Broadcast USB to Serial device over UDP (or other method) using Propeller
I have no idea if this is even possible, but I need a way to connect a usb device using an FTDI usb to serial chip, read the data in, and retransmit it over another medium such as bluetooth, network, etc. Does the propeller even have a way to connect to a usb host device? In doing research I came across an Arduino Usb Host module which I have considered using as well. This will eventually be used for mass production so it needs to be easily reproducible with readily available parts. Does anybody have any ideas/suggestions? I am posting this on the propeller forums because I have a PPDB and a propeller protoboard at my disposal to put together a prototype of this. Thanks in advance for any suggestions!
Russ
Edit:
After some research I have found that this likely isn't going to be possible with the current state of usb support on the propeller. If anybody has any idea's I'm still open to them, however I am looking into a different solution.
Russ
Edit:
They have a bluetooth module, but I haven't tried it yet...
I think you could also use the regular ethernet chip ENC28..something and connect it with wire to a wifi endpoint adapter. I think Parallax sells one of these...
I'm guessing this is a typo. You want the Propeller to be the USB host, right? If so, then yes, this will be hard.
What device do you want to connect to the Propeller?
The Vinculum chips can act an USB host for some devices.
Do you have a link to the Arduino USB Host module? That sounds interesting.
I've played around with the VNC2 a bit and things like keyboards and mice (HID) are pretty easy to get going...
Is UDP required?
What is the distance required?
Since this is obviously commercial, what licence would it operate under?
There are ZigBee modules, Bluetooth modules and WiFi modules available and all can be purchased with serial or SPI interfaces.
Micah has done a non-compliant USB Bluetooth interface that works on the prop. But it does use 3 or 4 cogs. And it works with some $1.50 bluetooth USB sticks. I am unsure whether it could be recoded to use less than 3-4 cogs.
