Tyler,
First thing, make sure you are using the same controller. If you are, it's most likely my code. I have had some bugs so. I changed hardware version, but the display is wired the same right now.
Not everything is working yet, but this *should* display pixels if you have the same controller.
eagletalontim, I can't work on the sd card right now, but hopefully dr A will figure this out. It would be a real bummer to find out the cage itself is bad. I hope I was doing something wrong. I was looking at the 5v crowd and they seem to have it working. I would THINK just removing the resistors would work, but bypassing may be key too. All I know is I tried both and I still have nothing. I'm making progress with the analog board, but still having issues. Time to RTFM...
Thanks, for the reply i'll try that out. I have tried to get the sd card working to and no luck so far. Weird i was hoping to use it and save some space(and money).
Tyler, which controller does your display use? Which display are you using? The one thing that comes to mind is POR values. Your display MAY NOT have the same Power On Reset values even if it is the same controller.
I am commenting code right now. I used to be in the habit of commenting as I wrote. I have been slacking off a bit.
I still have not been able to get my analog board to work. I will be switching back to my BS2 to test the control circuitry I added. The board was working with the BS2before I added the control circuitry. I'm hoping I'm just doing something wrong.
Found another wiring mistake. I wired DEV_SPI_ADD_LE to DEV_SPI_EN. I am correcting this now.
Other bugs found. Fixing those as well. I will be updating the final rev of ScreenTest shortly.
Thanks for the commented code i'll look at that later today when I have time. I hope Dr. A can firgure out the sd card, i can't. I read on a gadget gangstar forum that when not using PSM Sd Card reader your must put the Cs first instead of Do. As in:
...mount_explicit(CS, DI, CLK, DO) 'Gives me -100
instead of:
...mount_explicit(DO, CLK, DI, CS) 'Gives me -1
But unfortunately it doesn't seem to work, but mabye switching the order will provide a fix for this pesky sd card reader.
instead of:
Cheers,
Tyler
I will have to look into this. I have most of my hardware revisions done. I think I will leave multiplexing the parallel bus for later when I need it. I have one more chip to mount and connect on my analog board, which is fully working now. Hopefully all will go well with this.
Just got my screens in today I ordered 2 and got 4. Guess it is an error in my favor. I will continue to follow this thread for updates on the SD card reading. Just have to get mine to turn on, then display a pixel... the fun begins!
@ eagle, Awesome! I want to order 4 more of these things. I'm about ready to start working on the sd card, although I don't think I need it yet. I've been writing and drawing a GUI. I still haven't bound anything yet, but it's getting close. I'm getting excited at the potential. I'm still using spin drivers to write the display which is slow. I will be converting to ASM shortly. Drawing a screen is not horrible, but takes about 12 seconds. This is single threaded still, but I will be implementing multi-threading as soon as I get the drivers working. I hate to have to write my own text based gui, but I couldn't find anything that fit my needs close enough. I want font scaling because the simple borders control I have is not enough. Hats off to the guys at parallax for programming this font on the rom. It looks great.
Hey, thanks for the help! I have tried your latest test and still miserable failure. You mentioned that my displays may not have the same Power on and Reset values as yours(I believe we are using the same exact touchscreen module). How do I find out these values for my board and how do I adapt the code to address this? I think this may solve my troubles(My display doesn't seem to turn on or Reset ).
I mentioned those PORs because I am not setting every register on power on. You might want to try setting all the registers. I don't know enough to advise the correct values. With how forgiving these displays are, I wonder if you have a hardware issue. Did you connect Vcc to a good +5v? LCD Chip Select to ground and Write to +3.3? Does the backlight come on? Make sure LCD reset is 3v after power on. I have not needed reset, or used it other than making it high in the bootstrap.
Thanks for your patience. Yes I am using a good 5 volt for the VCC. I have put LCD CS to gnd and Write to 3.3 volt. Yes the Backlight turns in. But the LCD reset isn't 3V(tested with multimeter and got mere millivolts). My problem is that when I load the demo the backlight stays on but nothing comes up on the screen, don't know what to make of this though.
I sacrificed one of the displays by completely removing the SD socket and connecting wires to my own. Started with my own socket with lots of bypass caps and running the SD card off the propeller's 3V supply. First socket kept shorting the supply - who knows why but that one ended up in the bin. New socket. Moved the supply over to the local regulator. Removed first the 470uF, then the 22uF then the 0.1uF. No difference.
And then finally the answer. Bypassed the three 2k resistors.
So that is all you need to do. Remove those three resistors and replace with little wire links. Mine are not beautiful but they work fine. See attached photo. 10k pullups on the 4 lines. Oh and don't forget the card goes in upside down.
Tyler, your problem is the reset line. It must be high for the display to work. Otherwise the screen will just sit blank. You may be able to tie directly to 3v supply. I do not seem to need it, but results may vary.
Dr.A, I'm glad you got the card working. I will try again now that the rest of the hardware works.
Victory! Your were right joe my problem was the reset. I put it straight to the 3V just as you suggested and it worked perfectly. Now i'll move on to wiring touch recognition(hopefully it will take me less than a week ). Thanks for your help Joe and Dr. Acula(over on his thread).
@Dr. A im glad you solved the mystery of the sd card i'll definintly modify my board as you suggested and see if it works.
Awesome! I'm glad I could help. The touch input is very simple. DI, DO, Ck and CS. Write a byte, read 12. X-Y decoding looks to be decently easy.I will play with this in a couple days.
I have been thinking about freeing up the reset line since the screen doesn't seem to need it. I need to hook the CS line for the sd card back up and do some more tests. The sd cards I'm using (tried 3) might be the culprit. Now that everything else is working, it would be nice to have. I hope to have my sd breakout today or tomorrow, so that will give me something to test against as well.
I'm currently working out a couple aspects of the future menu design. I like using the propeller ROM font. It looks nice and has a comprehensive character set. I still need to write a few methods for the PropFont object, but this is what I have so far.
This is my PropFont object.
I'm sorry that I have not commented this code yet. I need to finish abstraction as well. It seems to run ok, other than being a bit slow. I have some ideas for optimization, but have not started working it out. I am convinced that using 2 cogs running Pasm will speed up display writes significantly. Before I can work on asm I need to finish the spin code. This includes a working character based gui. The current top object looks something like this.
That's the main portion of the code, some helper methods in the top object are
PUBEnable_SDCOUTA[DEV_SPI_ADD1..DEV_SPI_ADD0] := DEV_SPI_SDC_CS ' OUTA[DEV_SPI_EN] := 1PUBDisable_SDCOUTA[DEV_SPI_ADD1..DEV_SPI_ADD0] := DEV_SPI_SDC_CS ' OUTA[DEV_SPI_EN] := 1PUBSet_Spi_Ext_Address(Ext_Spi_Address)OUTA[DEV_SPI_ADD1..DEV_SPI_ADD0] := DEV_SPI_EXT_CS
wait.pause1ms(1)
OUTA[DEV_SPI_ADD_LE] := 0
wait.pause1ms(1)
SPI.SHIFTOUT(DEV_SD_DO, DEV_SD_CLK, 5, 3, Ext_Spi_Address)
wait.pause1ms(1)
OUTA[DEV_SPI_ADD_LE] := 1
wait.pause1ms(1)
'OUTA[DEV_SPI_ADD_LE] := 0' PUBDisable_SPI_EXT' OUTA[DEV_SPI_EN] := 1PUBStrobeCSOUTA[DEV_SPI_EN] := 0
wait.pause1ms(10)
OUTA[DEV_SPI_EN] := 1PUBTestTS | yval, xval,x,y
Enable_Touch ''Old format was OUTA[TS_CS] := 0 ' enable the touch screen'SPI.start(3,0) ' delay,state Already running?'Shiftout = data,clock,mode,bits,value'shiftin = data,clock,mode,bits'SPI read S, A2, A1, A0, Mode, SER, PD1, PD0' 1 0 0 1 1 0 0 0' MSB first' 001 is X' 101 is Yrepeat
pst.clear
SPI.SHIFTOUT(DEV_SD_DI, DEV_SD_CLK, 5, 8 , %1101_0000) ' reads x from 500 to 3700 (off < 500 )
xval := SPI.SHIFTIN(DEV_SD_DO, DEV_SD_CLK,2, 12)
SPI.SHIFTOUT(DEV_SD_DI, DEV_SD_CLK, 5, 8 , %1001_0000) ' reads y from 400 to 3800 (off > 3800 )
yval := SPI.SHIFTIN(DEV_SD_DO,DEV_SD_CLK,2, 12)
pst.Dec(xval)
pst.newline
pst.Dec(yval)
wait.pause1ms(10)
Disable_Touch ''Old format was OUTA[TS_CS] := 1 ' disable the touch screen PUBPST_Init | PstCog''Starts Parallax Serial Terminal for debugging.
PstCog := (pst.Start(115200) -1) '' returns the cog pst started in
pst.Str(String("Parallax Serial Terminal started in cog ")) '' talk to human
pst.Dec(PstCog) '' displays cog on PST ''
wait.pause1s(2)
'********************** private methods *********************PRIEnable_TouchOUTA[DEV_SPI_ADD1..DEV_SPI_ADD0] := DEV_SPI_TSC_CS
OUTA[DEV_SPI_EN] := 0' PRIDisable_TouchOUTA[DEV_SPI_ADD1..DEV_SPI_ADD0] := DEV_SPI_TSC_CS
OUTA[DEV_SPI_EN] := 0PRILCD_ResetOUTA[DEV_SPI_ADD1..DEV_SPI_ADD0] := DEV_SPI_LCD_RES
outa[DEV_SPI_EN] := 0
wait.pause1ms(5) ''wait here if necessary ' outa[DEV_SPI_EN] := 1
These are the basics. Once I get propfont finished, I'll re-write in asm which should speed up the display quite a bit. 12 seconds to display a blank screen is a bit too slow IMO. 4 sounds WAY more reasonable.
I've been working on the assembly program and had a lightbulb go off. I can save several instructions by adding a 10k pullup to the LCD write line. Instead of adding lcdwriteline to the data to be sent out, making pins = data, then pulling the write line low and back high again, flow will go make pins=data, mux lcdwrite*DIR* out, then back to input. I will be updating my hardware to this soon, but I'm writing without the update so I can test the difference this makes.
I will also be using a pullup on RS. This will save some code too.
edit,
Made hardware changes. I'm obviously doing something wrong in my ASM test. I don't know what now, I'll have to come back to this in a bit. Maybe someone can find my mistake, I'm burnt out at this point.
What you're doing here is running a huge loop full of nops. The nr modifier at the tail of your instructions stands for no result meaning the destination isn't affected. I don't think that's the idea here. So just remove them and let the insns do their default behaviour.
@Tyler, the colors are two bytes RRRRRGGG_GGGBBBBB so you get 5 levels for red and blue, and 6 levels for green. White is 11111111_11111111 which is hex FFFF
@Tyler, hex would be $FFFF. remember $ is Hex and hex is base 16. 0 - 9 and A thru F.
Thanks Kuroneko, I'll try again. Not very good @asm.
Thanks Joe! It worked perfectly(i need to read up on HEX im not familiar with it).
@Dr. Acula I bypassed the 2K resistors and the SD Card still didn't work. I tested my links they seemed fine, but my program still returned "Failed to Mount"(-1). Are there any other issues that may cause the sd not to work? I have formatted it to FAT-16 and it's a Lexar SDHC 4GB Sd card(if that helps with the diagnosis).
I have a working dat block. It writes a blank screen in a flash. I hope I can squeeze the character read and decode into the clock cycles wasted by the write loop. Very promising results. I'm glad I took the jump from spin to ASM. ASM is not that much harder, it's just it requires that much more though to making things work.
