Can anyone point me to a spin object to output x pulses over a period of y seconds?
TIA David Young
TIA David Young
You don't really need an object for this, it can easily be accomplished with a watchdog cog, a REPEAT loop, and WAITCNT or you could use a timer for PWM. If you are really looking for an object, search the OBEX for PWM.
Bruce
Application Notes with sample code and excellent documentation.
http://www.parallaxsemiconductor.com/an001
Forum sticky - scroll down to PE Kit Tools -> Transmit Square Wave Frequencies
Propeller Education Kit Labs, Tools,·and Applications
Here's a link to a post with code I use to flash LEDs.
This is the method that does all the work.
PRI LedFlash '' Runs in its own cog. repeat repeat result from 0 to _HighestLedPin ' check each pin if active[result] == _Deactivate ' should pin be deativated? outa[result] := 0 dira[result] := 0 if active[result] == _Active ' is pin active? dira[result] := 1 if state[result] == _Off if cnt - time[result] > offInterval[result] ' has pin been off long enough? time[result] += offInterval[result] state[result] := _On outa[result] := 1 else if cnt - time[result] > onInterval[result] ' has pin been on long enough? time[result] += onInterval[result] state[result] := _Off outa[result] := 0 if count[result] <> -1 if --count[result] =< 0 ' decrement count if not -1 active[result] := _Inactive dira[result] := 0The object lets you any number of the IO pins. I wrote this so I could flash multiple LEDs (up to 32) at different rates using one cog. Since it's written in Spin and test each pin to see if it's an active pin, it's relatively slow (but fast enough for flashing LEDs).
The object I linked to lets you set the on time, off time and how many times you want the LED/pin to turn on and off. It should be easy to modify to use time as a parameter instead of the number of pulses.
Let us/me know if you need help converting it to your needs (assuming it's fast enough for the pulses you want to make).
Here is a quick and easy example of using a timer.
CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 PUB SetThePulse | PulsePin, Second, Minute, HighTime, LowTime, Counter PulsePin := 1 'This is the IO pin which will send the pulse Second := CLKFREQ Minute := Second * 60 HighTime := CLKFREQ 'Establish high time using CLKFREQ, Second, Minute, or a combination 'of all of these with the proper operators. LowTime := CLKFREQ 'Establish low time using CLKFREQ, Second, Minute, or a combination 'of all of these with the proper operators. 'Can anyone point me to a spin object to output x pulses over a period of y seconds? 'Without further input from you, we will assume that you can determine the proper math. 'But in this example, we have assumed high pulse width of 1 second and a cycle offset 'of 1 second. And in this example, Pin #1 will go high 10 times over a 20 second period. CTRA[30..26] := %00100 ' Configure Counter A to NCO CTRA[5..0] := PulsePin FRQA := 1 DIRA[PulsePin]~~ Counter := CNT 'Get the current clock count REPEAT 10 PHSA := -HighTime WAITCNT(Counter += LowTime)
