computer than before?
I'm not sure if its needed but is the prop plug or Vinculum FTDI driver installed on it?
Are you running other applications besides Propeller Tool? (especially internet access)
Generally I only see the Propeller fail to program because of timing issues from other processes.
But I only see "No Propeller Found on COM port" if I forgot to put the power switch on
or connect the programming cable.
Does the Propeller run from eeprom instead?
I've never even heard of sudden unexplained total loss of programmability before.
If it worked on a different computer, I think it probably still does.
I tried on 3 different computers at home.
Yep, installed before connecting the cable, just like the first time.
Npoe.
Checked several times, moved between computers, no extraneous processes running, etc
There wasn't a program in it so that I could verify if it was running.
I find it hard to believe that both computers I tried at home are both "incompatible" -- I will bring it back to work
in the AM and see if it works with the original machine.
If not, send it back to find out what happened?
bill
I'm telling you all this because maybe 1. your background security features are causing your problems and/or 2. you might get success by just trying again and again and again...
I hope that helps,
Mark
I have emailed a support request to Parallax to see what steps to take next.
thanks
bill
One other thing to check is if your Prop resets when you do "identify" from PropTool...
It does this by toggling the DTR line of the FTDI chip on the PropPlug which momentarily pulls down RES\ of the Prop...
Might be hard to tell, depending on what code you had in EEPROM last...
If you did any soldering on your Protoboard, you might want to re-check the last things you did...
Beyond that, I'd just say that I've found it easier to kill a Protoboard than a PropPlug...
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
My Prop Products:· http://www.rayslogic.com/Propeller/Products/Products.htm
Make sure you have a good ground and the propeller programmer sees the port. Check the port list
Will work for Propeller parts!
I have not had problems with the FTDI chips in my prop plugs(4 of 6), prop clips(2), protoboard USB's (~20), prop demo boards (3), PPDB(2), propstick USB (3). I have run various combinations of these (sometimes 3 at a time) on differrent PC's from old XP P4-530's to the CoreI7-920 under Windows7-64bit with no issues. I have around 10 XP machines, a couple vista tablets and several Windows7 (all 64-bit unfortunately) machines that always work fine with some them up to COM35 because of all the different FTDI chips that connected to a particular machine. Asside: I am thankfull that Parallax has drivers that work on 64-bit and the fact that they are signed (Windows 7 needs it) - for other manufactures - notably some FPGA ones - the drivers are either unsigned (alternate boot req) or only support 32-bit (welcome back XP).
However, I do have 2 prop plugs that do not work anymore -and this is likely 100% my fault, I keep trying to use them but put them in a static bag - labelled and will one day send them back to Parallax for diagnostics as I was told on the forum by a Parallax director-level person that they are curious and will replace them.
So my issue was likely static discharge as I hand carried them across town or the carpet at my work - as I, like you occassionally bring boards (connected in my case to breadboards) back and forth to work so I can
D) upgrade the hardware of some working device back at home and bring it back to work on monday and hang it on the wall.
E) monitor the temp of the 3.3v regulator under a heavly load all day
I also busted a VFD from parallax and a protoboard after soldering 4 headers but that is another issue - the protoboard is in the freezer trying to replicate the -72c that parallax tests under (see youtube) and i only solder 2 of 4 headers on my other protoboards more carefully - and I am more relaxed now.
Solution:
I try to get at least 2 of everything and make identical prototypes - so I can have an exact replica of each circuit at work and at home and I only carry a memory stick with spin on it now - it also helps to narrow down the issue to usually my own circuitry.
When I need to move a board, I leave the USB proto plug connected to the USB cable at work, take the board home and reconnect it to another USB protoplug at home - no more issues. Otherwise I use a large static bag for the whole thing.
I use a static wrist strap around my lab, but I find that handling the prop clip especially by the edges has no issues.
The humidity in my lab usually hovers at 40%
When I follow these precautions I no longer have had any issues with my prop plugs for over 6 months now.
Also the fact that Parallax has graciously lowered the price of protoboard USB versions and the prop plug by about 30% this year.
Don't know if any of this helps.
thank you
Michael O'Brien
If it helps anyone else, I had the same error message (and this was the first time trying to use my new Prop demo board). The problem was simply not turning on the little power switch (duh).
The more recent issue was due to winodws updates: windows xp SP2 worked for a while, but would not work with a new prop board. The PC was very old and slow, and not connected to the internet; all non-essential "features" were disabled for performance. The issue was resolved reinstalling windows xp SP1 (reformat hard drive, clean install), connecting the PC to the internet, and allowing the PC to automatic update to the the current (SP3) level. The actual isue may have been related to .NET or MDAC, but I did not bother to check it fully after it started working.
My general fix for windows xp is to reinstall windows xp (reformat hard drive, clean install) and ask questions later. It save a LOT of time.
Hope this helps
Ben
Bruce
+1 - a couple of times.
Blue and red is flashing
Nothing connected to bd
Software says code is verified and uploaded (yellow box in lower rt )
Thats when the no propeller chip found msg arrives
I unloaded and reloaded drivers downloaded fresh from site
Tried 10k from pin 30 to 3.3v
What's next?
I might have to look into this too... I think I'm having occasional troubles on some comptures with the Quickstart.
It's wierd because I've had absolutely no trouble for about a year... I think it must of been some Windows Update on that driver that messed it up...
Lower latency below 16 (hardware, device manager, advanced)
Download ftdichip.com VCP drivers
Yes its working at least every other time which is ok fer now
Regards
Richard
Anyone have the steps for resetting a FTDI chip's eeprom? I've heard that mentioned in several threads but have never gotten a reasonable description of how this can be accomplished.
As far as resetting the Proto boards EEPROM, are we talking about just pushing the board's reset button? Or is there a way to erase the EEPROM without having access to the board via the FTDI driver on a USB-based computer?
dgately
Don't mess with the FTDI chip's EEPROM. It's intended to be set by the manufacturer of the device and contains things like the USB identification information. In Parallax's case, FTDI sets it.
