Eerpm write going wrong
Can anyone tell me wht this code after a power up the program locks up
I want to save the tempmin to the eeprom so with power out next power on the data is still there
What Am I overlooking ??
PUB getTemperature
ow.reset ' send convert temperature command
ow.writeByte(SKIP_ROM)
ow.writeByte(CONVERT_T)
repeat ' wait for conversion
waitcnt(cnt+clkfreq/1000*25)
if ow.readBits(1)
quit
ow.reset ' read DS1822 scratchpad
ow.writeByte(READ_SCRATCHPAD)
' read temperature
temp := F.FDiv(F.FFloat(ow.readByte + ow.readByte << 8), 16.0) ' convert to floating point
temp1:=f.FRound(f.fmul(temp,10.0)) {integer valvue of temp}
if tempmin == 0
rom.readLong($4000)
if tempmin == 0
tempmin:=temp1
if temp1 > tempmax
tempmax := temp1
if temp1 < tempmin
tempmin := temp1
rom.writeLong($4000,temp1)
When you say it crashes on power up, is that AFTER the eeprom has already been programmed.... and the eeprom has had a value stored in $4000... and THEN you reboot?
I frequently see (and use) the locations starting at $8000 for storing data to an EEPROM since $8000 is the start of the upper half of a 64K EEPROM chip.
There's a link in post #3 of my index to a program that will determine if your EEPROM is 32K of 64K (in case you're not sure of its size).
datasheet
http://ww1.microchip.com/downloads/en/DeviceDoc/21203R.pdf
schematic
about the $8000 location , this value I found around in some post , I don't realy understand the ram locations completly . so that is probably the problem
wich value is good to store I don't know
wanting to store 3 long values to be safe after power op.
hope I get the good advise
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 buton1 =9 {input buttons } buton2 =10 {input buttons } buton3 =11 {input buttons } buton4 =12 {input buttons } RS = 0 {lcd control} RW = 1 {lcd control} E = 2 {lcd control} DBLow = 3 {lcd control} DBHigh = 6 {lcd control} CR = 13 LF = 10 PSTClearScreen = 16 tempsensor = 14 SKIP_ROM = $CC ' 1-wire commands READ_SCRATCHPAD = $BE CONVERT_T = $44 CLS = $00 ' clear screen HOME = $01 ' home ' carriage return DEG = $B0 ' degree symbol #8, BKSP, TAB VAR long stack1[128] ,idx,tc long temp,temp1,tempmax,tempmin,ph,delta_ph ,kk ,gg byte messageBuffer[50] byte nstr[64] ,h_menu OBJ ow : "OneWire" fp : "FloatString" f : "FloatMath" LCD : "LCD_20x4" rom: "I2C_ROMEngine.spin"PUB main dira[pomp1]~~ dira[pomp2]~~ dira[buton1]~ {make button input} dira[buton2]~ {make button input} dira[buton3]~ {make button input} dira[buton4]~ cognew(Monitor,@stack1) LCD.Init( E, RS, RW, DBHigh, DBLow ) {LCD init} LCD.usDelay( 5_000 ) {LCD init} LCD.Clear h_menu:= 1 {Set LCD to home menu} repeat if ina[buton2]==0 { down scroll button} h_menu:= h_menu + 1 if h_menu == 4 {menu size = 3} h_menu := 1 waitcnt (clkfreq + cnt) if ina[buton3]==0 and h_menu == 1 {enter submenu2 } waitcnt (clkfreq / 2+ cnt) tempmax:=temp1 if ina[buton3]==0 and h_menu == 2 {enter submenu2 } waitcnt (clkfreq / 2+ cnt) tempmin:=temp1 LCD.RawSetPos( $00 ) {set lcd position} LCD.PrintStr( String("Temperture")) LCD.RawSetPos( $0B ) {set lcd position} LCD.PrintStr(fp.FloatToFormat(temp, 4, 1)) {float to sting} LCD.PrintStr( string(" C" )) LCD.RawSetPos( $40 ) {set lcd position} LCD.PrintStr( String("maximaal")) LCD.RawSetPos( $4B ) {set lcd position} LCD.PrintStr(decx(tempmax,3)) {float to sting} LCD.PrintStr( string(" C" )) LCD.RawSetPos( $14 ) {set lcd position} LCD.PrintStr( String("Minimaal")) LCD.RawSetPos( $1f ) {set lcd position} LCD.PrintStr(decx(tempmin,3)) {float to sting} LCD.PrintStr( string(" C" )) case h_menu 1: LCD.RawSetPos( $55 ) LCD.PrintStr( string("Max" )) 2: LCD.RawSetPos( $55 ) LCD.PrintStr( string("Min" )) 3: LCD.RawSetPos( $55 ) LCD.PrintStr( string("Set" )) waitcnt(clkfreq + cnt)PUB Monitor rom.ROMEngineStart(29,28, -1) ow.start(tempsensor) {temp sensor start} waitcnt(clkfreq / 4 + cnt) {Ph sensor start} repeat getTemperature { Get Temp Reading} waitcnt(clkfreq + cnt) PUB getTemperature ow.reset ' send convert temperature command ow.writeByte(SKIP_ROM) ow.writeByte(CONVERT_T) repeat ' wait for conversion