Rip ppdb
rogersyd
Well, I never thought I could be so careless, but the magic smoke has been released from my PPDB. Not a good way to start the weekend.
Speaking of which, any chance of resurrection? Looks like localized smoke. Sometimes the weakest (and hopefully replaceable) link lays down his life that other parts in the chain may live.
I looked on my board to see what the little black chip was. It's a yellow tantalum capacitor. So the cap is shot and maybe the voltage regulator. Both very replacable.
Becareful if you need to remove the voltage regulator. I pulled some traces when I replaced one on a Prop Proto board. Hot air or ChipQuik should be able to remove it without damage to the board.
John Abshier
So the tantalum threw a tantarum. Pa-dum-pum! Tip your waitresses, I'll be here all week. Thanks, you've been great...
Nick in support suggested I just remove what was left of the cap. Pliers sufficed.
She is working like a champ once again.
Thanks again all.
Should I bother to replace that cap? I would imagine it was there for a reason...
According to the PPDB schematic, this cap would appear to be C2 (10uF) that sits on the output of the +5V regulator VR2.
Yes - definitely replace it.
How to tell proper orientation? Use an Ohm meter to check for continuity to ground on one of the C2 pads.
A side note: I find it interesting that 4 other occurrences of this have happened, just from the previous posts.
Failure analysis time?
I haven't checked the shematic yet, but it sure looks like it's connected to the 5V reg and the power jack.
Edit: After looking at the schematic, I'm sure of it now. It's C1 the input on the 5V regulator. I'm guessing low quality wall-warts are to blame for the failures. A lot of wall-warts' outputs don't match the specs printed on them.
I defer to your account, as I don't physically have a PPDB; was basing my presumption on the location of the cap in the photo.
Either way - it would be a good thing to replace the cap.
I agree.
And I'd like to discourage the use of pliers for removing surface mount components. Components this small can be removed with a soldering iron. If need be, melt a bunch of solder so the solder is touching both sides of the component and it should just slide off.
Taking components off without heating them up is an easy way to pull traces on the circuit board.
same
So using a hammer is "right out" ?
The failure in this instance was mine. The battery pack I loaded with AAs and connected to her was configured with a center negative plug. I don't ever recall soldering it up that way, but that may explain why it was at the bottom of my parts bin. I will never assume the polarity of a power supply again. Lesson learned. It was a dopey move on my part.
Sounds prudent to replace the cap. Ill be sure to do that.
Thanks again all for the advice.
If nothing else, the cap's fireworks show provided a clear alert that something (polarity or other) was wrong, thus prompting you to immediately remove power. It may have acted as a fuse and protected something more critical downstream. Without it, next time you may leave power on for a longer time and do some real damage. Like it or not, there's always a next time. Pretty cheap insurance IMHO.
The PPDB costs $150.
How much does a cap cost? A nickel?
John Abshier
Peace of mind: Priceless
I would imagine that the PPDB was designed for real professionals who wouldn't do such a dopey thing, so there was probably no design requirement to make the thing idiot proof.
I am presuming that was intended 'tongue-in-cheek'?
I will need a multichannel high voltage controller for this, and a grab bag of cheap low-voltage semiconductors...
Anyway.... Does anyone have a part number for the Capacitor in question?
Looking at the position on the board between the two regulators and the schematic I would say this is the c2 cap.
I'll try just removing for now, but would like to replace it.
Just seems more like it's C2....
Follow the traces on the board. The cap in question has a thick trace that travels to the switch in one direction and the right pin on the 5V regulator in the other direction (the trace passes under all three pins).
The larger cap under the 5V regulator in connected to its center pin (output) which is also connected to the right pin on the 3.3V. This larger cap is C2.
Do you need help finding a replacement at Digi-Key? I know I've purchased tantalums about this size from them before. I could run through their search engine if your not familiar with the different terms (it took me a while to figure it out). I don't know what the voltage rating on C1 is. I couldn't read it on my PPDB. I think I'd try to find a cap with 20V or more rating. I would have thought the C1 cap would be a higher voltage rating than C2 but C2 is larger which I associate (probably incorrectly) with a higher capacity or higher voltage rating. Since both C1 and C2 are 10uF, I don't understand why C2 is larger than C1.