I hooked the sd card on my screen back up, but I haven't tested it yet. Now that spin code works, I'm going to investigate again. The hardware mods work great. Getting ASM working was top priority, now on to sd card!
*edit*
the question I have now is on cognew formatting..
is it?
cognew(@entry, @buffer)
or?
cognew(@entry,@@buffer)
A 50sec delay is usually an indicator that waitcnt just missed its target and is now waiting for a full wrap-around. Can you figure out where in your code it blocks (delay could be in an object)?
This is a little bit of code for those that can print a pixel but can't get an SD card working in order to display a font. Uses the internal propeller font which is inside the propeller chip.
PUBPropfont' use propeller font in the rom for bootup messages when debugging sd cards
curx := 0' set cursor to top left of screen (common variable)
cury := 0
Propfont_string(string("Loading SD")) ' string to send
Propfont_string(string("Loading Font"))
PUBPropfont_string(stringptr)'print at curx,curyrepeatstrsize(stringptr)
ILI9325.draw(curx,cury,curx+15,cury+31) ' location to start drawing
Propfont_out(byte[stringptr++])
curx +=16
curx := 0
cury += 32' new line at end of stringPUBPropfont_out(ascii) | address,pixels
address := $8000 + (ascii >> 1) << 7' get rom addressrepeat32' 32 rows per character, split in two parts
pixels := long[address] ' get rom font data
pixels := pixels >> (ascii & 1) ' shift for odd charactersrepeat16' 16 columnsif pixels & 1
ILI9325.pixel(%00000111_11100000) ' foreground color RRRRRGGG_GGGBBBBBelse
ILI9325.pixel(%00000000_00000000) ' background color
pixels := pixels >> 2' alternate pixels interleaved so shift 2
address += 4'increment address by 4 bytes
CON _clkmode = xtal1 + pll16x ' use crystal x 16 _xinfreq = 5_000_000 ''PINS FOR LCD RS = 16 ''PINS FOR CS - TO KEEP FROM FLOATING LCD_WR = 17 ''and sd card defs DEV_SD_CLK = 18 DEV_SD_DI = 19 DEV_SD_DO = 20 DEV_SPI_EN = 21 DEV_SPI_ADD0 = 22 DEV_SPI_ADD1 = 23 DEV_SPI_ADD_LE = 24 DEV_SPI_LCD_RES = 0 DEV_SPI_SDC_CS = 1 DEV_SPI_TSC_CS = 2 DEV_SPI_EXT_CS = 3 DEV_SPI_EXT_POT_CS = 0 DEV_SPI_EXT_SW_CS = %100 ''LCD REGISTERS REG_OSCILLATOR = $0000 ''Oscillator (R00h) (POR = 0000h) REG_DRIVEROUTPUTCONTROL = $0001 ''Driver Output Control (R01h) (POR = 2B3Fh) REG_LCDDRIVINGWAVFORM = $0002 ''LCD-Driving-Waveform Control (R02h) (POR = 0000h) REG_POWERCONTROL1 = $0003 '' (R03H) REG_DISPLAYCONTROL = $0007 ''Display Control (R07h) (POR = 0000h) REG_FRAMECYCLECONTROL = $000B ''Frame Cycle Control (R0Bh) (POR = 5308h)D308 BY DATASHEET REG_POWERCONTROL2 = $000C '' (R0Ch) (POR = 0004) REG_POWERCONTROL3 = $000D '' REG_POWERCONTROL4 = $000E '' REG_GATESCANPOSITION = $000F ''Gate Scan Position (R0Fh) (POR = 0000h) REG_SLEEPMODE = $0010 ''Sleep mode (R10h) (POR = 0001h) REG_ENTRYMODE = $0011 ''Entry Mode (R11h) (POR = 6830h) REG_HPORCH = $0016 '' (R16h) (POR = EF1Ch) REG_VPORCH = $0017 '' (R17h) (POR = 0003h) REG_POWERCONTROL5 = $001E '' REG_RAMDATAWRITE = $0022 '' REG_RAMWRITEDATAMASK1 = $0023 '' (R23h) (POR = 0000h) REG_RAMWRITEDATAMASK2 = $0024 '' (R24h) (POR = 0000h) REG_VERTICALSCROLCONTROL1 = $0041 '' (R41h) (POR = 0000h) REG_VERTICALSCROLCONTROL2 = $0042 '' (R42h) (POR = 0000h) REG_HORIZONTALRAMADDRESSPOS = $0044 '' (R44h) (POR = EF00h) REG_VERTICALRAMADDRESSSTART = $0045 '' (R45h) (POR = 0000h) REG_VERTICALRAMADDRESSEND = $0046 '' (R46h) (POR = 013Fh) REG_FIRSTWINDOWSTART = $0048 '' (R48h) (POR = 0000h) REG_FIRSTWINDOWEND = $0049 '' (R49h) (POR = 013Fh) REG_SECONDWINDOWSTART = $004A '' (R4Ah) (POR = 0000h) REG_SECONDWINDOWEND = $004B '' (R4Bh) (POR = 013Fh) REG_SETGDDRXADDRESSCOUNTER = $004E '' (R4Eh) (POR = 0000h) REG_SETGDDRYADDRESSCOUNTER = $004F '' (R4Fh) (POR = 0000h) FONT_ROM_ADDRESS = $8000 BGCOLOR = $0fff TXTCOLOR = $0000 OBJ 'fat : "SD3.01_FATEngine.spin" ' thanks to Kye spi : "SPI_ASM" ' thanks to Beau wait : "timing" ' thanks to parallax pst : "Parallax Serial Terminal" VAR long ActiveColor, WindowX1, WindowX2, WindowY1, WindowY2 PUB Bootstrap EnableDisplayPins OUTA[DEV_SPI_EN] := 0 OUTA[DEV_SPI_ADD_LE] := 0 'OUTA[DEV_SPI_ADD1..DEV_SPI_ADD0] := 3 'SPI.SHIFTOUT(DEV_SD_DO, DEV_SD_CLK, 4,8,%100) 'wait.pause1s(100) Init_SSD1289 'ClearScreen PST_Init SPI.start(5,0) 'Init_SD Repeat Test_Main PUB Init_SD | pe ''broken? PST.CLEAR pst.Str(string("Testing for SD card")) ' helpful message if card is out, better than just a blank screen pst.newline 'pst.dec(fat.FATEngineStart(20,18,19,22,-1, 1, 1, 1,-1)) pst.newline 'pst.str(string("sucess")) pst.newline pst.str(string("mounting fat")) pst.newline 'pst.DEC(fat.partitionError) 'fat.mountPartition(0) ' mount the sd card wait.pause1s(5) pst.str(string("mounting fat done")) pst.newline PUB TestTS | yval, xval,x,y Enable_Touch ''Old format was OUTA[TS_CS] := 0 ' enable the touch screen 'SPI.start(3,0) ' delay,state Already running? 'Shiftout = data,clock,mode,bits,value 'shiftin = data,clock,mode,bits 'SPI read S, A2, A1, A0, Mode, SER, PD1, PD0 ' 1 0 0 1 1 0 0 0 ' MSB first ' 001 is X ' 101 is Y repeat pst.clear SPI.SHIFTOUT(DEV_SD_DI, DEV_SD_CLK, 5, 8 , %1101_0000) ' reads x from 500 to 3700 (off < 500 ) xval := SPI.SHIFTIN(DEV_SD_DO, DEV_SD_CLK,2, 12) SPI.SHIFTOUT(DEV_SD_DI, DEV_SD_CLK, 5, 8 , %1001_0000) ' reads y from 400 to 3800 (off > 3800 ) yval := SPI.SHIFTIN(DEV_SD_DO,DEV_SD_CLK,2, 12) pst.Dec(xval) pst.newline pst.Dec(yval) wait.pause1ms(10) Disable_Touch ''Old format was OUTA[TS_CS] := 1 ' disable the touch screen PUB Init_SSD1289 ''Init Display EnableDisplayPins ''enable pins 0 to 15 WriteHigh LCD_Reset ''reset screen wait.pause1ms(5) LCD_Reset ''then init screen wait.pause1ms(5) Lcd_Write_Com (REG_DISPLAYCONTROL) ''Display Control (R07h) (POR = 0000h) Lcd_Write_Data($0021) ''GON = 1 DTE = 0 D[1:0] = 01 Lcd_Write_Com (REG_OSCILLATOR) ''Oscillator (R00h) (POR = 0000h) Lcd_Write_Data($0001) ''Turn on oscillator Lcd_Write_Com (REG_DISPLAYCONTROL) ''Display Control (R07h) (POR = 0000h) Lcd_Write_Data($0023) ''GON = 1 DTE = 0 D[1:0] = 11 Lcd_Write_Com (REG_SLEEPMODE) ''Sleep mode (R10h) (POR = 0001h) Lcd_Write_Data($0000) '' ''exit sleep mode Lcd_Write_Com (REG_DISPLAYCONTROL) ''Display Control (R07h) (POR = 0000h) Lcd_Write_Data($0033) ''GON = 1 DTE = 1 D[1:0] = 11 Lcd_Write_Com (REG_ENTRYMODE) ''Entry Mode (R11h) (POR = 6830h) Lcd_Write_Data($6838) '' Lcd_Write_Com (REG_LCDDRIVINGWAVFORM) ''LCD-Driving-Waveform Control (R02h) (POR = 0000h)($1000) Lcd_Write_Data($1000) '' '' Lcd_Write_Com (REG_GATESCANPOSITION) ''Gate Scan Position (R0Fh) (POR = 0000h) ($0000) Lcd_Write_Data($0000) '' '' '' Lcd_Write_Com (REG_DRIVEROUTPUTCONTROL) ''Driver Output Control (R01h) (POR = [0XXXX0X1]3Fh) 433f ($633F) Lcd_Write_Data($6B3F) '' '' Lcd_Write_Com (REG_FRAMECYCLECONTROL) ''Frame Cycle Control (R0Bh) (POR = 5308h) ($5308) Lcd_Write_Data($5308) '' ' Lcd_Write_Com (REG_DISPLAYCONTROL) ''Display Control (R07h) (POR = 0000h) ($0033) Lcd_Write_Data($0033) ''GON = 1 DTE = 1 