Tree House Control System - — Parallax Forums
kmc123kmc123 Posts: 33
edited 2012-03-08 09:22 in BASIC Stamp
Hi everyone,
I'm building my boys a Tree House and the whole thing will be controlled by a BS2. Currently my code looks at an RFID R/W module (Hidden in a tree stump) and a switch (In the tree house) and will raise or lower the stairs if a valid tag is read or the switch is pressed.
I'll be adding alarm system functionality, sun tracking for the solar panels, etc... soon, but wanted some input from you first.
Please take a look at my code and let me know if you see any ways to clean it up / speed it up (Works as is, but I know it is not the most elegant :) )
Also - I want to add a 4x4 matrix keypad but as it is I have 8 pins left and don't want to use all 8 for the keypad (I need quite a few for the items mentioned above) - Can someone point me to a schematic and sample code for using a 4x4 keypad with some kind of interface that uses fewer pins? I know I saw something on a forum (Not sure if it was this one or not) that talked about the ability to do it, but I'd need a wiring diagram and sample code...
Anyway - Here is the code - Please let me know your advice...
'   File...... TreeHouse.bs2
'   Purpose... Master Tree House Control Code
'   Author.... Kevin M. Cook
'   E-mail.... [EMAIL="kevin@cookfamily.com"]kevin@cookfamily.com[/EMAIL]
'   Updated... 01/15/2012
'   {$STAMP BS2}
'   {$PBASIC 2.5}
' -----[ Program Description ]-----------------------------------------------------------------
' This program is the heart of the Cook Boys Tree House Automation Control - It controlls the
' solar panel alignment, the lighting, the security systems, access control and staircase.
' -----[ I/O Pin Definitions ]-----------------------------------------------------------------
' PIN  0   Pins 1-7 are for future use as inputs from door / window contacts, cds cell sun
' PIN  1   tracker and tracker motors, etc...
' PIN  2
' PIN  3
' PIN  4
' PIN  5
' PIN  6
' PIN  7
RFID_TX      PIN  8    ' Connects to 28440 RFID R/W Module SIN
RFID_RX      PIN  9    ' Connects to 28440 RFID R/W Module SOUT
LCD          PIN  10   ' 27979 4x20 LCD and Piezo Speaker
MAN_SWITCH   PIN  11   ' Manual switch to raise and lower stairs from within the Tree House
DOWN_LIMIT   PIN  12   ' Limit switch that indacates stairs are at the "Down" position
UP_LIMIT     PIN  13   ' Limit switch that indacates stairs are at the "Up" position
DOWN_RELAY   PIN  14   ' Output to the "Down" motor relay
UP_RELAY     PIN  15   ' Output to the "Up" motor relay
' -----[ Constants ]---------------------------------------------------------------------------
#SELECT $STAMP
  #CASE BS2, BS2E, BS2PE
    T2400       CON     396
    T9600       CON     84
    T19K2       CON     32
  #CASE BS2SX, BS2P
    T2400       CON     1021
    T9600       CON     240
    T19K2       CON     110
#ENDSELECT
RfidBaud        CON     T9600                       ' set Baud rate to 9600 for the RFID module
LcdBaud         CON     T19K2                       ' set Baud rate to 19200 for the LCD module
LcdBkSpc        CON     $08                         ' move cursor left
LcdRt           CON     $09                         ' move cursor right
LcdLF           CON     $0A                         ' move cursor down 1 line
LcdCls          CON     $0C                         ' clear LCD (use PAUSE 5 after)
LcdCR           CON     $0D                         ' move pos 0 of next line
LcdBLon         CON     $11                         ' backlight on
LcdBLoff        CON     $12                         ' backlight off
LcdOff          CON     $15                         ' LCD off
LcdOn1          CON     $16                         ' LCD on; cursor off, blink off
LcdOn2          CON     $17                         ' LCD on; cursor off, blink on
LcdOn3          CON     $18                         ' LCD on; cursor on, blink off
LcdOn4          CON     $19                         ' LCD on; cursor on, blink on
LcdLine0        CON     $80                         ' move to line 0, column 0
LcdLine1        CON     $94                         ' move to line 1, column 0
LcdLine2        CON     $A8                         ' move to line 2, column 0
LcdLine3        CON     $BC                         ' move to line 3, column 0
'LcdCC0          CON     $F8                         ' define custom char 0
'LcdCC1          CON     $F9                         ' define custom char 1
'LcdCC2          CON     $FA                         ' define custom char 2
'LcdCC3          CON     $FB                         ' define custom char 3
'LcdCC4          CON     $FC                        ' define custom char 4
'LcdCC5          CON     $FD                        ' define custom char 5
'LcdCC6          CON     $FE                        ' define custom char 6
'LcdCC7          CON     $FF                        ' define custom char 7
Safety_Timer    CON     6000                        ' safety timer for motor protection
' -----[ Variables ]---------------------------------------------------------------------------
Idx           VAR    Byte                           ' index
User          VAR    Byte                           ' stores user number for ID purposes
Alarm_Count   VAR    Byte                           ' stores count of alarms for beep loop
Buf           VAR    Byte(12)                       ' 12-byte array for data Buffer
Stair_Timer   VAR    Word                           ' safety timer to stop motor burnout
' -----[ EEPROM Data ]-------------------------------------------------------------------------
'                       C#----  Data----------------------------------
'CC0             DATA    LcdCC0, $0E, $1F, $1C, $18, $1C, $1F, $0E, $00
'CC1             DATA    LcdCC1, $0E, $1F, $1F, $18, $1F, $1F, $0E, $00
'CC2             DATA    LcdCC2, $0E, $1F, $1F, $1F, $1F, $1F, $0E, $00
'Smiley          DATA    LcdCC3, $00, $0A, $0A, $00, $11, $0E, $06, $00
'Msg2            DATA    "IS VERY COOL!  ", 3
' -----[ Initialize ]--------------------------------------------------------------------------
HIGH LCD                                            ' setup serial output pin
PAUSE 500                                           ' allow LCD to initialize
SEROUT LCD, LcdBaud, [LcdBLon, LcdOn1, LcdCls]      ' initialize
PAUSE 500
SEROUT LCD, LcdBaud, ["Tree House", LcdCR]
SEROUT LCD, LcdBaud, ["Control System", LcdCR]
SEROUT LCD, LcdBaud, ["Version 1.0", LcdCR]
SEROUT LCD, LcdBaud, ["Ryan & Matthew ROCK!"]
