Propstacklen: A program to calculate SPIN stack sizes — Parallax Forums
johnfosjohnfos Posts: 59
edited 2012-04-14 08:31 in Propeller 1
For some time now I've been working on a program that will calculate the stack size required for a SPIN program. It's now at the stage of generating output, and I'd like to gauge how much interest there'd be if I published it in the Obex.
At the moment, I believe the usual way to check stack size is to fill the stack area with longs of some value, and then run the program and see how many get overwritten. The snag with that technique is that it gives only a lower bound for the size - a program run with different inputs may send the stack deeper.
So I wrote propstacklen to carry out a static analysis of the SPIN program, from which the deepest possible stack can be traced. When run, propstacklen reads the .list and .eeprom files that the compiler generated, and generates a report showing the trace of method calls that will produce the maximum stack. In this way, the figures generated in the report are the upper bound on the stack size.
Here's the output from PlayWav_8bit.spin in the WavPlayers Obex object. This is about a simple as it gets, because that program has only two methods: a main method, and one that's called by main(). The maximum stack depth is 80 bytes
Stack depth report for PlayWav_8bit
Generated by propstacklen version 0.1
STACK DEPTH REPORT for Method PlayWav_8bit.Main
All reported values are in decimal notation unless prefixed with 0x
Stack sizes are given in bytes
Main stack starts at 0x7340 and so extends to 0x738f
      80            Max stack depth within PlayWav_8bit.Main()
                    occurs in line 12 at statement:
                        Player(@Wav,10,11)
              24    is the local stack frame depth before the call
                    to PlayWav_8bit.Player
      56            Max stack depth within PlayWav_8bit.Player()
                    occurs in line 24 at statement:
                        CTRA:= 110 << 26 + 0<<9 + PinR
By way of contrast, here's the much more extensive report for Mike Green's BoeBotBasic:
Stack depth report for BoeBotBasic
STACK DEPTH REPORT for Method BoeBotBasic.main
RECURSION WARNING: Recursion has been detected and will add to the stack size
Main stack starts at 0x4900 and so extends to 0x4b3b
     572            Max stack depth within BoeBotBasic.main()
                    occurs in line 220 at statement:
                        err := \doline(s)
              20    is the local stack frame depth before the call
                    to BoeBotBasic.doline
     552            Max stack depth within BoeBotBasic.doline()
                    occurs in line 1300 at statement:
                        texec
                    to BoeBotBasic.texec
     532            Max stack depth within BoeBotBasic.texec()
                    occurs in line 1284 at statement:
                        mass.writeExpander(a,specialExpr)
              96    is the local stack frame depth before the call
                    to BoeBotBasic.specialExpr
     436            Max stack depth within BoeBotBasic.specialExpr()
                    occurs in line 666 at statement:
                        return expr
              12    is the local stack frame depth before the call
                    to BoeBotBasic.expr
     424            Max stack depth within BoeBotBasic.expr()
                    occurs in line 653 at statement:
                        t := logicAnd
                    to BoeBotBasic.logicAnd
     404            Max stack depth within BoeBotBasic.logicAnd()
                    occurs in line 643 at statement:
                        t := logicNot
                    to BoeBotBasic.logicNot
     384            Max stack depth within BoeBotBasic.logicNot()
                    occurs in line 639 at statement:
                        return not compare
                    to BoeBotBasic.compare
     372            Max stack depth within BoeBotBasic.compare()
                    occurs in line 612 at statement:
                        a := arithExpr
              28    is the local stack frame depth before the call
                    to BoeBotBasic.arithExpr
     344            Max stack depth within BoeBotBasic.arithExpr()
                    occurs in line 599 at statement:
                        t := term
                    to BoeBotBasic.term
     324            Max stack depth within BoeBotBasic.term()
                    occurs in line 583 at statement:
                        t := bitTerm
                    to BoeBotBasic.bitTerm
     304            Max stack depth within BoeBotBasic.bitTerm()
                    occurs in line 570 at statement:
                        t := bitFactor
                    to BoeBotBasic.bitFactor
     284            Max stack depth within BoeBotBasic.bitFactor()
                    occurs in line 560 at statement:
                        t := shifts
                    to BoeBotBasic.shifts
     264            Max stack depth within BoeBotBasic.shifts()
                    occurs in line 536 at statement:
                        t := factor
                    to BoeBotBasic.factor
     244            Max stack depth within BoeBotBasic.factor()
                    occurs in line 465 at statement:
                        return mass.getByte
                    to BB_massStorage.getByte
     224            Max stack depth within BB_massStorage.getByte()
