Trouble with hall effect IC
I'm using this hall effect IC
http://www.mouser.com/catalog/specsheets/SL353.pdf
This is a Honeywell SL353 hall effect sensor.
When I power it up it defaults to a logic 1.
When I bring a magnet near it the output changes to a logic 0.
When I power it down and set a magnet on top of it, then power it up, the output is a logic 0. When I remove the magnet the output is a logic 1.
Per the spec sheet: "Note 1: These Hall-effect sensors may have an initial output in either the ON or OFF state if powered up with an applied magnetic
field in the differential zone (applied magnetic field > Brp and < Bop). Honeywell recommends that the application circuit designer
allow 10 μs after supply voltage has reached its rated value for the output voltage to stabilize."
I would like the sensor to power up with a logic 0. When exposed to a magnetic field I'd like it to change to a logic 1.
Would someone please help me accomplish this goal?
Thank you!
Thank you!
Have you tried a simple 10 μs "waitcnt" when the program boots before testing the value?
Bruce
You could always use a variable to simulate an altered input, for example:
CON HALL_EFFECT_INPUT = 3 'Assumes PIN# 3 VAR BYTE HallEffectSensorState PUB Main WAITCNT(clkfreq / 100_000 + CNT) IF INA [3] 'magnet is not present HallEffectSensorState =: 0 ELSE 'magnet is present HallEffectSensorState =: 1
Why not just test the default input, like so:
CON HALL_EFFECT_INPUT = 3 'Assumes PIN# 3 PUB Main WAITCNT(clkfreq / 100_000 + CNT) IF INA [3] 'magnet is not present ELSE 'magnet is present
EDIT: I am no electronic genius, but I believe you could also do it electronically with a logic device, I believe it would be a flipflop or an inverter.
I'm using the hall effect sensor as an on/off button. The sensor feeds a Maxim Max16054 , power switch controller. The Maxim Max16054 needs the 'button' to be at a logic 0 and then pulse logic 1 in order to change it's state. So this part of the circuit doesn't hit the propeller yet.
This is going to be built into a very very space constrained application, so I was trying to minimize the number of chips and power consumption used.
I'm thinking that I may need to change hall effect IC's to a model that's normally low and goes high when in the presence of a magnet.
Take a look at this page http://www.kpsec.freeuk.com/trancirc.htm , you can create a logic inverter with a transistor and two resistors if you can find room on the board for these items. On that page, look for the title "A transistor inverter (NOT gate)"
Bruce
As you to save battery power you don't want the Prop to be simply sleeping (and using a little bit of power)
But the hall sensor and Max16054 would Always be powered and should have a known state.(after new batteries may have to check state)
As you want the magnet near once to turn on in and then later once again to turn if off.
To my knowledge, the prop does not have a 'sleep' mode. The closest to a sleep mode it has is to hold the reset line low, but that still consumes a pretty appreciable amount of power. I believe having a cog sitting on a waitpne using the 22kHz internal oscillator uses less power than the reset low method.
My plan was to have the hall effect sensor act as a switch for the Max16054. The Max16054 would then control a logic line to my buck regulator that creates the 3.3v for the circuit. The propeller will be powered by that regulator.
The hall effect sensor takes a few microamps, the Max16054 takes a few microamps, and the sleep mode of the buck regulator takes a few microamps....So the current draw when the device is 'off' is pretty low.
RCslow (~20khz) 70 microamps (.07 milliamps)
RCfast (~12mhz) 0.8 milliamps
RCfast with xtal 5mz activated but chip still running on RCfast 1.12 milliamps
xtal (5mhz) 0.6 milliamps pll off
xtal (5mhz) + pll1x (5mhz) 1.3 milliamps (The pll itself operates at 80mhz, x1 is a tap)
xtal (5mhz) + pll8x (40mhz) 2.9 milliamps
xtal (5mhz) + pll16x (80mhz) 4.8 milliamps
reset (reset button pressed) 0.8 milliamps
programming (being programmed F11 from PC, propeller uses 12mhz RCfast) 3.9 milliamps
brownout occurs at around 2.7 volts, at 2.5 volts 0.2 milliamp, at 2.2 volts 0.09 milliamp
Thanks for posting those numbers. Are those your measurements or are then pulled from some Parallax printed materials?
If your measurements can you describe your setup?
Peter
http://forums.parallax.com/showthread.php?84907-Propeller-Current-Draw
These were a single cog running who knows what. It was done by Tracey Allen.
These numbers came from a pre-release propeller. Chip says they are likely lower now.
I'm pretty sure Tracy has done some additional power tests with the Prop. I don't remember which thread the additional tests are in.
I just dug around the search tool and couldn't find it.
If you find it please bump that thread or repost, it's great info (and should be in the spec sheet IMHO).
I guess I'll take the numbers I posted and subtract 20% to get a rough estimate of power consumption.
http://forums.parallax.com/showthread.php?132961-Propeller-Power-Consumed-Based-on-Code&p=1019874&viewfull=1#post1019874
I remembered the names of some of the forum members who had posted in the thread. That and using the "site:" feature was enough information for Google to find it.
Very nice! Thank you!
I get 7uA for RCSLOW (that 70uA is probably the voltage regulator?) - 7uA is low enough for nearly all purposes.
and with software you can debouce/invert/latch etc
Though you could not disable the voltage regulator (unless you get one just to power prop and one larger with enable for accessories)
And this 20cent should work just as fine (though needs a 47k-470k pull-up)
http://www.mouser.com/ProductDetail/Diodes-Inc/AH1751-WG-7-A/?qs=sGAEpiMZZMvhQj7WZhFIAG2N5sxMWGciBBICsA0G5Wo%3d
Yes, I've verified that I can connect my current hall effect straight to the propeller.
That hall effect has the downside of consuming 3.5-6mA. My hall effect takes <10 uA while 'sleeping'. When it's being triggered it requires a comparable amount to yours.
http://www.mouser.com/Sensors/Hall-Effect-Magnetic-Sensors/Board-Mount-Hall-Effect-Magnetic-Sensors/_/N-6g7qoZscv7?P=1yzsbyyZ1yzsymjZ1z0w7ysZ1z0skrsZ1yzrvg5Z1z0rwf5Z1z0w0ma&Ns=Pricing|0
If they are open drain version and your magnet makes them NC during "off state" would not be too good
even with a 1M Ohm pull up resistor and if my calculations are correct would use 3.3 uA
