BS2 Code for motion LED project
I'm creating a project that LED striplights are trigger by motion sensors. I have the code posted below. The problem I'm seeing is that it seems that when one sensor is triggered to light the LEDs and if a second sensor is triggered within the same time frame of the first sensor being triggered, the second motion is ignored until first sensor is off.
What I would like to happen is if one sensor is triggered, it lights that set of leds and at the same time if a second sensor is triggered it will in addition light the second set of leds at the same time.
' {$STAMP BS2}
' {$PBASIC 2.5}
' {$PORT COM9}
' +++[Defining I/O ]++++++++++++++++++++++++++++++++++++
'Input from motion sensors trigger LED pin high to Gate of individual Mosfets tied to LED strips.
'StepSen1 PIN 15 ' Lower level steps motion sensor
'FoyerSen PIN 14 ' Foyer motion sensor
'StepSen2 PIN 13 ' Upper level steps motion sensor
'BathSen PIN 12 ' Outside half-bath motion sensor
'HallSen PIN 11 ' Hallway motion sensor
StepLED1 PIN 9 ' Lower level steps LED
FoyerLED PIN 8 ' Foyer LED
Stairs2LED PIN 7 ' Upper level stairs LED
HallwayLED PIN 6 ' Hallway LED
Hallway2LED PIN 5 ' Hallway/Loft LED
Main:
PAUSE 3000
DO
DEBUG BIN1 IN15
DEBUG BIN1 IN14
DO
LOOP UNTIL (IN15 = 1 )
HIGH StepLED1
PAUSE 5000
LOW StepLED1
DO
LOOP UNTIL (IN14 = 1 )
HIGH FoyerLED
PAUSE 5000
LOW FoyerLED
DO
LOOP UNTIL (IN13 = 1 )
HIGH Stairs2LED
PAUSE 5000
LOW Stairs2LED
DO
LOOP UNTIL (IN12 = 1) OR (IN11 = 1 )
HIGH HallwayLED
HIGH Hallway2LED
PAUSE 5000
LOW HallwayLED
LOW Hallway2LED
PAUSE 1
LOOP
Jim
would I connect the output pin of the stamp to the trigger?