                    occurs in line 170 at statement:
                        return pgetc
                    to BB_massStorage.pgetc
     212            Max stack depth within BB_massStorage.pgetc()
                    occurs in line 667 at statement:
                        t := pfillbuf
              16    is the local stack frame depth before the call
                    to BB_massStorage.pfillbuf
     196            Max stack depth within BB_massStorage.pfillbuf()
                    occurs in line 483 at statement:
                        fclust := nextcluster
                    to BB_massStorage.nextcluster
     180            Max stack depth within BB_massStorage.nextcluster()
                    occurs in line 378 at statement:
                        clust := followchain
                    to BB_massStorage.followchain
     164            Max stack depth within BB_massStorage.followchain()
                    occurs in line 368 at statement:
                        clust := brword(readfat(fclust))
                    to BB_massStorage.readfat
     144            Max stack depth within BB_massStorage.readfat()
                    occurs in line 362 at statement:
                        return readbytec(fatptr)
                    to BB_massStorage.readbytec
     128            Max stack depth within BB_massStorage.readbytec()
                    occurs in line 353 at statement:
                        readblockc(byteloc >> SectorShift)
                    to BB_massStorage.readblockc
     112            Max stack depth within BB_massStorage.readblockc()
                    occurs in line 268 at statement:
                        flushifdirty
                    to BB_massStorage.flushifdirty
      96            Max stack depth within BB_massStorage.flushifdirty()
                    occurs in line 259 at statement:
                        writeblock2(lastread, @buf2)
                    to BB_massStorage.writeblock2
      84            Max stack depth within BB_massStorage.writeblock2()
                    occurs in line 250 at statement:
                        ldr.writeSDCard(n, b, SectorSize)
                    to BB_i2cSpiLdr.writeSDCard
      64            Max stack depth within BB_i2cSpiLdr.writeSDCard()
                    occurs in line 107 at statement:
                        return doOperation(def#ioSpiWrite,addr,buffer,count)
                    to BB_i2cSpiLdr.doOperation
      40            Max stack depth within BB_i2cSpiLdr.doOperation()
                    occurs in line 123 at statement:
                        long[def#ioControl+4] := (count << 16) | (buffer & $FFFF)
STACK DEPTH REPORT for Method BoeBotBasic.servoProcess
      36            Max stack depth within BoeBotBasic.servoProcess()
                    occurs in line 1463 at statement:
                        uS := clkfreq / 1_000_000
STACK DEPTH REPORT for Method BoeBotBasic.pingProcess
      32            Max stack depth within BoeBotBasic.pingProcess()
                    occurs in line 1490 at statement:
                        waitpne(0, |< pingData, 0)
The first thing to notice is that BoeBotBasic uses recursion. Nothing wrong with that in itself, but it does mean that the stack size is unpredictable as far as a program like propstacklen (or, I believe, any other conceivable program) is concerned. So it reports the stack size for the main program as 572 bytes, but every recursive call will add to that amount. So far, propstacklen merely notes that recursion was detected. It would be possible to improve on that level of reporting, though never to the extent of predicting a maximum stack size when recursion is present.
The other thing to note is that if you scroll to the bottom of the report, you'll find that BoeBotBasic has two methods (servoProcess and pingProcess) that are opened in seperate cogs. Propstacklen detects this, and reports on the stack sizes those cogs will need.
Not shown here, but some SPIN programs are intended as libraries - not complete programs, but objects to be used within other programs. In such cases, propstacklen can be told to produce a separate report for each PUB method in the top object, giving an indication of the stack impact of using the library.
Propstacklen is a command line program written in C++, so it should run on any platform that has a C++ compiler. It writes its output to the standard output stream. It's developed and has been (minimally) tested under Linux; if it fails to build and run under other operating systems I'll consider that a bug.
Techie note: propstacklen doesn't work on the .spin file. Instead, it uses the .list and .eeprom files as generated by Brad's bstc compiler. That means that it should reflect any compiler optimisations that are applied. It also means that *any* compiler, for any language, that generates SPIN byte code should be covered by it - with the possible need to accommodate that compiler's particular syntax of the list file.
Source code. I don't believe the source code is polished enough for public display, but if I wait until it is you'll never see it :-)
So I've put it on my website here: http://www.jsjf.demon.uk/propstacklen.zip. I would have attached it to this post, but the forum software and Firefox don't seem to play well together in that regard. See the file README.txt for more details of how to use propstacklen.
Update: the latest version is http://www.jsjf.demon.co.uk/propstacklen_0.3.zip.