D[1:0] = 11 PUB PST_Init | PstCog ''Starts Parallax Serial Terminal for debugging. PstCog := (pst.Start(115200) -1) '' returns the cog pst started in pst.Str(String("Parallax Serial Terminal started in cog ")) '' talk to human pst.Dec(PstCog) '' displays cog on PST '' wait.pause1s(5) '' wait a bit PUB Test_Main | char, tmp pst.Clear pst.Str(String("Function Test Main Menu")) pst.NewLine pst.Str(String("1 for Font Test 1")) pst.NewLine pst.Str(String("2 for Color Test")) pst.Newline pst.Str(String("3 for Hello World")) pst.NewLine pst.Str(String("4 for FreeRun Color Test")) pst.NewLine pst.Str(String("5 for Sd Test")) pst.NewLine pst.Str(String("6 for TS Test")) pst.NewLine pst.Str(String("7 for External SPI Test")) pst.NewLine char := pst.DecIn if (char == 1) FontTest elseif (char == 2) pst.newline pst.str(string("Select Hex Color 0000 -FFFF")) pst.NewLine char := pst.hexin ColorTest(char) elseif (char == 3) HelloWorld elseif (char == 4) ColorTestFreeRUN elseif (char == 5) Init_SD elseif (char == 6) TestTS elseif (char == 7) Spi_Test 'pst. return PUB Spi_Test | char, address, data repeat pst.Clear pst.Str(String("1 for pot test")) Pst.NewLine Pst.Str(String("2 for switch test")) Pst.NewLine char := pst.DecIn if (char == 1) Pst.Clear Pst.Str(String("Input Pot Address 0 - 3")) Pst.NewLine address := Pst.DecIn Pst.NewLine Pst.Str(String("Input Pot Value")) Pst.Newline data := Pst.DecIn address <<= 8 data := data + address wait.pause1s(1) Set_Spi_Ext_Address(0) SPI.SHIFTOUT(DEV_SD_DO, DEV_SD_CLK, 5, 11, data) StrobeCS Disable_Spi_Ext PUB ColorTestFreeRUN | color repeat repeat color from $0000 to $FFFF step 1 ColorTest(Color) PUB ColorTest(Color) | idxr, idxc SetWindow(0, 0, 239, 319) SetGAddress(0,0) repeat idxr from 0 to 319 repeat idxc from 0 to 239 Lcd_Write_Com(REG_RAMDATAWRITE) Lcd_Write_Data(Color) return PUB HelloWorld | char, row, col PropFont_WriteCr(72, 0, 0*16, 0, 0, BGCOLOR, TXTCOLOR) PropFont_WriteCr(101, 0, 1*16, 0, 0, BGCOLOR, TXTCOLOR) PropFont_WriteCr(108, 0, 2*16, 0, 0, BGCOLOR, TXTCOLOR) PropFont_WriteCr(108, 0, 3*16, 0, 0, BGCOLOR, TXTCOLOR) PropFont_WriteCr(111, 0, 4*16, 0, 0, BGCOLOR, TXTCOLOR) PropFont_WriteCr(32, 0, 5*16, 0, 0, BGCOLOR, TXTCOLOR) PropFont_WriteCr(87, 0, 6*16, 0, 0, BGCOLOR, TXTCOLOR) PropFont_WriteCr(111, 0, 7*16, 0, 0, BGCOLOR, TXTCOLOR) PropFont_WriteCr(114, 0, 8*16, 0, 0, BGCOLOR, TXTCOLOR) PropFont_WriteCr(108, 0, 9*16, 0, 0, BGCOLOR, TXTCOLOR) PropFont_WriteCr(100, 0, 10*16, 0, 0, BGCOLOR, TXTCOLOR) PUB FontTest | tmp, char, row, col, rbor, cbor pst.Clear pst.Str(String("Select character")) pst.newline char := pst.DecIn pst.Str(String("Select Row")) pst.newline row := pst.DecIn pst.Str(String("Select Col")) pst.newline col := pst.DecIn pst.Str(String("Select RBor")) pst.newline rbor := pst.DecIn pst.Str(String("Select CBor")) pst.newline cbor := pst.DecIn PropFont_WriteCr(char, row, col, rbor, cbor, BGCOLOR, TXTCOLOR) return PUB ClearScreen | idxr, idxc Lcd_Write_Com (REG_SETGDDRxADDRESSCOUNTER) Lcd_Write_Data(0) Lcd_Write_Com (REG_SETGDDRyADDRESSCOUNTER) Lcd_Write_Data(0) repeat idxr from 0 to 76800 Lcd_Write_Com(REG_RAMDATAWRITE) Lcd_Write_Data(BGCOLOR) return PUB PropFont_WriteCr(Character, PosR, PosC, RBorder, CBorder, BgC, TxC) | characterpointer, odd_even, bitpatern[32], idx, pxlidx, lcdidx, pxlidxdcd, x1, y1, x2, y2 odd_even := character & $0001 characterpointer := character & $fffe characterpointer >>= 1 characterpointer *= 32 repeat idx from 0 to 31 bitpatern[idx] := long[FONT_ROM_ADDRESS][characterpointer + idx] y1 := PosC + CBorder y2 := (PosC + 15) - CBorder x1 := PosR + RBorder x2 := (PosR + 31) - RBorder SetWindow(x1, y1, x2, y2) SetGAddress(x1,y1) repeat idx from RBorder to 31 - RBorder repeat pxlidx from odd_even + (CBorder*2) to (odd_even + 30) - (CBorder*2) step 2 pxlidxdcd := |< pxlidx if ((bitpatern[idx] & pxlidxdcd) == pxlidxdcd) Lcd_Write_Com(REG_RAMDATAWRITE) Lcd_Write_Data(TxC) else Lcd_Write_Com(REG_RAMDATAWRITE) Lcd_Write_Data(BgC) SetWindow(0, 0, 239, 319) return PUB SetWindow(x1, y1, x2, y2) | HORIZONTALRAMADDRESSPOS WindowX1 := x1 WindowX2 := x2 WindowY1 := y1 WindowY2 := y2 HORIZONTALRAMADDRESSPOS := x1 + (x2 << 8) Lcd_Write_Com ( REG_HORIZONTALRAMADDRESSPOS) Lcd_Write_Data(HORIZONTALRAMADDRESSPOS) Lcd_Write_Com (REG_VERTICALRAMADDRESSSTART) Lcd_Write_Data(y1) Lcd_Write_Com (REG_VERTICALRAMADDRESSEND) Lcd_Write_Data(y2) PUB SetGAddress(x,y) Lcd_Write_Com (REG_SETGDDRxADDRESSCOUNTER) ''max %1111_1111, $FF Lcd_Write_Data(x) Lcd_Write_Com (REG_SETGDDRyADDRESSCOUNTER) ''max %1_0011_1111, $13f Lcd_Write_Data(y) return ''PUB ChangeOrientation(n) ' pass true = portrait or false = landscape, changes global variable orientation in this object '' EnableLatchPins '' orientation := n '' if orientation '' Lcd_Write_Com(REG_DRIVEROUTPUTCONTROL) '' ILIcmd($0001,$0100) ' set SS and SM bit 0001 0100 portrait '' ILIcmd($0003,$1030) ' set GRAM write direction and BGR=1. $0003 $1030 '' else '' ILIcmd($0001,$0000) ' set SS and SM bit 0001 0000 landscape '' ILIcmd($0003,$1038) ' landscape $1028 = original but 1038 is correct - not mirror image PUB Enable_SDC OUTA[DEV_SPI_ADD1..DEV_SPI_ADD0] := DEV_SPI_SDC_CS ' OUTA[DEV_SPI_EN] := 1 PUB Disable_SDC OUTA[DEV_SPI_ADD1..DEV_SPI_ADD0] := DEV_SPI_SDC_CS ' OUTA[DEV_SPI_EN] := 1 PUB Set_Spi_Ext_Address(Ext_Spi_Address) OUTA[DEV_SPI_ADD1..DEV_SPI_ADD0] := DEV_SPI_EXT_CS wait.pause1s(1) OUTA[DEV_SPI_ADD_LE] := 0 wait.pause1s(1) SPI.SHIFTOUT(DEV_SD_DO, DEV_SD_CLK, 5, 8, Ext_Spi_Address) wait.pause1s(1) OUTA[DEV_SPI_ADD_LE] := 1 wait.pause1s(1) OUTA[DEV_SPI_ADD_LE] := 0 ' PUB Disable_SPI_EXT ' OUTA[DEV_SPI_EN] := 1 PUB StrobeCS OUTA[DEV_SPI_EN] := 0 wait.pause1ms(5) OUTA[DEV_SPI_EN] := 1 '********************** private methods ********************* PRI Enable_Touch OUTA[DEV_SPI_ADD1..DEV_SPI_ADD0] := DEV_SPI_TSC_CS OUTA[DEV_SPI_EN] := 0 ' PRI Disable_Touch OUTA[DEV_SPI_ADD1..DEV_SPI_ADD0] := DEV_SPI_TSC_CS OUTA[DEV_SPI_EN] := 0 ' PRI LCD_Reset OUTA[DEV_SPI_ADD1..DEV_SPI_ADD0] := DEV_SPI_LCD_RES outa[DEV_SPI_EN] := 0 wait.pause1ms(5) ''wait here if necessary ' outa[DEV_SPI_EN] := 1 PRI LCD_Writ_Bus(V) OUTA[15..0] := V WriteLow ' write pin low WriteHigh ' toggle write pin PRI Lcd_Write_Com(V) RSLow LCD_Writ_Bus(V) PRI Lcd_Write_Data(V) RSHigh LCD_Writ_Bus(V) PRI EnableDisplayPins DIRA:=%00000001_11100011_11111111_11111111 ' , Reset, WR, RS and 16 data lines active PRI TristateDisplayPins ' tristate all pins - DIRA:=%00000001_11100010_00000000_00000000 '' PRI RSLow outa[RS] := 0 PRI RSHigh outa[RS] := 1 ' PRI WriteLow outa[LCD_WR] := 0 ' PRI WriteHigh outa[LCD_WR] := 1 Pub Deadend 'Deadend repeat wait.pause1s(10000)
Not everything is working yet, but this *should* display pixels if you have the same controller.eagletalontim, I can't work on the sd card right now, but hopefully dr A will figure this out. It would be a real bummer to find out the cage itself is bad. I hope I was doing something wrong.
