Non-Invasive current sensor usage....?
Hello all,
A little help please. I bought a non-invasive current sensor to monitor my home current consumption - http://www.seeedstudio.com/depot/noninvasive-ac-current-sensor-100a-max-p-547.html?cPath=6 with the aim to connect it to a propeller via an ADC.
Connected it up as per http://openenergymonitor.org/emon/node/59 and all I get from my multimeter is 0.1mv and 0.050hz. Tried various burden resistor sizes and no change. I am connecting it around the red mains feed between the fusebox and the meter. Tried without the "dc bias" - same result. The openenergymonitor site seems to imply a voltage output proportional to the current flowing....?
I notice that on its "datasheet" the current sensor model has a internal diode and the voltage sensor has an internal resistor. Mine as a resistance of 100ohm across the outputs - does that sound right?
Any ideas?
James
Any ideas?
James
I nabbed one off Ebay for $30 and it works great as a standalone unit.
James, I just want to make sure noticed from the chart, your model (SCT-013-000) apparently outputs a current proportional to the current flowing. All the other models listed look like they output a voltage.
That datasheet is awful... Wouldn't trust it to be right.
Let's assume its right about the turns-ratio of 1:2000, in which case 100A in gives 50mA out. In that case try a 22 ohm resistor for 1.1V output at 100A input (all rms, of course). This would be 3.1V pk-to-pk.
The "diode" is a bidirectional TVS device to protect the secondary against over-voltage should you leave it output unconnected (CT's have to be connected to a load otherwise they become step-up transformers).
The 100ohms you measure is probably just the winding resistance which is irrelevant to its function.
To get appreciable output voltage for lower input currents you might want to use a higher-valued burden resistor (useful for testing/calibration?) 220ohms for instance.
Make sure your multimeter is on AC voltage setting.
Gives a nice range.
I think the main trick was to use the multimeter on AC voltage - DOH! Also its wasn't 0.050hz, but 0.050khz.
Thanks again for your help!
A little more help if I may...!
Reading an AC voltage with a ADC... I appear to have two options:
(a) Filter the signal to be 0-2.5V AC and DC bias it on 2.5vdc so that I get a 0-5 volt sine wave centered at 2.5vdc. Then pick the biggest point on the wave as my voltage
(b) Rectify the AC signal to DC, which means I can have a 5vac signal as a 5vdc signal so I get better range. Problem is how to account for the "upto 1.1v" diode drop, as I don't want to scope the AC signal to run 0-6vac then find it turns into anything from a 4.9vdc to 5.5vdc signal and blow the ADC?
If (b) is the better option, can somebody recommend a recifier IC or the best approach? (max 6vac and 50ma required)
James