  • JLockeJLocke Posts: 354
    edited 2012-03-05 22:01
    Looks pretty awesome! I'll definitely download your .zip file and check it out. Thanks so much for your efforts!
    edited 2012-03-11 15:39
    I finally got around to compiling and trying out Propstacklen. I ran it on a current project, a temperature and humidity data-logger and got different results than you show above. It appears to have given up before it completed analysis. The last line says "There were error messages.", but doesn't say what those were. Here's the total output:
    Stack depth report for Thermo-Master
    Object Thermo-Master created at 0010
    Object pcFullDuplexSerial4FC created at 0a44
    Object DS1307_RTCEngine created at 15a4
    Object Simple_Numbers created at 1894
    Object F32 created at 1a4c
    Object FloatString created at 248c
    Object FloatMath created at 28f0
    Object Sensirion_full created at 2ae0
    Object Strings2 created at 2d2c
    Object fsrw created at 3074
    Object sdspiqasm created at 3878
    11 objects
    214 methods
    1445 spin lines
    5732 instructions
    1504 labels
    71 vars
    486 params
    140 locals
    pbase 0010 vbase 0000 vsize 03e9 (00fb longs)  Thermo-Master
    pbase 0a44 vbase 0000 vsize 0000 (0000 longs)  pcFullDuplexSerial4FC
    pbase 15a4 vbase 0000 vsize 0008 (0002 longs)  DS1307_RTCEngine
    pbase 1894 vbase 0000 vsize 0044 (0011 longs)  Simple_Numbers
    pbase 1a4c vbase 0000 vsize 0005 (0002 longs)  F32
    pbase 248c vbase 0000 vsize 0040 (0010 longs)  FloatString
    pbase 28f0 vbase 0000 vsize 0000 (0000 longs)  FloatMath
    pbase 2ae0 vbase 0000 vsize 0008 (0002 longs)  Sensirion_full
    pbase 2d2c vbase 0000 vsize 0020 (0008 longs)  Strings2
    pbase 3074 vbase 0000 vsize 0453 (0115 longs)  fsrw
    pbase 3878 vbase 0000 vsize 0010 (0004 longs)  sdspiqasm
    Total VAR space 0243 longs, 090c bytes
    Start address is 010c
    Adding process Method Thermo-Master.main
    plantFirstInstr (main) Method Thermo-Master.main
    plantFirstInstr (called) Method F32.start
    plantFirstInstr (called) Method F32.stop
    plantFirstInstr (called) Method pcFullDuplexSerial4FC.Init
    plantFirstInstr (called) Method pcFullDuplexSerial4FC.Stop
    Spinline popFrame: stack is empty for spin line at 0130
    Exploration terminated
    Was exploring Instr at 012d opcode 39
    Instruction count: 56
    All encountered instructions have exploration code
    All encountered instructions have known targets
    All mcod3 values are handled
    Any ideas? I should add that the program compiles and runs.
  • johnfosjohnfos Posts: 59
    edited 2012-03-11 16:37
    Oops!
    The error message it's referring to was the line:
    You've found an error in the program.
    Could you either post or send by PM your .list and .eeprom files?
    I'll look into it. The message you saw was generated by defensive code and should not have happened :-(
    edited 2012-03-11 22:31
    I'll post it up when I get home in the morning (at work now). Thanks again.
    edited 2012-03-12 06:10
    Here are my .list and .eeprom files: Thermo-Master Files.zip.
    Happy bug hunting!
    edited 2012-03-12 06:36
    Got it, thanks. Looking into it now.
