eeprom and i2c bus, speeds, master and slave.
Ok so I am looking at this eeprom its 512k 400khz/1mhz
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&itemSeq=111909704&uq=634671677330153641
What im wondering is basically how do you ensure your chip is communicating at the top speed in this case 1mhz. From the data sheet it looks like as long as it is at a constant 2.5 to 5.5 volts it will operate at 1mhz? So can i power it with a 3.3v regulator or does that mean the low signal has to be 2.5v and the high 5.5v? Do the pull up resistors have any bearing on frequency? One of the eeproms data sheets that parallax sells says to use a 10k resistor instead of 10k when operating at 1mz.
Also when chaining things on the i2c bus how is this done. I looked at a gadget gangster board that has a spot for an extra eeprom. Its wired the same as all the parallax stuff. There are two eeprom slots that are wired in parallel in the same manner as all the other standard schematics except the slaves(2nd eeprom) A0 pin is connected to the 3.3v power, instead of ground. Can someone explain to me why you would hook the address pin of the slave to the power, if you were to put a 3rd chip in parallel where would you stick its a0 pin?
Im just trying to basically get two eeprom chips wired correctly which im assuming the GG prop board does the right way, but i want to make sure they are operating at 1mhz too, I want to get the fastest infastructure i can for the memmory, i mean i read the read on eeprom can be like 5ns when at 1mhz now thats super fast and will ensure any data stored there will be super quick.
Different I2C devices have to have unique addresses. The An pins allow you to specify an address for the device. Most devices allow for a default address of 0 if no address pins are connected or they're connected to ground (Vss). Typically a 2nd device will have address 1 and its A0 address pin is connected to Vdd to make this so. If you want additional devices, you connect the address pins to create the addresses you want. Usually they're sequential. Note that there are additional address bits for different kinds of devices so there can be an address 0 for an EEPROM and an address 0 for a real-time-clock and they're unique and separate.
Like I said, the actual speed depends on the code you use. Something like the "Basic_I2C_Driver" object that's written in Spin won't get anywhere near 400kHz. My assembly driver that's used in FemtoBasic and other objects will run a bit faster than 400KHz at best since the code is written to allow for a variety of I2C devices and the generality slows it down. You could write your own routines in assembly that could easily run at 1MHz, but they'd need to be written specifically for use with EEPROMs.
Now as far as addressing im assuming you would do all ground master A0 power, slave 1, a2 power only slave 3, up to i guess all A pins connected to voltage would be 7? 1+2+3, basically conect the pins and count the address in binary, i.e a0 and a2 have power would be address 4?
