Square wave problem — Parallax Forums
Square wave problem
CenlasoftCenlasoft Posts: 265
edited 2012-02-28 06:48 in Propeller 1
Hello,
I am trying to use an ultrasonic TX and I have attached a schematic showing the circuit I built. I simply using pin 0 to send out a square wave that is .5ms in duration with an interval of 20 ms. It is a continuous wave. It works for about 45 sec to 1 min and then stops. I checked this with a scope with the ultrasonic sensor and without. The prop simply stops sending the square wave. If I press reset on the prop it starts again.
Thanks for any help.
Cenlasoft
  • CircuitsoftCircuitsoft Posts: 1,166
    edited 2012-02-21 10:33
    Can you post your code? The circuit looks fine.
  • MagIO2MagIO2 Posts: 2,243
    edited 2012-02-21 11:24
    Wait nother 50 sec and it propably starts again. Sounds like a waitcnt-problem. But to be sure you should post the code - if it's more than a short program, attach a zipped version.
    Another idea would be a recursion in your program which eats up the whole HUB-RAM.
  • groggorygroggory Posts: 205
    edited 2012-02-21 11:52
    Cenlasoft wrote: »
    Hello,
    Cenlasoft
    Try disconnecting this circuit completely...
    Then running your prop program and puttnig your square wave pin on your scope and see if it'll keep working beyond the 45s-1min. If it is still working, then this circuit is the problem.
    If this is the case I'm betting it has something to do with an interaction with the speaker/ transducer and your hex inverter. If you're using a piezo speaker perhaps you're hitting a natural frequency of it and it's overdriving the hex inverter and it's heating up and then going into shutdown? ...not sure.
    What do you think?
    edited 2012-02-21 12:48
    I'm voting for a software issue regarding use of waitcnt.
  • CenlasoftCenlasoft Posts: 265
    edited 2012-02-21 14:27
    Thanks for your suggestions. I tried sending a square wave using a signal generator set to 3.3 v and 40 khz. It did not fail. I have listed the code below:
    USTX.spin
    Curtis Desselles
    Con
    _clkmode = xtal1 + pll16x
    _xinfreq = 5_000_000
    freqPin = 0
    NewFreq = 40_000
    Var
    long stack1[32]
    Obj
    Pub Main
    cognew(US_out(freq_Pin),stack1)
    PUb US_out(fpin) | t
    '' US pulse generator
    '' -- uses ctra to modulate pin at 40kHz
    ctra := (%00100 << 26) | fpin
    frqa := 2_147_483 ' 40kHz @ 80MHz system freq
    dira[fpin] := 1
    t := cnt
    repeat
    outa[fpin] := 0 ' allow modulation
    waitcnt(t += (clkfreq / 1_000_000 * 500)) ' on 0.5ms
    outa[fpin] := 1 ' kill modulation
    waitcnt(t += (clkfreq / 1_000 * 18)) ' off 19.5ms
    edited 2012-02-21 14:49
    edited 2012-02-21 15:51
    Here is code properly displayed, thanks Phil:
      USTX.spin
      Curtis Desselles
    Con
     freqPin = 0
     NewFreq = 40_000
    Var
     long stack1[32]
    Obj
    Pub Main
      dira[fpin] := 1
      t := cnt
      repeat
    edited 2012-02-21 16:21
    Pub Main
      cognew(US_out([COLOR="orange"]freqPin[/COLOR]),[COLOR="red"]@[/COLOR]stack1)
    edited 2012-02-21 17:36
    Thanks kuroneko, I don't know how I missed that. It works now. I wonder how it worked for 1 min before?
    Cenlasoft
  • w8anw8an Posts: 176
    edited 2012-02-21 18:30
    Seems like it would be a good idea to put some kind of procedure after the cognew(...) so that cog 0 doesn't go into some unknown free running state...
    Pub Main
         cognew(US_out(freqPin),@stack1)
         repeat
    Cenlasoft wrote: »
    You basically placed your stack at address 0 in hub which definitely affects clkfreq (long[0]). If you'd waited slightly longer the pulse train would have restarted.
    @w8an: cog 0 just stops when it reaches the end of the main method (provided no-one messed with its stack).
    edited 2012-02-21 18:41
    Noted
    Thanks everyone for helping with this problem. In the circuit schematic (attached) that I posted, I want to tap in at one of the two traces going into the ultrasonic sensor. Basically I want to send a pulse (.5 ms, 20 ms interval) The amplitude is 10 vpp, At the tap point, I want to wait for a return pulse and measure the time of flight. I know how to do the spin code for that but, I don't want to burn my prop pin with the incoming signal pulse. The incoming signal pulse will be amplified using a 358 dual op amp which I have done already. It gives me a 2 vpp output. Any help with the circuit or code is appreciated.
    Cenlasoft
