APRS
Dear all
I found some APRS/AX25 code here based on Phil Pilgrim's Bell 202 modem:
http://forums.parallax.com/showthread.php?136334-Parallax-Propeller-Near-Space-Balloon&highlight=aprs
I have the code running but it does not sound like AX25 neither does it sound like Phil's modem. The idle tone is different and the burst is shorter - data rate sounds too high. Has anyone else got anywhere with this software?
I am trying to implement an APRS beacon.
Regards
Richard
G3CWI
Regards
Richard
G3CWI
Regards
Richard
G3CWI
The APRS object left by :
' SUNSET
' Stellenbosch University Near Space Engineering Testbed
' 26/09/2011
' Alex Erlank
...did not work straight out of the packet (!) I suspect that Alex deposited a non-working beta cut by mistake. However with a lot of head scratching and remote diagnostics (using the APRS network itself as a simple debug method), I now have a working object. Alex's code did a lot of stuff that didn't need to be there in my application so I have stripped a lot of things out and tidied things up. I also commented the code. My code is very basic but works just fine.
I can think of lots of nice enhancements.
Regards
Richard
G3CWI
APRS OBJECT.zip
Sorry that the code wasn't more user friendly. At the time there were a few people who were interested in the code so I posted what I had as soon as I got something working. I ended up using APRS to track a near space balloon. Thanks for cleaning up the code! Post it in the OBEX when you feel it is neat and reliable enough. Took me a long time and a lot of troubleshooting to get working initially!
Regards
Alex
Thanks for sharing it. You had inadvertently disabled the GPS Mini Code which took some tracking down! I have stripped out the GSM, Video and sensor parts and removed the Config file. I also tidied up a few bits (cosmetic only). It makes APRS a really easy weekend project.
Any further balloon launches in the offing?
Regards
Richard
G3CWI
Justin