    edited 2012-03-13 11:27
    @JLocke:
    Well, that was exciting. I'm not done yet, but I can present the report for your program:
    [john@henry thermo-master]$ propstacklen -q Thermo-Master
    Generated by propstacklen version 0.2
    STACK DEPTH REPORT for Method thermo-master.main
    Main stack starts at 0x44c0 and so extends to 0x455f
         160            Max stack depth within thermo-master.main()
                        occurs in line 169 at statement:
                            updateLCDLocal
                        to thermo-master.updateLCDLocal
         144            Max stack depth within thermo-master.updateLCDLocal()
                        occurs in line 384 at statement:
                            Comms.str(LCD, FltStr.FloatToFormat(LocTemp, 5, 1))
                        to FloatString.FloatToFormat
         124            Max stack depth within FloatString.FloatToFormat()
                        occurs in line 201 at statement:
                            n := F.FRound(F.FMul(single & $7FFF_FFFF , F.FFloat(teni[dp])))
                  36    is the local stack frame depth before the call
                        to FloatMath.FMul
          88            Max stack depth within FloatMath.FMul()
                        occurs in line 110 at statement:
                            Unpack(@sa, singleA)
                  44    is the local stack frame depth before the call
                        to FloatMath.Unpack
          44            Max stack depth within FloatMath.Unpack()
                        occurs in line 174 at statement:
                            longmove(pointer, @s, 3)
    STACK DEPTH REPORT for Method thermo-master.cog_LocalTemp
         120            Max stack depth within thermo-master.cog_LocalTemp()
                        occurs in line 190 at statement:
                            Sht.config(33, Sht#off, Sht#yes, Sht#hires)
                        to Sensirion_full.config
          92            Max stack depth within Sensirion_full.config()
                        occurs in line 100 at statement:
                            writeStatus((heater << 2) + (OTPreload << 1) + measRes)
                        to Sensirion_full.writeStatus
          64            Max stack depth within Sensirion_full.writeStatus()
                            ack := sendCommand(cmd_WriteStatus)
                        to Sensirion_full.sendCommand
          44            Max stack depth within Sensirion_full.sendCommand()
                        occurs in line 199 at statement:
                            return writeByte(cmd)
                        to Sensirion_full.writeByte
          28            Max stack depth within Sensirion_full.writeByte()
                        occurs in line 232 at statement:
                            dira[dpin] := value >> 7
    STACK DEPTH REPORT for Method thermo-master.cog_Remote
         160            Max stack depth within thermo-master.cog_Remote()
                        occurs in line 240 at statement:
                            Comms.str(XB, FltStr.FloatToFormat(LocTemp, 5, 1))
                        to FloatMath.FMul
                        to FloatMath.Unpack
    STACK DEPTH REPORT for Method thermo-master.cog_Log
         224            Max stack depth within thermo-master.cog_Log()
                        occurs in line 293 at statement:
                            Drv.popen(@FilName, "a")
                        to fsrw.popen
         204            Max stack depth within fsrw.popen()
                        occurs in line 377 at statement:
                            pclose
                        to fsrw.pclose
         168            Max stack depth within fsrw.pclose()
                        occurs in line 349 at statement:
                            r := pflush
                        to fsrw.pflush
         152            Max stack depth within fsrw.pflush()
                        occurs in line 319 at statement:
                            return pflushbuf(bufat, 1)
                        to fsrw.pflushbuf
         140            Max stack depth within fsrw.pflushbuf()
                        occurs in line 276 at statement:
                            readfat(cluststart)
                        to fsrw.readfat
         104            Max stack depth within fsrw.readfat()
                        occurs in line 217 at statement:
                        to fsrw.readbytec
          88            Max stack depth within fsrw.readbytec()
                        occurs in line 209 at statement:
                            readblockc(byteloc >> SECTORSHIFT)
                        to fsrw.readblockc
          72            Max stack depth within fsrw.readblockc()
                        occurs in line 131 at statement:
                            flushifdirty
                        to fsrw.flushifdirty
          56            Max stack depth within fsrw.flushifdirty()
                        to fsrw.writeblock2
          44            Max stack depth within fsrw.writeblock2()
                        occurs in line 115 at statement:
                            sdspi.writeblock(n, b)
                        to sdspiqasm.writeblock
          24            Max stack depth within sdspiqasm.writeblock()
                        occurs in line 92 at statement:
                            param := b
    STACK DEPTH REPORT for Method thermo-master.cog_Button
          20            Max stack depth within thermo-master.cog_Button()
                        occurs in line 345 at statement:
                            waitcnt((clkfreq / 5) + cnt)
    You might want to examine the section on cog_Log - if propstacklen is right (big if), you'll be wanting to increase that stack allowance.
    I haven't yet published the updated source, because one of the things I had to fix was an error in handling the bytecode generated for the LOOKUPZ spin statement. A similar fix will be needed for LOOKDOWN/LOOKDOWNZ so I'd like to do that before unleashing the next version.
    Meanwhile, I hope the report helps.
    edited 2012-03-13 14:53
    Thanks so much! I'd been playing with the stack sizes and that is why I was so interested in your program. Looking forward to the release of the next rev!
    edited 2012-03-13 15:14
    How did I miss this?
    This is great. I'll be sure to try it out.
    Thank you,
    edited 2012-03-13 16:04
    Hi Duane
    Please do - and please be patient if, like JLocke, it doesn't work for you out of the box. I've been testing it on objects pulled more or less at random from the Obex, and clearly I haven't necessarily covered all the possible cases yet.
    Suggestions of large and/or complicated Obex programs that might be good exercises are also welcome.
    edited 2012-03-15 11:27
    Ok, here's version 0.2 of propstacklen. There's a new url for the zip file:
    http://www.jsjf.demon.co.uk/propstacklen_0.2.zip
    See README.txt for detailed information about the program.