{ '' SSD1289 LCD driver ''P0 - P15 Data bus pins ''P16 LCD_RS ''P17 LCD_WR ''P18 SData_In ''P19 SData_ck ''P20 Sdata_out ''P21 TS_CS ''P22 SD_CS ''P23 LCD_RESET ''P24 ''P25 ''P26 ''P27 ''P28 ''P29 } CON _clkmode = xtal1 + pll16x ' use crystal x 16 _xinfreq = 5_000_000 ''PINS FOR LCD TS_CS = 21 SD_CS = 22 DEV_LCD_RST =23 RS = 16 ''PINS FOR CS - TO KEEP FROM FLOATING LCD_WR = 17 ''and sd card defs DEV_SD_CLK = 18 DEV_SD_DI = 19 DEV_SD_DO = 20 ''LCD REGISTERS REG_OSCILLATOR = $0000 ''Oscillator (R00h) (POR = 0000h) REG_DRIVEROUTPUTCONTROL = $0001 ''Driver Output Control (R01h) (POR = 2B3Fh) REG_LCDDRIVINGWAVFORM = $0002 ''LCD-Driving-Waveform Control (R02h) (POR = 0000h) REG_POWERCONTROL1 = $0003 '' (R03H) REG_DISPLAYCONTROL = $0007 ''Display Control (R07h) (POR = 0000h) REG_FRAMECYCLECONTROL = $000B ''Frame Cycle Control (R0Bh) (POR = 5308h)D308 BY DATASHEET REG_POWERCONTROL2 = $000C '' (R0Ch) (POR = 0004) REG_POWERCONTROL3 = $000D '' REG_POWERCONTROL4 = $000E '' REG_GATESCANPOSITION = $000F ''Gate Scan Position (R0Fh) (POR = 0000h) REG_SLEEPMODE = $0010 ''Sleep mode (R10h) (POR = 0001h) REG_ENTRYMODE = $0011 ''Entry Mode (R11h) (POR = 6830h) REG_HPORCH = $0016 '' (R16h) (POR = EF1Ch) REG_VPORCH = $0017 '' (R17h) (POR = 0003h) REG_POWERCONTROL5 = $001E '' REG_RAMDATAWRITE = $0022 '' REG_RAMWRITEDATAMASK1 = $0023 '' (R23h) (POR = 0000h) REG_RAMWRITEDATAMASK2 = $0024 '' (R24h) (POR = 0000h) REG_VERTICALSCROLCONTROL1 = $0041 '' (R41h) (POR = 0000h) REG_VERTICALSCROLCONTROL2 = $0042 '' (R42h) (POR = 0000h) REG_HORIZONTALRAMADDRESSPOS = $0044 '' (R44h) (POR = EF00h) REG_VERTICALRAMADDRESSSTART = $0045 '' (R45h) (POR = 0000h) REG_VERTICALRAMADDRESSEND = $0046 '' (R46h) (POR = 013Fh) REG_FIRSTWINDOWSTART = $0048 '' (R48h) (POR = 0000h) REG_FIRSTWINDOWEND = $0049 '' (R49h) (POR = 013Fh) REG_SECONDWINDOWSTART = $004A '' (R4Ah) (POR = 0000h) REG_SECONDWINDOWEND = $004B '' (R4Bh) (POR = 013Fh) REG_SETGDDRXADDRESSCOUNTER = $004E '' (R4Eh) (POR = 0000h) REG_SETGDDRYADDRESSCOUNTER = $004F '' (R4Fh) (POR = 0000h) FONT_ROM_ADDRESS = $8000 BGCOLOR = $0fff TXTCOLOR = $0000 OBJ spi : "SPI_ASM" ' thanks to Beau wait : "timing" ' thanks to parallax pst : "Parallax Serial Terminal" VAR long ActiveColor, WindowX1, WindowX2, WindowY1, WindowY2 PUB Bootstrap EnableDisplayPins OUTA[SD_CS] := 1 OUTA[TS_CS] := 1 SPI.start(3,0) Init_SSD1289 ClearScreen PST_Init SPI.start(5,0) HelloWorld Repeat Test_Main PUB TestTS | yval, xval,x,y OUTA[TS_CS] := 0 ' enable the touch screen 'SPI.start(3,0) ' delay,state Already running? 'Shiftout = data,clock,mode,bits,value 'shiftin = data,clock,mode,bits 'SPI read S, A2, A1, A0, Mode, SER, PD1, PD0 ' 1 0 0 1 1 0 0 0 ' MSB first ' 001 is X ' 101 is Y repeat pst.clear SPI.SHIFTOUT(DEV_SD_DO, DEV_SD_CLK, 5, 8 , %1101_0000) ' reads x from 500 to 3700 (off < 500 ) xval := SPI.SHIFTIN(DEV_SD_DI, DEV_SD_CLK,2, 12) SPI.SHIFTOUT(DEV_SD_DO, DEV_SD_CLK, 5, 8 , %1001_0000) ' reads y from 400 to 3800 (off > 3800 ) yval := SPI.SHIFTIN(DEV_SD_DI,DEV_SD_CLK,2, 12) pst.Dec(xval) pst.newline pst.Dec(yval) wait.pause1ms(100) OUTA[TS_CS] := 1 ' disable the touch screen PUB Init_SSD1289 ''Init Display EnableDisplayPins ''enable pins 0 to 15 WriteHigh LCD_Reset ''reset screen wait.pause1ms(5) LCD_Reset ''then init screen wait.pause1ms(5) Lcd_Write_Com (REG_DISPLAYCONTROL) ''Display Control (R07h) (POR = 0000h) Lcd_Write_Data($0021) ''GON = 1 DTE = 0 D[1:0] = 01 Lcd_Write_Com (REG_OSCILLATOR) ''Oscillator (R00h) (POR = 0000h) Lcd_Write_Data($0001) ''Turn on oscillator Lcd_Write_Com (REG_DISPLAYCONTROL) ''Display Control (R07h) (POR = 0000h) Lcd_Write_Data($0023) ''GON = 1 DTE = 0 D[1:0] = 11 Lcd_Write_Com (REG_SLEEPMODE) ''Sleep mode (R10h) (POR = 0001h) Lcd_Write_Data($0000) '' ''exit sleep mode Lcd_Write_Com (REG_DISPLAYCONTROL) ''Display Control (R07h) (POR = 0000h) Lcd_Write_Data($0033) ''GON = 1 DTE = 1 D[1:0] = 11 Lcd_Write_Com (REG_ENTRYMODE) ''Entry Mode (R11h) (POR = 6830h) Lcd_Write_Data($6838) '' Lcd_Write_Com (REG_LCDDRIVINGWAVFORM) ''LCD-Driving-Waveform Control (R02h) (POR = 0000h)($1000) Lcd_Write_Data($1000) '' '' Lcd_Write_Com (REG_GATESCANPOSITION) ''Gate Scan Position (R0Fh) (POR = 0000h) ($0000) Lcd_Write_Data($0000) '' '' '' Lcd_Write_Com (REG_DRIVEROUTPUTCONTROL) ''Driver Output Control (R01h) (POR = [0XXXX0X1]3Fh) 433f ($633F) Lcd_Write_Data($6B3F) '' '' Lcd_Write_Com (REG_FRAMECYCLECONTROL) ''Frame Cycle Control (R0Bh) (POR = 5308h) ($5308) Lcd_Write_Data($5308) '' ' Lcd_Write_Com (REG_DISPLAYCONTROL) ''Display Control (R07h) (POR = 0000h) ($0033) Lcd_Write_Data($0033) ''GON = 1 DTE = 1 D[1:0] = 11 PUB PST_Init | PstCog ''Starts Parallax Serial Terminal for debugging. PstCog := (pst.Start(115200) -1) '' returns the cog pst started in pst.Str(String("Parallax Serial Terminal started in cog ")) '' talk to human pst.Dec(PstCog) '' displays cog on PST '' wait.pause1s(5) '' wait a bit PUB Test_Main | char, tmp pst.Clear pst.Str(String("Function Test Main Menu")) pst.NewLine pst.Str(String("1 for Font Test 1")) pst.NewLine pst.Str(String("2 for Color Test")) pst.Newline pst.Str(String("3 for Hello World")) pst.NewLine pst.Str(String("4 for FreeRun Color Test")) pst.NewLine pst.Str(String("5 for TouchScreen Test")) pst.NewLine char := pst.DecIn if (char == 1) FontTest elseif (char == 2) pst.newline pst.str(string("Select Hex Color 0000 -FFFF")) pst.NewLine char := pst.hexin ColorTest(char) elseif (char == 3) HelloWorld elseif (char == 4) ColorTestFreeRUN elseif (char == 5) TestTS PUB ColorTestFreeRUN | color repeat repeat color from $0000 to $FFFF step 1 ColorTest(Color) PUB ColorTest(Color) | idxr, idxc SetWindow(0, 0, 239, 319) SetGAddress(0,0) repeat idxr from 0 to 319 repeat idxc from 0 to 239 Lcd_Write_Com(REG_RAMDATAWRITE) Lcd_Write_Data(Color) return PUB HelloWorld | char, row, col PropFont_WriteCr(72, 0, 0*16, 0, 0, BGCOLOR, TXTCOLOR) PropFont_WriteCr(101, 0, 1*16, 0, 0, BGCOLOR, TXTCOLOR) PropFont_WriteCr(108, 0, 2*16, 0, 0, BGCOLOR, TXTCOLOR) PropFont_WriteCr(108, 0, 3*16, 0, 0, BGCOLOR, TXTCOLOR) PropFont_WriteCr(111, 0, 4*16, 0, 0, BGCOLOR, TXTCOLOR) PropFont_WriteCr(32, 0, 5*16, 0, 0, BGCOLOR, TXTCOLOR) PropFont_WriteCr(87, 0, 6*16, 0, 0, BGCOLOR, TXTCOLOR) PropFont_WriteCr(111, 0, 7*16, 0, 0, BGCOLOR, TXTCOLOR) PropFont_WriteCr(114, 0, 8*16, 0, 0, BGCOLOR, TXTCOLOR) PropFont_WriteCr(108, 0, 9*16, 0, 0, BGCOLOR, TXTCOLOR) PropFont_WriteCr(100, 0, 10*16, 0, 0, BGCOLOR, TXTCOLOR) PUB FontTest | tmp, char, row, col, rbor, cbor pst.Clear pst.Str(String("Select character")) pst.newline char := pst.DecIn pst.Str(String("Select Row")) pst.newline row := pst.DecIn pst.Str(String("Select Col")) pst.newline col := pst.DecIn pst.Str(String("Select RBor")) pst.newline rbor := pst.DecIn pst.Str(String("Select CBor")) pst.newline cbor := pst.DecIn PropFont_WriteCr(char, row, col, rbor, cbor, BGCOLOR, TXTCOLOR) return PUB ClearScreen | idxr, idxc Lcd_Write_Com (REG_SETGDDRxADDRESSCOUNTER) Lcd_Write_Data(0) Lcd_Write_Com (REG_SETGDDRyADDRESSCOUNTER) Lcd_Write_Data(0) repeat idxr from 0 to 76800 Lcd_Write_Com(REG_RAMDATAWRITE) Lcd_Write_Data(BGCOLOR) return PUB PropFont_WriteCr(Character, PosR, PosC, RBorder, CBorder, BgC, TxC) | characterpointer, odd_even, bitpatern[32], idx, pxlidx, lcdidx, pxlidxdcd, x1, y1, x2, y2 odd_even := character & $0001 characterpointer := character & $fffe characterpointer >>= 1 characterpointer *= 32 repeat idx from 0 to 31 bitpatern[idx] := long[FONT_ROM_ADDRESS][characterpointer + idx] y1 := PosC + CBorder y2 := (PosC + 15) - CBorder x1 := PosR + RBorder x2 := (PosR + 31) - RBorder SetWindow(x1, y1, x2, y2) SetGAddress(x1,y1) repeat idx from RBorder to 31 - RBorder repeat pxlidx from odd_even + (CBorder*2) to (odd_even + 30) - (CBorder*2) step 2 pxlidxdcd := |< pxlidx if ((bitpatern[idx] & pxlidxdcd) == pxlidxdcd) Lcd_Write_Com(REG_RAMDATAWRITE) Lcd_Write_Data(TxC) else Lcd_Write_Com(REG_RAMDATAWRITE) Lcd_Write_Data(BgC) SetWindow(0, 0, 239, 319) return PUB SetWindow(x1, y1, x2, y2) | HORIZONTALRAMADDRESSPOS WindowX1 := x1 WindowX2 := x2 WindowY1 := y1 WindowY2 := y2 HORIZONTALRAMADDRESSPOS := x1 + (x2 << 8) Lcd_Write_Com ( REG_HORIZONTALRAMADDRESSPOS) Lcd_Write_Data(HORIZONTALRAMADDRESSPOS) Lcd_Write_Com (REG_VERTICALRAMADDRESSSTART) Lcd_Write_Data(y1) Lcd_Write_Com (REG_VERTICALRAMADDRESSEND) Lcd_Write_Data(y2) PUB SetGAddress(x,y) Lcd_Write_Com (REG_SETGDDRxADDRESSCOUNTER) ''max %1111_1111, $FF Lcd_Write_Data(x) Lcd_Write_Com (REG_SETGDDRyADDRESSCOUNTER) ''max %1_0011_1111, $13f Lcd_Write_Data(y) return '********************** private methods ********************* PRI LCD_Reset outa[DEV_LCD_RST] := 0 wait.pause1ms(5) ''wait here if necessary ' outa[DEV_LCD_RST] := 1 PRI LCD_Writ_Bus(V) OUTA[15..0] := V WriteLow ' write pin low WriteHigh ' toggle write pin PRI Lcd_Write_Com(V) RSLow LCD_Writ_Bus(V) PRI Lcd_Write_Data(V) RSHigh LCD_Writ_Bus(V) PRI EnableDisplayPins DIRA:=%00000000_11100011_11111111_11111111 ' , Reset, WR, RS and 16 data lines active PRI TristateDisplayPins ' tristate all pins - DIRA:=%00000000_11100010_00000000_00000000 '' PRI RSLow outa[RS] := 0 PRI RSHigh outa[RS] := 1 ' PRI WriteLow outa[LCD_WR] := 0 ' PRI WriteHigh outa[LCD_WR] := 1
instead of:
Cheers,
Tyler
Hey, bonus. Tempting to order 2000 and see what happens.
