AVR and FPGA knowledge request?
Ok, i have been sick + college = no time to do anything
now i am about to order a new batch of parts inculding 3 props and one wdc65c02 and a few atmegas
here is the problem
i want to start with FPGAs and what i need to do that i cant figure out.
i started with the propeller with the serial to prop adapter as its cheap and easy.
and the prop to write a program for it easy just download the proptool IDE!
well i decided to ask you guys for advice.
what to use to get started easy and cheap on atmegas and FPGAs
oh why FPGAs well i made some interesting stuff in LOGISIM (wich is a good digital circuit simulator)
and i want to make it real
here is a peice of my CPU i am making
alu core unit2.zip
it opens with logisim
i intend to make modular sub componet CPU with a seperate command core ALU and memory maneger. so i can then use ramchips or registers as system registers and make the CPU scalable if you open this please note the way my X an Y registers are configured they can be functioned together or either can be functioned against a ram byte and the intended scheme is paired ram banks with automatic tracking of which byte has an instruction i am still working out the details of my command core and how to scale the register memory. pretty fun eh?
now if any of you want to help YAY thanks big thumbs up and plus i will make sure to include thanks in my code. thats all i can do for you if you help.
here is the problem
alu core unit2.zip
Best bet, try one of the FPGA vendor forums for help.All the vendors are into doing synthizable cpu's so that's where the expertise is.
A good starter place for FPGA is the Lattice MachXO2 Breakout Board. (LCMXO2-1200ZE-B-EVN) just $29.99
This has a FT2232H - one channel for ISP, and a spare channel for user link.
$30 is pretty cheap
anyone know of a DIY option though i like DIY stuff, i learn better from that.
I've also used this board: http://www.digilentinc.com/Products/Detail.cfm?NavPath=2,400,897&Prod=NEXYS3
If you're interested, I'll sell you one of them for 50% student cost + $5 shipping (the BASYS2 contingent on me finding it...). I've had a bunch of fun developing on FPGAs, but it's difficult for me.
is there any FPGAs on DIPs that are any good?
What do you mean DIY ? - Any Verilog/VHDL you code is certainly Doing it Yourself !!
The Board has 0.1" connectors, so you can integrate into anything you like.
There is nothing in DIP that will swallow a Soft-CPU.
Take a look at the links I provided: they list a student price on the webpage. Usually students can get a significant discount. As far as DIP, unlikely.
I don't know about other FPGAs, but the Digilent boards have IO ports (they call them Pmod connectors) that can be directly wired to a breadboard, and they interface at standard logic levels (IIRC 3.3v).
JMG thanks too i don't mind if the FPGA is not big enough for a whole CPU since it is a modular design i am after (if you want to look at my ALU) a design that will have parts of a CPU on different chips and use ram chips or addressable storage registers for registers. in fact it be awesome just to get started with any level of FPGAs so eventually i can make my own CPU.
but yeah both of you gave great advice. thanks really.
yeah i like to make my own cables and stuff i found some ok looking DIY cables to go from a parallel port to the FPGA but funny enough the person who posted it didnt have anything that he did with it so i am clueless as to what it can do. and the site didn't say how to use it so it could just be trolling.
it is a great way to learn to make all the stuff from scratch needed to use the stuff. or at least its my best way to learn
http://www.customcircuitsolutions.com/cable.html
http://www.pyroelectro.com/tutorials/byteblastermv/schematic.html
and one question what level of logic can a macrocell emulate? one gate or an advanced function?
anyone got some good suggestion on AVRs i like the propeller but AVRs can do a lot more in the area of math functions or so i have heard, plus some AVRs are dirt cheap.
i have a hard time discribing my goals i know but thanks for helping me and putting up with this.
or if going for math is a PIC better?