    I have (I hope) fixed the problem that DLocke had, and made a few other mainly cosmetic changes. For example, error messages are now clearly marked as such instead of just being buried in the rest of the output.
    My test cases still don't include full coverage of the SPIN bytecodes, and I'd be very grateful if someone could suggest an Obex program that makes extensive use of locks in particular.
    I'm also contemplating the fact that this tool should work with compilers other than bstc. If anyone's interested in that, I'd need a listing file and eeprom file generated by the compiler. The source language doesn't have to be spin: any compiler that generates spin byte code should be fair game.
    Enjoy!
    edited 2012-04-04 21:49
    Hello again,
    I've made some rather significant changes to my project source, so thought I'd try version 0.2. I built the executable and ran it against my project files, and again came up with an error. Below is the output from the program:
    Stack depth report for thermo-master
    Object thermo-master created at 0010
    Object pcFullDuplexSerial4FC created at 0960
    Object DS1307_RTCEngine created at 14c0
    Object Simple_Numbers created at 17b0
    Object F32 created at 1968
    Object FloatString created at 23a8
    Object FloatMath created at 280c
    Object Sensirion_full created at 29fc
    Object Strings2 created at 2c48
    Object fsrw created at 2f90
    Object sdspiqasm created at 3794
    Object jl_unix_time created at 3ad0
    12 objects
    229 methods
    1507 spin lines
    6119 instructions
    1528 labels
    68 vars
    535 params
    174 locals
    pbase 0010 vbase 0000 vsize 0a36 (028e longs)  thermo-master
    pbase 0960 vbase 0000 vsize 0000 (0000 longs)  pcFullDuplexSerial4FC
    pbase 14c0 vbase 0000 vsize 0008 (0002 longs)  DS1307_RTCEngine
    pbase 17b0 vbase 0000 vsize 0044 (0011 longs)  Simple_Numbers
    pbase 1968 vbase 0000 vsize 0005 (0002 longs)  F32
    pbase 23a8 vbase 0000 vsize 0040 (0010 longs)  FloatString
    pbase 280c vbase 0000 vsize 0000 (0000 longs)  FloatMath
    pbase 29fc vbase 0000 vsize 0008 (0002 longs)  Sensirion_full
    pbase 2c48 vbase 0000 vsize 0020 (0008 longs)  Strings2
    pbase 2f90 vbase 0000 vsize 0453 (0115 longs)  fsrw
    pbase 3794 vbase 0000 vsize 0010 (0004 longs)  sdspiqasm
    pbase 3ad0 vbase 0000 vsize 001c (0007 longs)  jl_unix_time
    Total VAR space 03dd longs, 0f74 bytes
    Start address is 0110
    Adding process Method thermo-master.main
    Error: Spinline popFrame: stack is empty for spin line at 0130
    Was exploring Instr at 0131 opcode 39
    There was one error message.
    I've attached my .list and .eeprom files for your inspection. Thanks!
    edited 2012-04-12 08:40
    I'm so sorry - I must have missed your last post and have only now come across it. I'm also sorry that we have another problem to deal with.
    The issue is that propstacklen is being confused by a perfectly legitimate trick you're using: breaking a long line of code by terminating it with '{' and starting the next line with '}'. The continuation line then appears in the list file out of the normal sequence.
    I need to fix propstacklen, but as a temporary work-round you could try removing those line breaks (there are only four). Propstacklen v0.2 will then process your files.
    My problem is that bstc appears to be inconsistent in its own handling of this: sometimes it lists the continuation line, sometimes not. I need to look further into it.
    edited 2012-04-12 09:25
    Version 0.3 of propstacklen is now available: http://www.jsjf.demon.co.uk/propstacklen_0.3.zip.
    It fixes the problem where using a curly bracketted comment to split long source lines was causing confusion in the parse of the list file. No other changes.
    edited 2012-04-13 12:04
    Yes, thanks so much. That works for me now! I ran another project through and got this message "Error: List file contains instruction with no previous spin line. Was the compilation done without the -s flag? Error: The list file was not parseable. Sorry." This is a new project that I just patched together, so I'm going to look it over a bit. The list file looks OK at first glance.
    Glad the first one worked.
    For the second, it's complaining that you ran bstc without specifying the -s flag (which tells bstc to include the source lines in the list file). Since you've been using propstacklen successfully I assume you did use the flag, in which case this is a propstacklen error.
    If you'd care to post the list and eeprom files for the failure case, I'll look into it.
    And thanks for your patience and all the useful feedback.