6 hours to go before work stops and soldering time starts
Thanks Again,
Tyler
Tyler
Tyler
CON RS = 16 ''PINS FOR CS - TO KEEP FROM FLOATING LCD_WR = 17 ''LCD REGISTERS REG_OSCILLATOR = $0000 ''Oscillator (R00h) (POR = 0000h) REG_DRIVEROUTPUTCONTROL = $0001 ''Driver Output Control (R01h) (POR = 2B3Fh) REG_LCDDRIVINGWAVFORM = $0002 ''LCD-Driving-Waveform Control (R02h) (POR = 0000h) REG_POWERCONTROL1 = $0003 '' (R03H) REG_DISPLAYCONTROL = $0007 ''Display Control (R07h) (POR = 0000h) REG_FRAMECYCLECONTROL = $000B ''Frame Cycle Control (R0Bh) (POR = 5308h)D308 BY DATASHEET REG_POWERCONTROL2 = $000C '' (R0Ch) (POR = 0004) REG_POWERCONTROL3 = $000D '' REG_POWERCONTROL4 = $000E '' REG_GATESCANPOSITION = $000F ''Gate Scan Position (R0Fh) (POR = 0000h) REG_SLEEPMODE = $0010 ''Sleep mode (R10h) (POR = 0001h) REG_ENTRYMODE = $0011 ''Entry Mode (R11h) (POR = 6830h) REG_HPORCH = $0016 '' (R16h) (POR = EF1Ch) REG_VPORCH = $0017 '' (R17h) (POR = 0003h) REG_POWERCONTROL5 = $001E '' REG_RAMDATAWRITE = $0022 '' REG_RAMWRITEDATAMASK1 = $0023 '' (R23h) (POR = 0000h) REG_RAMWRITEDATAMASK2 = $0024 '' (R24h) (POR = 0000h) REG_VERTICALSCROLCONTROL1 = $0041 '' (R41h) (POR = 0000h) REG_VERTICALSCROLCONTROL2 = $0042 '' (R42h) (POR = 0000h) REG_HORIZONTALRAMADDRESSPOS = $0044 '' (R44h) (POR = EF00h) REG_VERTICALRAMADDRESSSTART = $0045 '' (R45h) (POR = 0000h) REG_VERTICALRAMADDRESSEND = $0046 '' (R46h) (POR = 013Fh) REG_FIRSTWINDOWSTART = $0048 '' (R48h) (POR = 0000h) REG_FIRSTWINDOWEND = $0049 '' (R49h) (POR = 013Fh) REG_SECONDWINDOWSTART = $004A '' (R4Ah) (POR = 0000h) REG_SECONDWINDOWEND = $004B '' (R4Bh) (POR = 013Fh) REG_SETGDDRXADDRESSCOUNTER = $004E '' (R4Eh) (POR = 0000h) REG_SETGDDRYADDRESSCOUNTER = $004F '' (R4Fh) (POR = 0000h) FONT_ROM_ADDRESS = $8000 VAR long BackgroundColor,ActiveColor, ActiveTextColor, InactiveTextColor, Row, Col, RowBorder,ColBorder, WindowX1, WindowX2, WindowY1, WindowY2 'long obj wait : "timing" PUB Init_SSD1289 ''Init Display EnableDisplayPins ''enable pins 0 to 15 WriteHigh 'LCD_Reset ''reset screen 'wait.pause1ms(5) 'LCD_Reset ''then init screen 'wait.pause1ms(5) Lcd_Write_Com (REG_DISPLAYCONTROL) ''Display Control (R07h) (POR = 0000h) Lcd_Write_Data($0021) ''GON = 1 DTE = 0 D[1:0] = 01 Lcd_Write_Com (REG_OSCILLATOR) ''Oscillator (R00h) (POR = 0000h) Lcd_Write_Data($0001) ''Turn on oscillator Lcd_Write_Com (REG_DISPLAYCONTROL) ''Display Control (R07h) (POR = 0000h) Lcd_Write_Data($0023) ''GON = 1 DTE = 0 D[1:0] = 11 Lcd_Write_Com (REG_SLEEPMODE) ''Sleep mode (R10h) (POR = 0001h) Lcd_Write_Data($0000) '' ''exit sleep mode Lcd_Write_Com (REG_DISPLAYCONTROL) ''Display Control (R07h) (POR = 0000h) Lcd_Write_Data($0033) ''GON = 1 DTE = 1 D[1:0] = 11 Lcd_Write_Com (REG_ENTRYMODE) ''Entry Mode (R11h) (POR = 6830h) Lcd_Write_Data($6838) '' Lcd_Write_Com (REG_LCDDRIVINGWAVFORM) ''LCD-Driving-Waveform Control (R02h) (POR = 0000h)($1000) Lcd_Write_Data($1000) '' '' Lcd_Write_Com (REG_GATESCANPOSITION) ''Gate Scan Position (R0Fh) (POR = 0000h) ($0000) Lcd_Write_Data($0000) '' '' '' Lcd_Write_Com (REG_DRIVEROUTPUTCONTROL) ''Driver Output Control (R01h) (POR = [0XXXX0X1]3Fh) 433f ($633F) Lcd_Write_Data($6B3F) '' '' Lcd_Write_Com (REG_FRAMECYCLECONTROL) ''Frame Cycle Control (R0Bh) (POR = 5308h) ($5308) Lcd_Write_Data($5308) '' ' Lcd_Write_Com (REG_DISPLAYCONTROL) ''Display Control (R07h) (POR = 0000h) ($0033) Lcd_Write_Data($0033) ''GON = 1 DTE = 1 D[1:0] = 11 PUB WriteNextActiveCr(Character) | characterpointer, odd_even, bitpatern[32], idx, pxlidx, lcdidx, pxlidxdcd, x1, y1, x2, y2 odd_even := character & $0001 characterpointer := character & $fffe characterpointer >>= 1 characterpointer *= 32 repeat idx from 0 to 31 bitpatern[idx] := long[FONT_ROM_ADDRESS][characterpointer + idx] y1 := Col + ColBorder y2 := (Col + 15) - ColBorder x1 := Row + RowBorder x2 := (Row + 31) - RowBorder SetWindow(x1, y1, x2, y2) SetGAddress(x1,y1) repeat idx from RowBorder to 31 - RowBorder repeat pxlidx from odd_even + (ColBorder*2) to (odd_even + 30) - (ColBorder*2) step 2 pxlidxdcd := |< pxlidx if ((bitpatern[idx] & pxlidxdcd) == pxlidxdcd) Lcd_Write_Com(REG_RAMDATAWRITE) Lcd_Write_Data(ActiveTextColor) else Lcd_Write_Com(REG_RAMDATAWRITE) Lcd_Write_Data(BackgroundColor) if (((Col + 16) > 319 ) and ((Row + 32) > 223)) Row := 0 Col := 0 elseif (((Col + 16) > 319 ) and ((Row + 32) < 223)) Row := Row + 32 Col := 0 else Col := Col + 16 SetWindow(0, 0, 239, 319) PUB WriteActiveCr(Character, PosR, PosC, RBorder, CBorder, BgC, TxC) | characterpointer, odd_even, bitpatern[32], idx, pxlidx, lcdidx, pxlidxdcd, x1, y1, x2, y2 odd_even := character & $0001 characterpointer := character & $fffe characterpointer >>= 1 characterpointer *= 32 repeat idx from 0 to 31 bitpatern[idx] := long[FONT_ROM_ADDRESS][characterpointer + idx] Row := PosR Col := PosC RowBorder := RBorder ColBorder := CBorder BackgroundColor := BgC ActiveTextColor := Txc y1 := PosC + CBorder y2 := (PosC + 15) - CBorder x1 := PosR + RBorder x2 := (PosR + 31) - RBorder SetWindow(x1, y1, x2, y2) SetGAddress(x1,y1) repeat idx from RBorder to 31 - RBorder repeat pxlidx from odd_even + (CBorder*2) to (odd_even + 30) - (CBorder*2) step 2 pxlidxdcd := |< pxlidx if ((bitpatern[idx] & pxlidxdcd) == pxlidxdcd) Lcd_Write_Com(REG_RAMDATAWRITE) Lcd_Write_Data(TxC) else Lcd_Write_Com(REG_RAMDATAWRITE) Lcd_Write_Data(BgC) if (((Col + 16) > 319 ) and ((Row + 32) > 223)) Row := 0 Col := 0 elseif (((Col + 16) > 319 ) and ((Row + 32) < 223)) Row := Row + 32 Col := 0 else Col := Col + 16 SetWindow(0, 0, 239, 319) return PUB SetWindow(x1, y1, x2, y2) | HORIZONTALRAMADDRESSPOS WindowX1 := x1 WindowX2 := x2 WindowY1 := y1 WindowY2 := y2 HORIZONTALRAMADDRESSPOS := x1 + (x2 << 8) Lcd_Write_Com ( REG_HORIZONTALRAMADDRESSPOS) Lcd_Write_Data(HORIZONTALRAMADDRESSPOS) Lcd_Write_Com (REG_VERTICALRAMADDRESSSTART) Lcd_Write_Data(y1) Lcd_Write_Com (REG_VERTICALRAMADDRESSEND) Lcd_Write_Data(y2) PUB SetGAddress(x,y) Lcd_Write_Com (REG_SETGDDRxADDRESSCOUNTER) ''max %1111_1111, $FF Lcd_Write_Data(x) Lcd_Write_Com (REG_SETGDDRyADDRESSCOUNTER) ''max %1_0011_1111, $13f Lcd_Write_Data(y) PUB ClearScreen(color) | idxr, idxc Lcd_Write_Com (REG_SETGDDRxADDRESSCOUNTER) Lcd_Write_Data(0) Lcd_Write_Com (REG_SETGDDRyADDRESSCOUNTER) Lcd_Write_Data(0) repeat idxr from 0 to 76800 Lcd_Write_Com(REG_RAMDATAWRITE) Lcd_Write_Data(Color) Row := 0 Col := 0 PUB FillScreen(Color) | idxr, idxc Lcd_Write_Com (REG_SETGDDRxADDRESSCOUNTER) Lcd_Write_Data(0) Lcd_Write_Com (REG_SETGDDRyADDRESSCOUNTER) Lcd_Write_Data(0) repeat idxr from 0 to 76800 Lcd_Write_Com(REG_RAMDATAWRITE) Lcd_Write_Data(Color) Row := 0 Col := 0 PUB SetBG(Color) PUB SetFG(Color) PUB SetActive(Color) PUB SetInActive(Color) PUB SetRow(NewRow) PUB SetCol(NewCol) PUB EnableDisplayPins DIRA:=%00000001_11100011_11111111_11111111 ' , Reset, WR, RS and 16 data lines active PUB TristateDisplayPins ' tristate all pins - DIRA:=%00000001_11100010_00000000_00000000 '' PRI LCD_Writ_Bus(V) OUTA[15..0] := V WriteLow ' write pin low WriteHigh ' toggle write pin PRI Lcd_Write_Com(V) RSLow LCD_Writ_Bus(V) PRI Lcd_Write_Data(V) RSHigh LCD_Writ_Bus(V) PRI RSLow outa[RS] := 0 PRI RSHigh outa[RS] := 1 ' PRI WriteLow outa[LCD_WR] := 0 ' PRI WriteHigh outa[LCD_WR] := 1
