MIDI-to-USB doesn't play well with Prop Plug
I have a cheapo generic MIDI-to-USB interface connected between a MIDI keyboard and my laptop. When I press a key on the keyboard, a green LED on the MIDI-USB device flashes and the software on the laptop makes a sound. So far so good. Unfortunately, when I plug in a Prop Plug (with a live Propeller on the other end), the MIDI-USB device stops working (no more green flash, no sound).
Any ideas to get both the MIDI-USB and Prop Plug working concurrently?
EDIT: It's working now. Apparently I had a bad solder joint.
EDIT2: Actually, it appears that the problem is in the MIDI-USB box. I have two of them and only one has the problem.
Does the MIDI-USB adapter emulate a serial port? If so, it could be that both it and your PropPlug are using the same COM port number. In that case, just reassign one of them.
This was my thought as well. I think it would pretty much have to, as MIDI data is a set 31250 baud. At least that's the way it works on a Roland I have, where the driver is assigned to a COM port.
-- Gordon
Apparently there's still some subtle difference between my Propeller's MIDI OUT and "regular" MIDI OUT.
If you suspect a hardware incompatibility, you could try going back to the 5V circuit, with two 220R resistors, and use a 74HCT buffer or transistor inverter driven by the Prop.
