Eerpm write going wrong — Parallax Forums
Igor_RastIgor_Rast Posts: 357
edited 2012-03-03 08:07 in Propeller 1
Can anyone tell me wht this code after a power up the program locks up
I want to save the tempmin to the eeprom so with power out next power on the data is still there
What Am I overlooking ??
PUB getTemperature
  ow.reset                                              ' send convert temperature command
  ow.writeByte(SKIP_ROM)
  ow.writeByte(CONVERT_T)
  repeat                                                ' wait for conversion
    waitcnt(cnt+clkfreq/1000*25)
    if ow.readBits(1)
      quit
  ow.reset                                              ' read DS1822 scratchpad
  ow.writeByte(READ_SCRATCHPAD)
                                                        ' read temperature
  temp := F.FDiv(F.FFloat(ow.readByte + ow.readByte << 8), 16.0) ' convert to floating point
  temp1:=f.FRound(f.fmul(temp,10.0))               {integer valvue of temp}
  if tempmin == 0
     rom.readLong($4000)
       if tempmin == 0
         tempmin:=temp1
  if temp1 > tempmax
    tempmax := temp1
  if temp1 < tempmin
    tempmin := temp1
    rom.writeLong($4000,temp1)
    edited 2012-03-02 18:53
    Which object are you using for "rom", how big is your EEPROM, and from where did you obtain the $4000 address? It would probably b e best to attach an archive of your entire program.
  • T ChapT Chap Posts: 4,249
    edited 2012-03-02 19:47
    Regardless the eeprom size, if there is only ONE eeprom and rom.writelong is affecting it, the eeprom location $4000 is not ideal to be using for a storage location. However on first programming the eeprom, it should run unless there is another problem. Stack size is often a crash culprit.
    When you say it crashes on power up, is that AFTER the eeprom has already been programmed.... and the eeprom has had a value stored in $4000... and THEN you reboot?
    edited 2012-03-02 22:19
    To go along with what Phil and T Chap are asking, what size is your EEPROM?
    I frequently see (and use) the locations starting at $8000 for storing data to an EEPROM since $8000 is the start of the upper half of a 64K EEPROM chip.
    There's a link in post #3 of my index to a program that will determine if your EEPROM is 32K of 64K (in case you're not sure of its size).
  • Igor_RastIgor_Rast Posts: 357
    edited 2012-03-03 03:51
    ok , im using a 256 kb eeprom from microchip technologies. and like T chap said the program crashes after the on power up after the eeprom already has been programed, and the first program does runn .
    datasheet
    http://ww1.microchip.com/downloads/en/DeviceDoc/21203R.pdf
    schematic
    about the $8000 location , this value I found around in some post , I don't realy understand the ram locations completly . so that is probably the problem
    wich value is good to store I don't know
    wanting to store 3 long values to be safe after power op.