I'm sorry that I have not commented this code yet. I need to finish abstraction as well. It seems to run ok, other than being a bit slow. I have some ideas for optimization, but have not started working it out. I am convinced that using 2 cogs running Pasm will speed up display writes significantly. Before I can work on asm I need to finish the spin code. This includes a working character based gui. The current top object looks something like this.CON _clkmode = xtal1 + pll16x ' use crystal x 16 _xinfreq = 5_000_000 ''PINS FOR LCD ''and sd card defs DEV_SD_CLK = 18 DEV_SD_DI = 19 DEV_SD_DO = 20 DEV_SPI_EN = 21 DEV_SPI_ADD0 = 22 DEV_SPI_ADD1 = 23 DEV_SPI_ADD_LE = 24 DEV_SPI_LCD_RES = 0 DEV_SPI_SDC_CS = 1 DEV_SPI_TSC_CS = 2 DEV_SPI_EXT_CS = 3 DEV_SPI_EXT_POT_CS = 0 DEV_SPI_EXT_SW_CS = 1 BGCOLOR = $ffff TXTCOLOR = $0000 NotPressedBGC = $ffff NotPressedATC = $0000 PressedBGC = $0000 PressedATC = $ffff Pressed = 1 NotPressed = 0 OBJ pfw : "PropFont" 'fat : "SD3.01_FATEngine.spin" ' thanks to Kye spi : "SPI_ASM" ' thanks to Beau wait : "timing" ' thanks to parallax pst : "Parallax Serial Terminal" VAR long stringptr[65], BackgroundColor, ActiveTextColor BYTE Fader0[3], Fader1[3], Fader2[3], Fader3[3], faderOrentation, faderpos, faderval, oldfader, ButtonName 'Fader POS, New Fader Value, Old Fader Value, FaderOrentation holds 0 for landscape, portrait not enabled word Button0[3], Button1[3], Button2[3], Button3[3], Button4[3], Button5[3], ButtonGroup, ButtonX, ButtonY, ButtonState PUB Bootstrap | f BackgroundColor := $ffff ActiveTextColor := %0000 pfw.EnableDisplayPins OUTA[DEV_SPI_EN] := 1 OUTA[DEV_SPI_ADD_LE] := 0 SPI.start(3,0) pfw.Init_SSD1289 pfw.ClearScreen(BackgroundColor) FaderTest ButtonTest deadend PST_Init PUB FaderTest | F Fader0[0] :=255 Fader0[1] := 0 Fader0[2] := 2 Fader1[0] := 0 Fader1[1] := 0 Fader1[2] := 54 Fader2[0] := 126 Fader2[1] := 0 Fader2[2] := 106 Fader3[0] := 192 Fader3[1] := 0 Fader3[2] := 161 REPEAT f from 0 to 3 SetFader(F) DrawFader 'Repeat REPEAT f from 0 to 3 SetFader(F) UpdateFader Fader0[1] := Fader0[0] Fader0[0] -= 1 PUB ButtonTest | b Button0[0] := 1 Button0[1] := 206 Button0[2] := 78 Button1[0] := 54 Button1[1] := 206 Button1[2] := 66 Button2[0] := 108 Button2[1] := 206 Button2[2] := 209 Button3[0] := 161 Button3[1] := 206 Button3[2] := 209 Button4[0] := 216 Button4[1] := 206 Button4[2] := 66 Button5[0] := 271 Button5[1] := 206 Button5[2] := 78 REPEAT b from 0 to 5 SetButton(b) Drawbutton(b) PUB SetFader(FaderNumber) case FaderNumber 0: faderval := Fader0[0] oldfader := Fader0[1] faderpos := Fader0[2] 1: faderval := Fader1[0] oldfader := Fader1[1] faderpos := Fader1[2] 2: faderval := Fader2[0] oldfader := Fader2[1] faderpos := Fader2[2] 3: faderval := Fader3[0] oldfader := Fader3[1] faderpos := Fader3[2] PUB UpdateFader 'layer 2 pfw.WriteActiveCr(6, faderpos, 2, 7, 0, BackgroundColor, ActiveTextColor) pfw.WriteActiveCr(7, faderpos, 301, 7, 0, BackgroundColor, ActiveTextColor) pfw.WriteActiveCr(32, faderpos, oldfader + 31, 4, 2, BackgroundColor, ActiveTextColor) pfw.WriteActiveCr(14, faderpos, faderval + 24, 4, 3, BackgroundColor, ActiveTextColor) PUB DrawFader |index 'layer 1 pfw.WriteActiveCr(1, faderpos, 0, 0, 0, BackgroundColor, ActiveTextColor) pfw.WriteActiveCr(9, faderpos, 7, 0, 0, BackgroundColor, ActiveTextColor) REPEAT 18 pfw.WriteNextActiveCr(13) pfw.WriteActiveCr(1, faderpos, 297, 0, 0, BackgroundColor, ActiveTextColor) pfw.WriteActiveCr(9, faderpos, 304, 0, 0, BackgroundColor, ActiveTextColor) PUB SetButton(Button) case Button 0: ButtonX := Button0[0] ButtonY := Button0[1] ButtonName := Button0[2] ButtonState := ButtonGroup & $01 1: ButtonX := Button1[0] ButtonY := Button1[1] ButtonName := Button1[2] ButtonState := ButtonGroup & $02 2: ButtonX := Button2[0] ButtonY := Button2[1] ButtonName := Button2[2] ButtonState := ButtonGroup & $04 3: ButtonX := Button3[0] ButtonY := Button3[1] ButtonName := Button3[2] ButtonState := ButtonGroup & $08 4: ButtonX := Button4[0] ButtonY := Button4[1] ButtonName := Button4[2] ButtonState := ButtonGroup & $10 5: ButtonX := Button5[0] ButtonY := Button5[1] ButtonName := Button5[2] ButtonState := ButtonGroup & 20 PUB DrawButton(Button) | x, y if ButtonState == Pressed pfw.WriteActiveCr(1, ButtonY, ButtonX, 0, 0, PressedBGC, PressedATC) pfw.WriteNextActiveCr(ButtonName) pfw.WriteNextActiveCr(9) else pfw.WriteActiveCr(1, ButtonY, ButtonX, 0, 0, NotPressedBGC, NotPressedATC) pfw.WriteNextActiveCr(ButtonName) pfw.WriteNextActiveCr(9)
That's the main portion of the code, some helper methods in the top object arePUB Enable_SDC OUTA[DEV_SPI_ADD1..DEV_SPI_ADD0] := DEV_SPI_SDC_CS ' OUTA[DEV_SPI_EN] := 1 PUB Disable_SDC OUTA[DEV_SPI_ADD1..DEV_SPI_ADD0] := DEV_SPI_SDC_CS ' OUTA[DEV_SPI_EN] := 1 PUB Set_Spi_Ext_Address(Ext_Spi_Address) OUTA[DEV_SPI_ADD1..DEV_SPI_ADD0] := DEV_SPI_EXT_CS wait.pause1ms(1) OUTA[DEV_SPI_ADD_LE] := 0 wait.pause1ms(1) SPI.SHIFTOUT(DEV_SD_DO, DEV_SD_CLK, 5, 3, Ext_Spi_Address) wait.pause1ms(1) OUTA[DEV_SPI_ADD_LE] := 1 wait.pause1ms(1) 'OUTA[DEV_SPI_ADD_LE] := 0 ' PUB Disable_SPI_EXT ' OUTA[DEV_SPI_EN] := 1 PUB StrobeCS OUTA[DEV_SPI_EN] := 0 wait.pause1ms(10) OUTA[DEV_SPI_EN] := 1 PUB TestTS | yval, xval,x,y Enable_Touch ''Old format was OUTA[TS_CS] := 0 ' enable the touch screen 'SPI.start(3,0) ' delay,state Already running? 'Shiftout = data,clock,mode,bits,value 'shiftin = data,clock,mode,bits 'SPI read S, A2, A1, A0, Mode, SER, PD1, PD0 ' 1 0 0 1 1 0 0 0 ' MSB first ' 001 is X ' 101 is Y repeat pst.clear SPI.SHIFTOUT(DEV_SD_DI, DEV_SD_CLK, 5, 8 , %1101_0000) ' reads x from 500 to 3700 (off < 500 ) xval := SPI.SHIFTIN(DEV_SD_DO, DEV_SD_CLK,2, 12) SPI.SHIFTOUT(DEV_SD_DI, DEV_SD_CLK, 5, 8 , %1001_0000) ' reads y from 400 to 3800 (off > 3800 ) yval := SPI.SHIFTIN(DEV_SD_DO,DEV_SD_CLK,2, 12) pst.Dec(xval) pst.newline pst.Dec(yval) wait.pause1ms(10) Disable_Touch ''Old format was OUTA[TS_CS] := 1 ' disable the touch screen PUB PST_Init | PstCog ''Starts Parallax Serial Terminal for debugging. PstCog := (pst.Start(115200) -1) '' returns the cog pst started in pst.Str(String("Parallax Serial Terminal started in cog ")) '' talk to human pst.Dec(PstCog) '' displays cog on PST '' wait.pause1s(2) '********************** private methods ********************* PRI Enable_Touch OUTA[DEV_SPI_ADD1..DEV_SPI_ADD0] := DEV_SPI_TSC_CS OUTA[DEV_SPI_EN] := 0 ' PRI Disable_Touch OUTA[DEV_SPI_ADD1..DEV_SPI_ADD0] := DEV_SPI_TSC_CS OUTA[DEV_SPI_EN] := 0 PRI LCD_Reset OUTA[DEV_SPI_ADD1..DEV_SPI_ADD0] := DEV_SPI_LCD_RES outa[DEV_SPI_EN] := 0 wait.pause1ms(5) ''wait here if necessary ' outa[DEV_SPI_EN] := 1
These are the basics. Once I get propfont finished, I'll re-write in asm which should speed up the display quite a bit. 12 seconds to display a blank screen is a bit too slow IMO. 4 sounds WAY more reasonable.I will also be using a pullup on RS. This will save some code too.
