Solar panel deicer
On a lone mountain top in the middle of nowhere there is a tower that happily relays microwave radio signals to bring the joys/horrors of the internet to those who would have to do without.
This tower runs with solar power.
Issue: Snow and ice obscure the panels and the battery bank dies. It's not good for the batteries, or rural facebook addicts who tie up my friend's phone lines.
Solution: Build a robot! er... an automated panel deicing/cleaning solution.
I've used a lot of micros including the apparently infamous xcore. A chip that I have a number of and have never really used beyond playing with them is the Propeller. I wanted something that was easy to modify for him if he cared to tweak it so the Propeller it is.
I have to... well spin up on SPIN but I'm a CE. that doesn't bother me.
The question I would like to ask is more of a solicitation of ideas on how to deice the solar panels without using too much power. This is in the middle of nowhere and with the kind of snows they get near there you're not getting to the tower without climbing gear and a dog sled or a snowmobile of which he owns neither. I considered some kind of plexiglass cover on top that opens or shakes to knock stuff off but that involves too many moving parts. The idea that seems to have the most merit at the moment is a pump and nozzle system to spray an environmentally friendly deicing solution on the panels when certain conditions are met such as a bright sunny day but the panel output is low. There is a small wind turbine but even that freezes up at times.
I've been reading over posts and there are some sharp people here. I'm hoping someone can help me figure out some alternative methods of clearing off the panels.
So the conditions are:
- Power restricted so no dumping a lot of amps through heaters unless it can be done efficiently
- Assume things like freezing rain and five feet or more of snow.
- Simple and robust.
Harprit.
Oh and never say never about snow on vertical surfaces. I've seen times when it looks like everything has been powder coated.
I've seen scenes very similar to this up there.
In addition mount an extra panel oriented for the warm season.
Use a good quality MPPT charger on each panel. Redundancy is a good thing. Talk to MorningStar, and others, for severe environment chargers.
Mounted vertically they shouldn't retain much snow. Ice is a different problem but that doesn't effect power output as much.
We have used the thermal solar heater panels suggested by Harprit. This works well but you still need triple redundant panels.
Don't forget about the lightning protection.
Duane
Lawson
Vertically mounted solarpanels will not compleately solve the problem but I guess it will help a lot. Even a high altitude summer sun will still charge the batteries enough. What about adding more batteries to the bank? Find a better wind charger, perhaps?
We have a few similar repeater stations around here, solar panels is not an issue at all because of no effect of the sun from november to january. So its based on wind chargers only. We have faced a few wind charger breakdowns because of too hard conditions. We are now trying a wind wane that is specially made for rough environment and look forward to see how it will survive the coming winter.
Covering the solar panels with additional transparent material is likely to cause significant drops in efficiency
About the only other thing I can think of is washing the panels in a warmed solution of ethylene glycol - that's how they de-ice airplane wings. But that is a rather messy alternative and putting in a winter's supply of the solution might be rather difficult. Warming it may just waste more electricity than it is worth.
These panels need to be setup so their load is connected through a relay so it can be taken offline and wired in parallel to the other panels output so the relay station can say online 24/7.
If, you don't want to the more panels. Then, I will use heat trace that is attached and laying in figure eight pattern on top of the panels.
Again, this isn't my tower so minimizing any alterations to the current setup is key.
- windshield wipers
- de-icing fluid
- electrical heating
- backup generator
- propane gas warmer to melt snow and ice
- roof used during winter when sun is low in the sky, and retracts during the rest of the year
- bottom side of the roof could be shiny sheet metal and angled to reflect more sunlight on the panels
- enclose the panels in a shed with the south side open
I'm not up to speed on solar panels, so I was wondering, do they generate some % of their capability with reflected light versus direct light? If so, then in winter you could face the panels at a downward angle and they could use sunlight reflected off of snow cover and then point them toward the sun the rest of the time. At night, they could "go to sleep" pointing downward in case of overnight snows.
The only problem is with any of the moving panel solutions, you are using a lot of energy to motivate the panels.
Here are a couple of photos from the Sierra in California (from video, ucmerced.edu/CZO/research)
These are small panels, but the equipment inside (snow depth and and weather logger) does not require much current. The battery can be sized for two weeks without solar power. It has was a problem at first due to lack of control of placement in a forested area.
I agree about vertical or near vertical placement, if possible. Panels that have any kind of rim or bump (like the one in the photo) hold snow longer than a flat surface. There are small rimless panels build on a flat aluminum plate that are better in this respect.
Has anyone suggested a year's supply of explosive charges on the back of the panel? Well, how about a large pager motor?
About ethylene glycol... It has a sweet smell that can be very enticing to bears.
I have also connected my Deicing cable to an Aviosys 9258, which allows me to deice my panels from any computer or my cell phone. Of course I have CCTV to check on the snow on the panels too!
The 100' of deicing cable from Home Depot cost about $100, and a roll of 2" foil tape was another $20. Of course the time (labor to install) is another thing!