    hope I get the good advise
    CON
       _clkmode = xtal1 + pll16x
       _xinfreq = 5_000_000
      buton1 =9                    {input buttons }
      buton2 =10                    {input buttons }
      buton3 =11                    {input buttons }
      buton4 =12                     {input buttons }
      RS = 0                         {lcd control}
      RW = 1                         {lcd control}
      E  = 2                         {lcd control}
      DBLow  = 3                      {lcd control}
      DBHigh = 6                      {lcd control}
      CR  = 13
      LF  = 10
      PSTClearScreen = 16
      tempsensor = 14
      SKIP_ROM          = $CC                               ' 1-wire commands
      READ_SCRATCHPAD   = $BE
      CONVERT_T         = $44
      CLS               = $00                               ' clear screen
      HOME              = $01                               ' home
                                   ' carriage return
      DEG               = $B0                               ' degree symbol
       #8, BKSP, TAB
    VAR
    long stack1[128]        ,idx,tc
    long temp,temp1,tempmax,tempmin,ph,delta_ph ,kk ,gg
    byte messageBuffer[50]
    byte  nstr[64] ,h_menu
    OBJ
      ow            : "OneWire"
      fp             : "FloatString"
      f             : "FloatMath"
      LCD : "LCD_20x4"
        rom: "I2C_ROMEngine.spin"
    PUB main
    dira[pomp1]~~
    dira[pomp2]~~
    dira[buton1]~                                                         {make button input}
    dira[buton2]~                                                         {make button input}
    dira[buton3]~                                                         {make button input}
    dira[buton4]~
    cognew(Monitor,@stack1)
    LCD.Init( E, RS, RW, DBHigh, DBLow )                            {LCD init}
    LCD.usDelay( 5_000 )                                            {LCD init}
    LCD.Clear
      h_menu:=  1                                           {Set LCD to home menu}
      repeat
         if ina[buton2]==0                           { down scroll button}
            h_menu:= h_menu + 1
            if h_menu == 4                            {menu size = 3}
              h_menu := 1
            waitcnt (clkfreq + cnt)
        if ina[buton3]==0  and h_menu == 1                                  {enter submenu2 }
            waitcnt (clkfreq / 2+ cnt)
            tempmax:=temp1
        if ina[buton3]==0  and h_menu == 2                                  {enter submenu2 }
            tempmin:=temp1
        LCD.RawSetPos( $00 )                            {set lcd position}
        LCD.PrintStr( String("Temperture"))
        LCD.RawSetPos( $0B )                               {set lcd position}
        LCD.PrintStr(fp.FloatToFormat(temp, 4, 1))         {float to sting}
        LCD.PrintStr( string(" C" ))
        LCD.RawSetPos( $40 )                            {set lcd position}
        LCD.PrintStr( String("maximaal"))
        LCD.RawSetPos( $4B )                               {set lcd position}
        LCD.PrintStr(decx(tempmax,3))         {float to sting}
        LCD.RawSetPos( $14 )                            {set lcd position}
        LCD.PrintStr( String("Minimaal"))
        LCD.RawSetPos( $1f )                               {set lcd position}
        LCD.PrintStr(decx(tempmin,3))         {float to sting}
       case h_menu
             1:
                LCD.RawSetPos( $55 )
                LCD.PrintStr( string("Max" ))
             2:
                LCD.PrintStr( string("Min" ))
             3:
                LCD.PrintStr( string("Set" ))
      waitcnt(clkfreq + cnt)
    PUB Monitor
      rom.ROMEngineStart(29,28, -1)
      ow.start(tempsensor)                                            {temp sensor start}
      waitcnt(clkfreq / 4 + cnt)                                      {Ph sensor start}
     repeat
        getTemperature                                                 { Get Temp Reading}
    PUB getTemperature
        if ow.readBits(1)
          quit
                                                            ' read temperature
           if tempmin == 0
             tempmin:=temp1
      if temp1 > tempmax
        tempmax := temp1
      if temp1 < tempmin
        tempmin := temp1
    DAT
    endCmd        byte "E", 13, 0
    readCmd       byte "r", 13, 0
    continuousCmd byte "C", 13, 0
    tt            byte  "2","5",".","5",13,0
    temp2         byte
    PUB decx(value, digits) | div
    '' Returns pointer to zero-padded, signed-decimal string
    '' -- if value is negative, field width is digits+1
      clrstr(@nstr, 64)
      digits := 1 #> digits <# 10
      if (value < 0)                                        ' negative value?
