transistor gate question
Im trying to understand how to select proper gate parameters for a transistor. I have a basic stamp 2. The max output of an i/o pin i think is 20ma, which doesnt seem like enough to "open" the transistor(2n3904) all the way. I can connect the solenoid to vdd,vss,(5 v), and it closes properly. The coil resistance is 108 ohms, 5 volts. which would need .05 amp to activate solenoid. The continous current rating of the transistor is .2 amps. My understanding of transistors is the more current applied to the gate or base , the more the "electrical valve"opens up. Is this correct?
2N3904, NPN, bipolar -- it's base current
Thanks, PJ! (Is it beer time yet?)
Vcbo-40v
Vceo-40v
Vebo-5v
Ic-3a
ft-3mgz
dissipation 20w
h(sub-e) min-10-50
.....are the gate threshold and saturation points in these figures?
Gain values:
min max hFE(1) VCE=1V, IC=0.1mA 40 - - hFE(2) VCE=1V, IC=1mA 70 - - hFE(3) VCE=1V, IC=10mA 100 - 300 hFE(4) VCE=1V, IC=50mA 60 - - hFE(5) VCE=1V, IC=100mA 30 - -
As PhiPi says, 5ma into the base will give you more than enough gain to switch 50ma as this is only a gain of 10.
