Battery power VS DC motors
Hi,
I would like to power 4 GHM-04 Lynxmotion Spur Gear Head Motors and controle them via Parallax HB-25 DC Motor Controller.
Is there a formula to know how much amps your battery pack should be able to provide to the motors?
the motor specs are:
- Voltage Operating Range: 6-7.2vdc (this is clear
- Speed at Rated Load (1.0Kg-cm): 146 RPM+/- 10%
- No Load Current at 7.2vdc: < 221mA
- Current at Rated Load (1.0Kg-cm): < 556mA
I guess the more weight the more amps? correct?
Let's say that the robot has a weight of 7kg/using 4 motors, how much amps does the battery pack require?
Any help would be great
Kris
Of course this is all a gross generalization, duty cycle, speed of the platform in getting here-to-there, effienciecy of the drive components all come into play.
