IF... THEN... ELSE syntax help needed.
Im looking for some help on the IF
THEN
ELSE syntax. Im trying to look at the status of three input pins and then change some output pins if a certain condition exists. Below is my source file. Can anyone tell me what Im doing wrong?
Main:
IF IN5=0 THEN GPOHI
ELSEIF
IN6=0 THEN GPOHI
ELSEIF
IN7=1 THEN GPOHI
ELSE GPOLO
ENDIF
GOTO Main
END
GPOHI:
HIGH 15 'Energize relay 1
HIGH 14 'Energize relay 2
HIGH 13 'Energize relay 3
GOTO Main
GPOLO:
LOW 15 'Relax relay 1
LOW 14 'Relax relay 2
LOW 13 'Relax relay 3
GOTO Main
Main:
IF IN5=0 THEN GPOHI
ELSEIF
IN6=0 THEN GPOHI
ELSEIF
IN7=1 THEN GPOHI
ELSE GPOLO
ENDIF
GOTO Main
END
GPOHI:
GOTO Main
GPOLO:
GOTO Main
IF IN7=1
You left out two IF statements.
' {$STAMP BS2} ' {$PBASIC 2.5} Main: IF (IN5=0) THEN GOTO GPOHI ELSEIF(IN6=0) THEN GOTO GPOHI ELSEIF (IN7=1) THEN GOTO GPOHI ELSE GOTO GPOLO ENDIF GOTO Main END GPOHI: HIGH 15 'Energize relay 1 HIGH 14 'Energize relay 2 HIGH 13 'Energize relay 3 GOTO Main GPOLO: LOW 15 'Relax relay 1 LOW 14 'Relax relay 2 LOW 13 'Relax relay 3 GOTO MainIF IN5=0 THEN GPOHI
IF IN6=0 THEN GPOHI
IF IN7=1 THEN GPOHI
GOTO GPOLO
or:
Main:
IF IN5=0 OR IN6=0 OR IN7=1 THEN GPOHI
GOTO GPOLO
Main:
IF IN5=0 THEN GPOHI
IF IN6=0 THEN GPOHI
IF IN7=1 THEN GPOHI
GOSUB GPOLO
GOTO Main
END
'******************************************************************[ Subroutines ]
GPOHI:
GOTO Main
GPOLO:
RETURN
GOTO Main
' {$PBASIC 2.5}
statement if you want to use 2.5
Main:
GOTO GPOLO
GPOHI:
GOTO Main
GPOLO:
GOTO Main