edit,
CON _clkmode = xtal1 + pll16x ' use crystal x 16 _xinfreq = 5_000_000 DEV_SPI_EN = 21 PUB BOOT 'bootstrap dirA[DEV_SPI_EN] := 1 OUTA[DEV_SPI_EN] := 1 cognew(@entry, 0) repeat wait.pause1s(5) DAT org 0 entry mov dira, DirsEnabled 'initalize pins mov outa, PinsInit 'and set write high 'then initalize display mov LCD_Data,asmREG_DISPLAYCONTROL ''Display Control (R07h) (POR = 0000h) call #writecmd mov LCD_Data,DISPLAYCONTROL0 '' GON = 1 DTE = 0 D[1:0] = 01 call #writedat mov LCD_Data,asmREG_OSCILLATOR ''Oscillator (R00h) (POR = 0000h) call #writecmd mov LCD_Data,OSCILLATOR ''Turn on oscillator call #writedat mov LCD_Data,asmREG_DISPLAYCONTROL ''Display Control (R07h) (POR = 0000h) call #writecmd mov LCD_Data,DISPLAYCONTROL1 ''GON = 1 DTE = 0 D[1:0] = 11 call #writedat mov LCD_Data,asmREG_SLEEPMODE ''Sleep mode (R10h) (POR = 0001h) call #writecmd mov LCD_Data,SLEEPMODE '' ''exit sleep mode call #writedat mov LCD_Data,asmREG_DISPLAYCONTROL ''Display Control (R07h) (POR = 0000h) call #writecmd mov LCD_Data,DISPLAYCONTROL2 ''GON = 1 DTE = 1 D[1:0] = 11 call #writedat mov LCD_Data,asmREG_ENTRYMODE ''Entry Mode (R11h) (POR = 6830h) call #writecmd mov LCD_Data,ENTRYMODE '' call #writedat mov LCD_Data,asmREG_LCDDRIVINGWAVFORM ''LCD-Driving-Waveform Control (R02h) (POR = 0000h)($1000) call #writecmd mov LCD_Data,DRIVINGWAVEFORM '' '' call #writedat mov LCD_Data,asmREG_GATESCANPOSITION ''Gate Scan Position (R0Fh) (POR = 0000h) ($0000) call #writecmd mov LCD_Data,GATESCANPOSITION '' call #writedat mov LCD_Data,asmREG_DRIVEROUTPUTCONTROL ''Driver Output Control (R01h) (POR = [0XXXX0X1]3Fh) 433f ($633F) call #writecmd mov LCD_Data,DRIVEROUTPUT '' call #writedat mov LCD_Data,asmREG_FRAMECYCLECONTROL ''Frame Cycle Control (R0Bh) (POR = 5308h) ($5308) call #writecmd mov LCD_Data,FRAMECYCLE '' call #writedat mov LCD_Data,asmREG_DISPLAYCONTROL ''Display Control (R07h) (POR = 0000h) ($0033) call #writecmd mov LCD_Data,DISPLAYCONTROL2 ''GON = 1 DTE = 1 D[1:0] = 11 call #writedat mov LCD_Data,asmREG_DISPLAYCONTROL ''Display Control (R07h) (POR = 0000h) ($0033) call #writecmd mov LCD_Data,DISPLAYCONTROL2 ''GON = 1 DTE = 1 D[1:0] = 11 call #writedat mov LCD_Data,asmREG_HORIZONTALRAMADDRESSPOS call #writecmd mov LCD_Data,asmHORIZONTALRAMADDRESSPOS call #writedat mov LCD_Data,asmREG_VERTICALRAMADDRESSSTART call #writecmd mov LCD_Data,#0 call #writedat mov LCD_Data,asmREG_VERTICALRAMADDRESSEND call #writecmd mov LCD_Data,239 call #writedat loop mov LCD_Data,asmREG_RAMDATAWRITE call #writecmd mov LCD_Data,asmColor call #writedat jmp #loop writecmd mov outa, LCD_Data wc nop muxc dira,RSpin nop muxnc dira,WritePin nop muxc dira,WritePin nop muxnc dira,RSpin nop writecmd_ret writedat mov outa, LCD_Data wc nop muxnc dira,WritePin nop muxc dira,WritePin nop writedat_ret asmColor long $0000 PinsInit long %00000000_00000000_00000000_00000000 DirsDisabled long %00000000_00000000_11111111_11111111 DirsEnabled long %00000000_00000000_11111111_11111111 BackgroundColorASM long $ffff ActiveColorASM long $0000 WritePin long %00000000_00000010_00000000_00000000 RSPin long %00000000_00000001_00000000_00000000 GATESCANPOSITION long $0000_0000 SLEEPMODE long $0000_0000 OSCILLATOR long $0000_0001 DISPLAYCONTROL0 long $0000_0021 DISPLAYCONTROL1 long $0000_0023 DISPLAYCONTROL2 long $0000_0033 FRAMECYCLE long $0000_5308 DRIVEROUTPUT long $0000_6B3F DRIVINGWAVEFORM long $0000_1000 ENTRYMODE long $0000_6838 asmXADDRESSCOUNTER long $0000_0000 asmHORIZONTALRAMADDRESSPOS long $0001_3F00 asmREG_OSCILLATOR long $0000_0000 ''Oscillator (R00h) (POR = 0000h) asmREG_DRIVEROUTPUTCONTROL long $0000_0001 ''Driver Output Control (R01h) (POR = 2B3Fh) asmREG_LCDDRIVINGWAVFORM long $0000_0002 ''LCD-Driving-Waveform Control (R02h) (POR = 0000h) asmREG_POWERCONTROL1 long $0000_0003 '' (R03H) asmREG_DISPLAYCONTROL long $0000_0007 ''Display Control (R07h) (POR = 0000h) asmREG_FRAMECYCLECONTROL long $0000_000B ''Frame Cycle Control (R0Bh) (POR = 5308h)D308 BY DATASHEET asmREG_POWERCONTROL2 long $0000_000C '' (R0Ch) (POR = 0004) asmREG_POWERCONTROL3 long $0000_000D '' asmREG_POWERCONTROL4 long $0000_000E '' asmREG_GATESCANPOSITION long $0000_000F ''Gate Scan Position (R0Fh) (POR = 0000h) asmREG_SLEEPMODE long $0000_0010 ''Sleep mode (R10h) (POR = 0001h) asmREG_ENTRYMODE long $0000_0011 ''Entry Mode (R11h) (POR = 6830h) asmREG_HPORCH long $0000_0016 '' (R16h) (POR = EF1Ch) asmREG_VPORCH long $0000_0017 '' (R17h) (POR = 0003h) asmREG_POWERCONTROL5 long $0000_001E '' asmREG_RAMDATAWRITE long $0000_0022 '' asmREG_RAMWRITEDATAMASK1 long $0000_0023 '' (R23h) (POR = 0000h) asmREG_RAMWRITEDATAMASK2 long $0000_0024 '' (R24h) (POR = 0000h) asmREG_VERTICALSCROLCONTROL1 long $0000_0041 '' (R41h) (POR = 0000h) asmREG_VERTICALSCROLCONTROL2 long $0000_0042 '' (R42h) (POR = 0000h) asmREG_HORIZONTALRAMADDRESSPOS long $0000_0044 '' (R44h) (POR = EF00h) asmREG_VERTICALRAMADDRESSSTART long $0000_0045 '' (R45h) (POR = 0000h) asmREG_VERTICALRAMADDRESSEND long $0000_0046 '' (R46h) (POR = 013Fh) asmREG_FIRSTWINDOWSTART long $0000_0048 '' (R48h) (POR = 0000h) asmREG_FIRSTWINDOWEND long $0000_0049 '' (R49h) (POR = 013Fh) asmREG_SECONDWINDOWSTART long $0000_004A '' (R4Ah) (POR = 0000h) asmREG_SECONDWINDOWEND long $0000_004B '' (R4Bh) (POR = 013Fh) asmREG_SETGDDRXADDRESSCOUNTER long $0000_004E '' (R4Eh) (POR = 0000h) asmREG_SETGDDRYADDRESSCOUNTER long $0000_004F '' (R4Fh) (POR = 0000h) LCD_data res 1
'init display in spin, tristate pins, and pass to ASM cognew(@entry, 0) repeat wait.pause1s(5) DAT org 0 entry mov outa, PinsInit mov dira, DirsEnabled :loop mov LCD_Data,#$22 add zero,#0 wz nop muxz dira,RSpin nr nop muxnz outa,RSpin nr nop mov outa,LCD_Data nr nop muxz dira,WritePin nr nop muxnz dira,WritePin nr nop muxnz dira,RSpin nr nop mov LCD_Data,#$22 add zero,#0 wz nop muxnz dira,RSpin nr nop mov outa, #LCD_Data nr nop muxz dira,WritePin nr nop muxnz dira,WritePin nr nop jmp #:loop
Should write characters. Maybe it's running too fast? I don't know ASM very well at all. Any help would be appreciated!Thanks Kuroneko, I'll try again. Not very good @asm.
Thanks for your help,
Tyler
DAT org 0 entry mov outa, PinsInit 'and set write high mov dira, DirsEnabled WrCmd mov outa,#$22 add zero,#0 wz muxz dira,RSpin ' add pntr, #2 ':wait1 djnz pntr, :wait1 muxz dira,WritePin add pntr, #16 :wait2 djnz pntr, :wait2 muxnz dira,WritePin add pntr, #5 :wait3 djnz pntr, :wait3 muxnz dira,RSpin WrDat mov outa,asmColor add zero,#0 wz add pntr, #4 :wait1 djnz pntr, :wait1 muxz dira,WritePin add pntr, #16 :wait3 djnz pntr, :wait3 muxnz dira,WritePin add pntr, #5 :wait2 djnz pntr, :wait2 ' 'sub asmColor,#1 'max asmColor, BackgroundColorASM ' add pntr,waittime ':wait5 djnz pntr, :wait5 jmp #WrCmd
I hooked the sd card on my screen back up, but I haven't tested it yet. Now that spin code works, I'm going to investigate again. The hardware mods work great. Getting ASM working was top priority, now on to sd card!*edit*
is it?
or?
