12V Motor controll help!
Hello everyone and thanks for taking the time to look over my problem.
Well I figured its time to start a project so I went ahead and ordered 3 peristaltic pumps that I hope to turn into a aquarium doser. I've been looking around for a way of interfacing them to the prop and have come up with tons of tutorials on servo motors, mosfets, relay boards and all kinds of motor control boards that are out of the price range for this project. So my question to you is....
What is the easiest way to safely control a 12V DC motor that has a max amperage draw of 85mA.
I have a PPDB but I think the max voltage rating for the motor controller on it is 7 or 8 volts iirc. Are mosfets the best way to go for something like this and how breadboard friendly are they? Keep in mind I'm still very new to all of this and this is going to be my first foray into an actual physical project and not just following along a tutorial.
Thanks again, I'll await the advice of the guru's here before I go crazy and start ordering stuff haha.
A 2N2222 transistor turning on a reed relay, turning on a small motor, would work, and is simple and cheap too...
What do you mean by "aquarium doser"?
-Tommy
Ok so I would be safe to use the L293D half H driver on my PPDB then? I would like to order the parts to run all three motors as I plan on using perf board or getting a PCB made after the prototyping stage. I'll look into your suggested method of control, thanks a lot for the input any and all information is greatly appreciated.
My standard recommendation is to use an IRF3708 low threshold MOSFET. The gate can be directly driven by the prop running on 3.6V. (OK, a 1K resister from the prop pin to the gate is prudent.)
Good design would assume the startup current may be as high as 3 times the running current.
So, one could use a 2N2222 NPN transistor with a 430 ohm resister from the prop pin to the base would be about right.
Duane J
@T Chap Thanks for the response I suppose I should have been more specific. I would like to have speed control on the motor in order to more accurately calibrate the amount of chemical being delivered. On off would work but when trying to regulate smaller doses it would advantageous to be able to slow the motor down.
@JonnyMac I think you just nailed it, I'll take a look at that chip and see what else I need to interface it with the prop. One chip takes care of two motors plus speed control, that is perfect for my needs and well within my price range.
Thank you for all your responses.
@Duane The 2n2222 transistor and the Mosfet you mentioned are those two seperate options or do they need to be used in conjuction? Bare with me, I'm a bit slow
Have no fear, the L293D has thermal protection, and has shut down everytime I have "over driven" the poor thing,
At like 2.5 Amps of current, it gets very warm, and then stops working till it cools down...
Just to throw some more gas on the fire, directly below the L293D data sheet link, is another link, to a ULN2803A darlington array,
Sheesh, JonnyMac and Duane are on it, so you are in good hands here...
-Tommy
I recommend reading this thread and using a ULN2803 Darlington array.
http://forums.parallax.com/showthread.php?132760-Using-the-propeller-to-trigger-24v-solenoids&highlight=ULN2803
One chip solution.
Bruce
@idbruce Thanks for the link to that thread thats exactly what I needed to wrap my brain around this stuff.
Thanks to the entire forum, I love this place.
Your welcome.
Yea, besides the occassional bickering amongst the siblings, it is like one big happy family that helps one another
I was so lost this morning when I made my first post and now I have a firm direction and general understanding of what I need to do in order to achieve my goal. Thumbs up!
Separate methods.
The 2N2222A & 430 ohm resister is the smallest.
However, the IRF3708 is my favorite MOSFET that can be directly driven with a prop. This MOSFET is rated for 62A. Read the high current to mean "Low On Resistance" when driven with the relatively low gate drive voltage supplied by the prop.
This graph, which I measured, shows the gate voltage vs. resistance.
Clearly this would drive your motor. And fairly low cost at about $2.
I always have these in my junk box.
There are a few other MOSFETs but I haven't evaluated them enough yet.
Duane J
