Robot Arm
I was playing with the OWI robot arm yesterday and decided to start on one from scratch. Built with a handful of cheap 9g servos and leftover plastic from other projects.
http://bit.ly/z6IWVz
The servos are just cycling with a couple of the small servo testers Erco mentioned a while back.
Still not complete... I need another servo to add rotation at the wrist. Besides the small servos, the assembly isn't terribly strong. The whole thing is held together with 3M moulding tape... great for holding "Ranger" on the side of my truck, but it doesn't resist shear force very well.
The arm sections are too long, occasionally catching the servo wires and generally mucking things up.
Working on refining the design in AutoCad. I just about have the solid model of the 9g servo. Once I finish that, the rest should be (fairly) easy.
Hmmm... errands to run for now.
Amanda
Amanda
Come on in, the water's fine! http://forums.parallax.com/showthread.php?137471-Arm-Wrist-Gripper-Uses-9-gram-servos&p=1074060&viewfull=1#post1074060
I just received the latest ROBOT magazine with my arm construction article in it, FYI. Still have some code to finish for their web site.
I used Lego turntables additional pivot connections when I made my popsicle stick hexapod. I thought it helped strengthen the joints a lot.
Dragged out the bench power supply, set to 9.5 vdc. Now we're getting somewhere. The servos just snapped into position. Excellent... at least till the 3M tape gave up the ghost. :-{
Replaced all the connections with fresh tape and the assembly lasted for about another half-dozen cycles. Seems to be too much flex and twist for the 3M.
Gotta update the arm sections and bolt them to the servo horns.
I love this stuff!!!!
Amanda
Interesting tho' about your servos running at 3.6v. Hafta experiment a bit.
