Source for 17 Segment LEDs
blittled
I need to find a vendor for the 17 segment LEDS similiar to the ones on the PPDB. Sparkfun sells single common anode ones but the ones on the PPDB are common cathode. I can use single or double displays. Thanks!
http://www.mouser.com/Optoelectronics/LED-Displays/_/N-6j73g?P=1z0yqgtZ1z0j22y&Keyword=16+segment+LED&FS=True
You will want to search for 16 segment LEDs, the 17'th is the decimal point.
Jim
I'll probably get the ones from Mouser or just use 7 segment displays since that only requires 1 MCP23S17. If I do use the common anode ones from Sparkfun I'll have to add a 2N3904 transitor to switch on each display.