        -value                                              '   yes, make positive
        nstr[idx++] := "-"                                  '   and print sign indicator
      div := 1_000_000_000                                  ' initialize divisor
      if digits < 10                                        ' less than 10 digits?
        repeat (10 - digits)                                '   yes, adjust divisor
          div /= 10
      value //= (div * 10)                                  ' truncate unused digits
      repeat digits
        nstr[idx++] := (value / div + "0")                  ' convert digit to ASCII
        value //= div                                       ' update value
        div /= 10                                           ' update divisor
      return @nstr
    PRI clrstr(strAddr, size)
    ' Clears string at strAddr
    ' -- also resets global character pointer (idx)
      bytefill(strAddr, 0, size)                            ' clear string to zeros
      idx~                                                  ' reset index
    esentialy what this code needs to do is :p
    1 read the temp value and display it on lcd ( working complete )
    2 remember what value was the highs temp value and store it to tempmax ( must be saved to eeprom not to get lost on powerup, max value doing what is needs to remember , only not at power out)
    3 remember what value was the lowest temp value and store it to tempmin ( must be saved to eeprom not to get lost on powerup ,min value doing what is needs to remember , only not at power out))
    4 set an offset value ( must be saved to eeprom not to get lost on powerup)
    hope I make myself clear
    1024 x 820 - 178K
    ssss.jpg 178.3K
    edited 2012-03-03 06:10
    Using the Propeller Tool, Press F8, then if not already showing the HEX info, press SHOW HEX. Scroll down and you can see where there are values other than 0 which are used in the Eeprom. Go to the blue section, and you can use any address there in blue. For example, the last row is a good place to write, which starts at $7FF0 and that row runs all the way to $7FFF. So you can use $7FF0 if you want. Keep in mind every time you program the Propeller(the eeprom), the values you have written will be gone until your program puts the temp back again.
    edited 2012-03-03 06:34
    ok so I understand the memory map
    but what's wrong with my code, because it still doesn't remember the value at powerup
    PUB getTemperature
        if ow.readBits(1)
          quit
                                                            ' read temperature
        if tempmin == 0
           rom.readLong($7FF0)
           if tempmin == 0
             tempmin:=temp1
      if temp1 > tempmax
        tempmax := temp1
      if temp1 < tempmin
         tempmin := temp1
         rom.writeLong($7FF0,temp1)
    so the rom.readLong($7FF0)
    and the rom.writeLong($7FF0,temp1) folowed by a temp1:=f.FRound(f.fmul(temp,10.0)) to restore the value in temp1 because what you sugested it gets lost
    it's getting me crazy :p
    edited 2012-03-03 06:51
    Gets lost? What is the value that is coming back?
    For a test, forget about your full code. Write a test method that writes a value ie 7 to the location, then read the location and show the result that is currently in the eeprom address.
    Also, it is a good practice to not have code hard left, only the PUB, VAR, OBJ, designators. DAT is ok to have declarations hard left
    edited 2012-03-03 07:23
    Igor_Rast wrote: »
    Take a look at the PEK sticky at the top of the Propeller forum. There's an EEPROM data logging lab that shows you how to same variables to EEPROM. A very common way to do this is to just use the same EEPROM address as the variables' RAM location.
    I think you're making this harder than it needs to be.
    edited 2012-03-03 07:42
    I am not familiar with the i2cromengine. I use MinimalI2Cdriver and the following example to read/write eeprom.
    PUB WriteTempLow
        WritePage(eeprom1, $F100, @TempLow, 4)    '  1 =byte. 2=2word, 4=long
    PUB ReadTempLow
        ReadPage(EEPROM1, $F100, @TempLow, 4)
    PUB WritePage(devid, address, pointer, count)
        i2c1.i2cWritepage(28, devid, address, pointer, count)
        waitcnt(clkfreq/200 + cnt)
        i2c1.i2cstop(28)
    PUB ReadPage(devid, address, pointer, count)           'boot eeprom $A0
        i2c1.i2cstart(28)
        i2c1.i2cReadPage(28, devid, address, pointer, count)    '$7000test
        i2c1.i2cstop(28)
        return  pointer
    Not sure in the case of your i2c object, but in my example it is required to pass the address of the variable with@, not just using the var itself.
    Thanks for the advice guy's
    I Got it working , thnx