PUB BOOT |cr 'bootstrap dirA[DEV_SPI_ADD0] := 1 dirA[DEV_SPI_ADD1] := 1 dirA[DEV_SPI_EN] := 1 OUTA[LCD_WR] := 0 OUTA[RS] := 0 OUTA[DEV_SPI_EN] := 1 OUTA[DEV_SPI_ADD_LE] := 0 PST_Init Init_SSD1289 pst.str(string("init done, clearing screen")) pst.newline EnableDisplayPins FillScreen($0000) pst.str(string("clear, tri-stating pins")) pst.newline TristateDisplayPins pst.str(string("tri-stated pins, starting cog with screen buffer address")) pst.newline pst.dec(@screenbuffer) pst.newline pst.dec(@@screenbuffer) cr := (cognew(@entry,@long[screenbuffer])+ 1) pst.dec(cr) pst.newline pst.str(string("waiting")) pst.newline 'StartAsm repeat repeat while (long[screenbuffer] <> 0) pst.str(string("waiting")) pst.newline wait.pause1s(1) pst.str(string("done")) PUB PST_Init | PstCog ''Starts Parallax Serial Terminal for debugging. PstCog := (pst.Start(115200) -1) '' returns the cog pst started in pst.Str(String("Parallax Serial Terminal started in cog ")) '' talk to human pst.Dec(PstCog) '' displays cog on PST '' wait.pause1s(1) PUB SetWindow(x1, y1, x2, y2) | HORIZONTALRAMADDRESSPOS WindowX1 := x1 WindowX2 := x2 WindowY1 := y1 WindowY2 := y2 HORIZONTALRAMADDRESSPOS := x1 + (x2 << 8) Lcd_Write_Com (REG_HORIZONTALRAMADDRESSPOS) Lcd_Write_Data(HORIZONTALRAMADDRESSPOS) Lcd_Write_Com (REG_VERTICALRAMADDRESSSTART) Lcd_Write_Data(y1) Lcd_Write_Com (REG_VERTICALRAMADDRESSEND) Lcd_Write_Data(y2) PUB SetGAddress(x,y) Lcd_Write_Com (REG_SETGDDRxADDRESSCOUNTER) ''max %1111_1111, $FF Lcd_Write_Data(x) Lcd_Write_Com (REG_SETGDDRyADDRESSCOUNTER) ''max %1_0011_1111, $13f Lcd_Write_Data(y) PUB ClearScreen(color) | idxr, idxc SetWindow(0, 0, 239, 319) SetGAddress(0,0) repeat idxr from 0 to 76240 Lcd_Write_Com(REG_RAMDATAWRITE) Lcd_Write_Data(Color) Row := 0 Col := 0 PUB FillScreen(Color) | idxr, idxc SetWindow(0, 0, 239, 319) SetGAddress(0,0) repeat idxr from 0 to 76240 Lcd_Write_Com(asmREG_RAMDATAWRITE) Lcd_Write_Data(Color) Row := 0 Col := 0 PUB EnableDisplayPins DIRA:=%00000001_11100000_11111111_11111111 ' , Reset, WR, RS and 16 data lines active PUB TristateDisplayPins ' tristate all pins - DIRA:=%00000001_11100000_00000000_00000000 '' PRI Lcd_Write_Asm(V) 'handler for asm writes long[screenbuffer] := V 'makes screen buffer = v PRI LCD_Writ_Bus(V) OUTA[15..0] := V WriteLow ' write pin low WriteHigh ' toggle write pin PRI Lcd_Write_Com(V) RSLow LCD_Writ_Bus(V) PRI Lcd_Write_Data(V) RSHigh LCD_Writ_Bus(V) PRI RSLow dira[RS] := 1 PRI RSHigh dira[RS] := 0 ' PRI WriteLow dira[LCD_WR] := 1 ' PRI WriteHigh dira[LCD_WR] := 0 pub deadend repeat wait.pause1s(1) PUB EnableDisplayPins DIRA:=%00000001_11100000_11111111_11111111 ' , Reset, WR, RS and 16 data lines active PUB TristateDisplayPins ' tristate all pins - DIRA:=%00000001_11100000_00000000_00000000 '' PRI Lcd_Write_Asm(V) 'handler for asm writes long[screenbuffer] := V 'makes screen buffer = v PRI LCD_Writ_Bus(V) OUTA[15..0] := V WriteLow ' write pin low WriteHigh ' toggle write pin PRI Lcd_Write_Com(V) RSLow LCD_Writ_Bus(V) PRI Lcd_Write_Data(V) RSHigh LCD_Writ_Bus(V) PRI RSLow dira[RS] := 1 PRI RSHigh dira[RS] := 0 ' PRI WriteLow dira[LCD_WR] := 1 ' PRI WriteHigh dira[LCD_WR] := 0 pub deadend repeat wait.pause1s(1) PUB Init_SSD1289 ''Init Display EnableDisplayPins ''enable pins 0 to 15 ' WriteHigh 'LCD_Reset ''reset screen 'wait.pause1ms(5) 'LCD_Reset ''then init screen 'wait.pause1ms(5) Lcd_Write_Com (REG_DISPLAYCONTROL) ''Display Control (R07h) (POR = 0000h) Lcd_Write_Data($0021) ''GON = 1 DTE = 0 D[1:0] = 01 Lcd_Write_Com (REG_OSCILLATOR) ''Oscillator (R00h) (POR = 0000h) Lcd_Write_Data($0001) ''Turn on oscillator Lcd_Write_Com (REG_DISPLAYCONTROL) ''Display Control (R07h) (POR = 0000h) Lcd_Write_Data($0023) ''GON = 1 DTE = 0 D[1:0] = 11 Lcd_Write_Com (REG_SLEEPMODE) ''Sleep mode (R10h) (POR = 0001h) Lcd_Write_Data($0000) '' ''exit sleep mode Lcd_Write_Com (REG_DISPLAYCONTROL) ''Display Control (R07h) (POR = 0000h) Lcd_Write_Data($0033) ''GON = 1 DTE = 1 D[1:0] = 11 Lcd_Write_Com (REG_ENTRYMODE) ''Entry Mode (R11h) (POR = 6830h) Lcd_Write_Data($6838) '' Lcd_Write_Com (REG_LCDDRIVINGWAVFORM) ''LCD-Driving-Waveform Control (R02h) (POR = 0000h)($1000) Lcd_Write_Data($1000) '' '' Lcd_Write_Com (REG_GATESCANPOSITION) ''Gate Scan Position (R0Fh) (POR = 0000h) ($0000) Lcd_Write_Data($0000) '' '' '' Lcd_Write_Com (REG_DRIVEROUTPUTCONTROL) ''Driver Output Control (R01h) (POR = [0XXXX0X1]3Fh) 433f ($633F) Lcd_Write_Data($6B3F) '' '' Lcd_Write_Com (REG_FRAMECYCLECONTROL) ''Frame Cycle Control (R0Bh) (POR = 5308h) ($5308) Lcd_Write_Data($5308) '' ' Lcd_Write_Com (REG_DISPLAYCONTROL) ''Display Control (R07h) (POR = 0000h) ($0033) Lcd_Write_Data($0033) ''GON = 1 DTE = 1 D[1:0] = 11 'TristateDisplayPins 'deadend DAT 'init org 0 entry mov outa, PinsInit 'set pins to inital state mov dira, DirsEnabled 'enables p0 - p15 mov bufferaddress, par 'store par in bufferaddress, par is screen buffer address at startup 'wrlong zero, bufferaddress 'set par to zero to confirm load done 'get write command from buffer, and check if it's 0 'Get rdlong LCD_cmd, bufferaddress 'get long from main memory and put it in ldc command, msW = LCD cmd, LSw = LCD data ' cmp Lcd_cmd, #0 wz 'and check if it's 0 'if_z jmp #get 'if it is, try again. 'if not, prepare transfer ' mov LCD_Data, LCD_cmd 'copy lcd command to lcd data ' and LCD_Data, lowWordMask 'mask off High word of Lcd_Data ' shr LCD_cmd, #16 'move lcd command 16 bit to the right if not gddr write ' cmp LCD_cmd, #22 wz 'check to see if this is a gddr write 'if_nz jmp WRcmd 'optimized write to display, for gddr transfer WrCmdfix mov outa,#$22 add zero,#0 wz muxz dira,RSpin add pntr, #6 :wait1 djnz pntr, :wait1 muxz dira,WritePin add pntr, #16 :wait2 djnz pntr, :wait2 muxnz dira,WritePin add pntr, #5 :wait3 djnz pntr, :wait3 muxnz dira,RSpin WrDatafix mov outa,#$1ff add zero,#0 wz add pntr, #6 :wait1 djnz pntr, :wait1 muxz dira,WritePin add pntr, #16 :wait3 djnz pntr, :wait3 muxnz dira,WritePin add pntr, #5 :wait2 djnz pntr, :wait2 ' 'sub asmColor,#1 ' max asmColor, BackgroundColorASM add pntr,#16 :wait5 djnz pntr, :wait5 wrlong zero, bufferaddress jmp #WrCmdfix zero long $0 waittime long $6 asmColor long $0000_ffff PinsInit long %00000000_00000000_00000000_00000000 DirsDisabled long %00000000_00000000_00000000_00000000 DirsEnabled long %00000000_00000000_11111111_11111111 BackgroundColorASM long $0000_ffff ActiveColorASM long $0000 WritePin long %00000000_00000010_00000000_00000000 RSPin long %00000000_00000001_00000000_00000000 lowWordMask long $0000_ffff GATESCANPOSITION long $0000_0000 SLEEPMODE long $0000_0000 OSCILLATOR long $0000_0001 FRAMECYCLE long $0000_5308 DRIVEROUTPUT long $0000_6B3F DRIVINGWAVEFORM long $0000_1000 ENTRYMODE long $0000_6838 DISPLAYCONTROL0 long $0000_0021 DISPLAYCONTROL1 long $0000_0023 DISPLAYCONTROL2 long $0000_0033 asmXADDRESSCOUNTER long $0000_0000 asmHORIZONTALRAMADDRESSPOS long $0001_3F00 asmREG_OSCILLATOR long $0000_0000 ''Oscillator (R00h) (POR = 0000h) asmREG_DRIVEROUTPUTCONTROL long $0000_0001 ''Driver Output Control (R01h) (POR = 2B3Fh) asmREG_LCDDRIVINGWAVFORM long $0000_0002 ''LCD-Driving-Waveform Control (R02h) (POR = 0000h) asmREG_POWERCONTROL1 long $0000_0003 '' (R03H) asmREG_DISPLAYCONTROL long $0000_0007 ''Display Control (R07h) (POR = 0000h) asmREG_FRAMECYCLECONTROL long $0000_000B ''Frame Cycle Control (R0Bh) (POR = 5308h)D308 BY DATASHEET asmREG_POWERCONTROL2 long $0000_000C '' (R0Ch) (POR = 0004) asmREG_POWERCONTROL3 long $0000_000D '' asmREG_POWERCONTROL4 long $0000_000E '' asmREG_GATESCANPOSITION long $0000_000F ''Gate Scan Position (R0Fh) (POR = 0000h) asmREG_SLEEPMODE long $0000_0010 ''Sleep mode (R10h) (POR = 0001h) asmREG_ENTRYMODE long $0000_0011 ''Entry Mode (R11h) (POR = 6830h) asmREG_HPORCH long $0000_0016 '' (R16h) (POR = EF1Ch) asmREG_VPORCH long $0000_0017 '' (R17h) (POR = 0003h) asmREG_POWERCONTROL5 long $0000_001E '' asmREG_RAMDATAWRITE long $0000_0022 '' asmREG_RAMWRITEDATAMASK1 long $0000_0023 '' (R23h) (POR = 0000h) asmREG_RAMWRITEDATAMASK2 long $0000_0024 '' (R24h) (POR = 0000h) asmREG_VERTICALSCROLCONTROL1 long $0000_0041 '' (R41h) (POR = 0000h) asmREG_VERTICALSCROLCONTROL2 long $0000_0042 '' (R42h) (POR = 0000h) asmREG_HORIZONTALRAMADDRESSPOS long $0000_0044 '' (R44h) (POR = EF00h) asmREG_VERTICALRAMADDRESSSTART long $0000_0045 '' (R45h) (POR = 0000h) asmREG_VERTICALRAMADDRESSEND long $0000_0046 '' (R46h) (POR = 013Fh) asmREG_FIRSTWINDOWSTART long $0000_0048 '' (R48h) (POR = 0000h) asmREG_FIRSTWINDOWEND long $0000_0049 '' (R49h) (POR = 013Fh) asmREG_SECONDWINDOWSTART long $0000_004A '' (R4Ah) (POR = 0000h) asmREG_SECONDWINDOWEND long $0000_004B '' (R4Bh) (POR = 013Fh) asmREG_SETGDDRXADDRESSCOUNTER long $0000_004E '' (R4Eh) (POR = 0000h) asmREG_SETGDDRYADDRESSCOUNTER long $0000_004F '' (R4Fh) (POR = 0000h) currentwait res 1 bufferaddress res 1 Longin res 1 LCD_cmd res 1 LCD_data res 1 Pntr res 1 c res 1
it runs. screen clears slowly, then displays wait for 50 +seconds. Then draws, and done? is there some way to start a cog faster?*edit* PST displays this
er address
3292
163
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
waiting
donedonedonedonedonedonedonedonedonedonedonedo
init done, clearing screenclear, tri-stating pins
er address
3292
163
waiting * 52 times then..
*edit* Fixed it..
I can be so dumb sometimes. Changed first wait to
to the RIGHT onemov pntr, #6 :wait1 djnz pntr, :wait1
PUB Propfont ' use propeller font in the rom for bootup messages when debugging sd cards curx := 0 ' set cursor to top left of screen (common variable) cury := 0 Propfont_string(string("Loading SD")) ' string to send Propfont_string(string("Loading Font")) PUB Propfont_string(stringptr) 'print at curx,cury repeat strsize(stringptr) ILI9325.draw(curx,cury,curx+15,cury+31) ' location to start drawing Propfont_out(byte[stringptr++]) curx +=16 curx := 0 cury += 32 ' new line at end of string PUB Propfont_out(ascii) | address,pixels address := $8000 + (ascii >> 1) << 7 ' get rom address repeat 32 ' 32 rows per character, split in two parts pixels := long[address] ' get rom font data pixels := pixels >> (ascii & 1) ' shift for odd characters repeat 16 ' 16 columns if pixels & 1 ILI9325.pixel(%00000111_11100000) ' foreground color RRRRRGGG_GGGBBBBB else ILI9325.pixel(%00000000_00000000) ' background color pixels := pixels >> 2 ' alternate pixels interleaved so shift 2 address += 4 'increment address by 4 bytes
