Dying Monitor
My desktop monitor is getting dimmer and bluish. CCFL dying or inverter? Is it worth fixing? Has anyone tried? I found this site with info: http://www.lcdparts.net/DI3D.aspx
That sort of thing happens as you grow older. Other people start to seem smarter and appear to move and talk faster, too. It's best you just accept it as a natural process of an aging brain. I strongly suggest reading (while you still can) the book to which I've linked below. It will help you understand what's happening to you as you gradually lose your senses. There there... There there....
http://www.amazon.com/Man-Who-Mistook-His-Wife/dp/0684853949/ref=sr_1_1?s=books&ie=UTF8&qid=1330233473&sr=1-1
I have since learned that bad caps are a common cause of death with monitors.
I don't know if bad caps would cause a dim blue screen, but the capacitors are cheap and not too hard to replace.
Man, how I wish I could go back in time and not post this ridiculous question. Makes me think ElectricEye is on to something. Now why did I come in this Forum? What did I need? Did I forget to remember or remember to forget?
At least I discovered the problem before I tore down my perfectly functioning monitor.
I would not have found that problem in a million years! I would have "assumed" the monitor connection was good!
But that goes back to troubleshooting 101, first things to check... Is it plugged in? Do you have power? ....
And now is the video connector securely connected?
What type of connector? VGA? DVI?