waitcnt(cnt+clkfreq/1000*25) if ow.readBits(1) quit ow.reset ' read DS1822 scratchpad ow.writeByte(SKIP_ROM) ow.writeByte(READ_SCRATCHPAD) ' read temperature temp := F.FDiv(F.FFloat(ow.readByte + ow.readByte << 8), 16.0) ' convert to floating point temp1:=f.FRound(f.fmul(temp,10.0)) {integer valvue of temp} if tempmin == 0 tempmin:=temp1 if temp1 > tempmax tempmax := temp1 if temp1 < tempmin tempmin := temp1 DAT endCmd byte "E", 13, 0 readCmd byte "r", 13, 0 continuousCmd byte "C", 13, 0 tt byte "2","5",".","5",13,0 temp2 byte PUB decx(value, digits) | div '' Returns pointer to zero-padded, signed-decimal string '' -- if value is negative, field width is digits+1 clrstr(@nstr, 64) digits := 1 #> digits <# 10 if (value < 0) ' negative value? -value ' yes, make positive nstr[idx++] := "-" ' and print sign indicator div := 1_000_000_000 ' initialize divisor if digits < 10 ' less than 10 digits? repeat (10 - digits) ' yes, adjust divisor div /= 10 value //= (div * 10) ' truncate unused digits repeat digits nstr[idx++] := (value / div + "0") ' convert digit to ASCII value //= div ' update value div /= 10 ' update divisor return @nstr PRI clrstr(strAddr, size) ' Clears string at strAddr ' -- also resets global character pointer (idx) bytefill(strAddr, 0, size) ' clear string to zeros idx~ ' reset indexesentialy what this code needs to do is
1 read the temp value and display it on lcd ( working complete )
2 remember what value was the highs temp value and store it to tempmax ( must be saved to eeprom not to get lost on powerup, max value doing what is needs to remember , only not at power out)
3 remember what value was the lowest temp value and store it to tempmin ( must be saved to eeprom not to get lost on powerup ,min value doing what is needs to remember , only not at power out))
4 set an offset value ( must be saved to eeprom not to get lost on powerup)
hope I make myself clear
but what's wrong with my code, because it still doesn't remember the value at powerup
PUB getTemperature ow.reset ' send convert temperature command ow.writeByte(SKIP_ROM) ow.writeByte(CONVERT_T) repeat ' wait for conversion waitcnt(cnt+clkfreq/1000*25) if ow.readBits(1) quit ow.reset ' read DS1822 scratchpad ow.writeByte(SKIP_ROM) ow.writeByte(READ_SCRATCHPAD) ' read temperature temp := F.FDiv(F.FFloat(ow.readByte + ow.readByte << 8), 16.0) ' convert to floating point temp1:=f.FRound(f.fmul(temp,10.0)) {integer valvue of temp} if tempmin == 0 rom.readLong($7FF0) if tempmin == 0 tempmin:=temp1 if temp1 > tempmax tempmax := temp1 if temp1 < tempmin tempmin := temp1 rom.writeLong($7FF0,temp1) temp1:=f.FRound(f.fmul(temp,10.0))so the rom.readLong($7FF0)
and the rom.writeLong($7FF0,temp1) folowed by a temp1:=f.FRound(f.fmul(temp,10.0)) to restore the value in temp1 because what you sugested it gets lost
it's getting me crazy
For a test, forget about your full code. Write a test method that writes a value ie 7 to the location, then read the location and show the result that is currently in the eeprom address.
Also, it is a good practice to not have code hard left, only the PUB, VAR, OBJ, designators. DAT is ok to have declarations hard left
Take a look at the PEK sticky at the top of the Propeller forum. There's an EEPROM data logging lab that shows you how to same variables to EEPROM. A very common way to do this is to just use the same EEPROM address as the variables' RAM location.
I think you're making this harder than it needs to be.
PUB WriteTempLow WritePage(eeprom1, $F100, @TempLow, 4) ' 1 =byte. 2=2word, 4=long PUB ReadTempLow ReadPage(EEPROM1, $F100, @TempLow, 4) PUB WritePage(devid, address, pointer, count) i2c1.i2cWritepage(28, devid, address, pointer, count) waitcnt(clkfreq/200 + cnt) i2c1.i2cstop(28) PUB ReadPage(devid, address, pointer, count) 'boot eeprom $A0 i2c1.i2cstart(28) i2c1.i2cReadPage(28, devid, address, pointer, count) '$7000test i2c1.i2cstop(28) return pointerNot sure in the case of your i2c object, but in my example it is required to pass the address of the variable with@, not just using the var itself.
I Got it working , thnx
