PLC controlled lighting system with PIR's
I have come up with a project to upgrade the lighting system for a building, whereby the lights will be switched on by PIR's which will act as inputs into a PLC (mistsubishi FX1S). Programming the PLC i should be fine with, but I am struggling with how to integrate the PIR output with the PLC. I also need to figure out how to activate the lights, im guessing to have the plc to activate a relay to bring in the supply to the lights within the room for that PIR.
If anyone could help me figure a solution I would be most grateful.
Hi phil,
That is one of the thing I need asisstance with, I am wondering is there better suited PIR's to utilise with the PLC?
2. Commercial motion sensors: Run from 24VDC. Have relay outputs compatible with PLC inputs. Come fully-enclosed.
This is not to say that Parallax's PIR would not work. But it would require the addition of a voltage regulator, driver, and either a relay or optoisolator to be compatible with your PLC. Then you'd have to rig up an enclosure for it.
'Didn't mean to cast Parallax's PIRs in a bad light with my comparison, only to point out that to "industrialize" them, i.e. to make them compatible with a typical PLC and provide environmental protection, will require some additional parts and effort. A PLC interface is a bit different than the three-pin servo-type interface we Parallaxians know and love.
