Sample code for temperature from Gyroscope Module 3-Axis L3G4200D (#27911)
Does anyone have any sample code for reading temperature with the Gyroscope Module 3-Axis L3G4200D (#27911)?
I have it set up and working, but I have no idea how to read the temp - The sample code on the product page shows X Y and Z readings - I'm looking for a simple temp reading from a BS2.
Does anyone have something to share?
Anyone???
This is the only sensor / product that I have ever purchased from Parallax that does not have sample code or examples on how to use one of it's features...
I attempted the following code on a whim (It's really just taking the sample code and plugging in OUT_TEMP instead of OUT_X_INC in the code.
I get numbers returned, but they are very low numbers (10-20) and I have no idea if I'm on the right track or if I am, how to convert those numbers to a temperature scale for degrees C or F...
There has to be someone out there that has read temp from one of these, Right
Parallax??? Can you help with a piece of example code?
Just curious...
Jim...
I was searching through the web for this issue, I found a chip (Triple-Axis Digital-Output Gyro ITG-3200)which is a different chip but does the same thing as yours. In the post it was stated on how to retrieve the temperature information.
{One person asked the following:}
Gyros work great. I like the built-in filtering options.
Heads up for me it came set to use the alternate I2C address (0x69) instead of the default (0x68).
Has anyone gotten good data from the temperature sensor? Im getting values around -16,000, at room temp=/.
{The reply was:}
The description above mentions that they pulled AD0 high, so 0x69 is the expected address.
Then see Table 3.1 in the manual. -13200 represents 35 celsius, then every 280 from there is another degree celsius. (Admittedly a bit confusing to decipher from the table).
So code would look like:
tempC = 35.0 + ((rawVal + 13200)/280.0);
Also note that you divide the gyro values by 14.375 to get degrees per second.
I mention all that to say is that I went to the PDF (27911-GyroscopeAppNote2) listed for Parallax's chip and it
states the following under section 7.
7 Temperature sensor
The L3G4200D is provided with an internal temperature sensor that is suitable for delta
temperature measurement. Temperature data are generated with a frequency of 1 Hz and
are stored inside the OUT_TEMP register in twos complement format, with a sensitivity if -1
LSB/°C.
So I'm thinking that you have to retrieve that termperature information from the OUT_TEMP register. I"m not a programmer, but maybe this can give one a hint to get the proper code syntax to retrieve that data.
I hope that helps in some way.
I found a datasheet with more info on the chip/temperature.
Look at the attachment go to page 34 (or search for table 30 and/or table 40)
Look at table 39 & table 40. It lists the registers for temperature.
Edit: I had originally put spin code sorry!
Edit: added corrected code to read temp and gyros 2/22
Thanks so much for looking at this for me!
I ran your code and I'm getting the same results as I got in the last code that I posted.
Currently it is 79 degrees F in my office, and the numbers I am getting with both my code and your code fluctuate between 11 and 13.
This is obviously not Degrees F or Degrees C (With 11,12, and 13 it would directly convert to 51.8, 53.6, or 55.4 Degrees F) - , and I don't see a logical formula to convert it to either.
If I take the lowest number I am getting (11) and multiply it by 2 (22) I come CLOSE to the current temp (22 C = 71.6 F) but the 24 and 26 convert to 75.2 and 78.8 which are WAY too high, so it can't be as easy as that
I really appreciate your help and if you have any other ideas I'd love to hear them!!!
-Kevin
Edit2: The temp# returned from the gyro is an 8 bit two's complement integer representing -128 to 127. Also note that as the temp goes up the temp register # returned will decrease for every degree celsius and it seems you have about a 14 degree celsius temp offset for real/read room temperature
Bummer on the lower voltage getting the same result
As far as WHY I want to get temp from it, I wanted to add the temp of my kids treehouse to the 4x20 lcd display and since I'm planning on using this sensor in the treehouse control panel project anyway and it's advertised as "The Gyroscope Module is a low power 3-axis angular rate sensor featuring temperature data as an added bonus." I thought - PERFECT - This is going to be EXACTLY what I need!!! Little did I know it would be this difficult lol
http://www.parallax.com/Store/Sensors/TemperatureHumidity/tabid/174/CategoryID/49/List/0/SortField/0/Level/a/ProductID/84/Default.aspx
L3G4200D gyro;
// Get Gyro Temperature
int gyroModuleTemperature()
return (map(gyro.readReg(0x26), 127, -127, -40, 85)+26) * (9.0/5.0); // Return degrees F.
You might need to change the +26 value to get your correct offset.
Hopefully it can help someone.
I emailed Parallax about the temperature data being accurate for a room or an environment.
"Yes, you can use the temperature reading from the Gyro to have the current temperature of the room or atmosphere that the Gyro is in." - Nick from Parallax
More you know
The 25 is not the Temperature it is a Reference number
To Get the Temperature you have to
Subtract the Value in OUT_TEMP(26h) Register From 25
then Add that to 25 Then use it as Deg C or Convert it to Deg F =(Deg C*9/5+32)
Note The Temp is not ambient Temp it is the Sensor Temperature of the chip
which changes negative for positive temp changes because that the direction the Measurements are affected
They increase as temp Decreases so an negative correction is needed.
To Measure Approx Ambient Temp one could add an offset Correction Number to get closer.
Comment the temperature measurement is Sensor Temp not ambient. The following can be used to create something somewhat useful
VAR
Byte STemp, ESTemp
PUB ReadTemp
STemp := Read_1B(OUT_TEMP)
ESTemp := 25 - STemp
ESTemp := ESTemp + 25 - 4 'Deg C the -4 is my correction yours may be different
ESTemp := ESTemp * 9 / 5 +32 'Deg F
I run into the same problem with L3GD20. This should be the most correct solution, although not confirmed by the ST authorities.
The datasheet is not complete and really misleading on this.
I'm using an Arduino with SDA->A4 and SCL->A5 with 5v.
Try:
1) If you're in an office, use a can of compressed air to change the temperature of the sensor. A soft stream of air should lower the temperature a degree or two to prove the sensor is working. Alternatively, put the sensor in the sun.
2) remember to enable to control ready signal.