PAUSE 5000
' -----[ Program Code ]------------------------------------------------------------------------
Main:
SEROUT LCD, LcdBaud, [LcdCls]
PAUSE 5
'GOSUB Check_Manual   ' Check manual switch
'GOSUB Read_Legacy    ' Look For a EM4102 Read-only tag
GOSUB Read_Tag       ' Look for a EM4x50 Read/Write Tag
GOTO Main            ' Keep looking :)
' -----[ Subroutines ]-------------------------------------------------------------------------
Check_Manual:
SEROUT LCD, LcdBaud, ["Check Manual Switch", LcdCR]
IF MAN_SWITCH = 0 THEN  ' Check To see If the manual switch is pressed - 0 = Pressed, 1 = Not
  SEROUT LCD, LcdBaud, ["Serial number: N/A", LcdCR]
  User = 0
  GOTO Authorized
ENDIF
RETURN
Read_Tag:                                     ' Look for a EM4x50 Read/Write Tag
SEROUT LCD, LcdBaud, ["Check for RW Tag", LcdCR]
SEROUT RFID_TX, RfidBaud, ["!RW", $01, 32]    ' Instruct what to read
SERIN  RFID_RX, RfidBaud, [STR Buf\5]         ' Get status byte and data bytes
IF Buf(0) = $01 THEN Good_RW_Read             ' If no errors, (A Good Read)
RETURN
Read_Legacy:                                  ' Look for a EM4102 read-only tag
SEROUT LCD, LcdBaud, ["Check for RO Tag", LcdCR]
SEROUT RFID_TX, RfidBaud, ["!RW", $0F]        ' Instruct what to read
SERIN  RFID_RX, RfidBaud, [STR Buf\12]        ' Get header and data
IF Buf(0) = $0A THEN Good_RO_Read             ' If no errors, (A Good Read)
RETURN
Good_RW_Read:
' Getting to this point means that a RW tag was read.
' Show the tag's Serial Number
SEROUT LCD, LcdBaud, ["Serial Number: ", LcdCR]
FOR Idx = 1 TO 4
  SEROUT LCD, LcdBaud, [HEX2 Buf(Idx)]
NEXT
' Look to see if the serial number of the tag that was read is an authorized tag.
IF Buf(1) = $01 AND Buf(2) = $95 AND Buf(3) = $D0 AND Buf(4) = $AC THEN
 User = 1 ' Kevin's Dog Tags
 GOTO Authorized
ENDIF
IF Buf(1) = $01 AND Buf(2) = $95 AND Buf(3) = $CA AND Buf(4) = $37 THEN
 User = 2 ' Ryan's Dog Tags
 GOTO Authorized
ENDIF
IF Buf(1) = $01 AND Buf(2) = $95 AND Buf(3) = $C9 AND Buf(4) = $5F THEN
 User = 3 ' Matthew's Dog Tags
 GOTO Authorized
ENDIF
' If this spot is hit, the tag was read, but NOT authorized.
GOSUB NOT_Authorized
GOTO Main  ' Do it all over again!
Good_RO_Read:
' Getting to this point means that a RO tag was read.
' Show the tag's Serial Number.
FOR Idx = 1 TO 10                  ' Display the data (ignore final \r byte sent by the reader)
    SEROUT LCD, LcdBaud, [Buf(Idx)]
NEXT
' 4C182B6B55 = Home Again Injectable Pet Tracking Microchip Implant Kit from Amazon
IF Buf(1) = $4C AND Buf(2) = $18 AND Buf(3) = $2B AND Buf(4) = $6B AND Buf(4) = $55 THEN
 User = 10 ' Home Again Implant Chip
 GOTO Authorized
ENDIF
NOT_Authorized:
SEROUT LCD, LcdBaud, [LcdCls, "Access DENIED!!!"]
GOSUB Alarm
RETURN
Authorized:
SEROUT LCD, LcdBaud, [LcdCls, "Access Granted for: "]
SELECT User
  CASE = 0
    SEROUT LCD, LcdBaud, ["Manual Switch", LcdCR]
  CASE = 1
    SEROUT LCD, LcdBaud, ["Kevin M. Cook", LcdCR]
  CASE = 2
    SEROUT LCD, LcdBaud, ["Ryan M. Cook", LcdCR]
  CASE = 3
    SEROUT LCD, LcdBaud, ["Matthew P. Cook", LcdCR]
  CASE = 10
    SEROUT LCD, LcdBaud, ["Home Again Chip", LcdCR]
ENDSELECT
Stair_Timer = 0
' 0 = Pressed / Closed, 1 = Not Pressed / Open
IF UP_LIMIT = 0 AND DOWN_LIMIT = 1 THEN ' Stairs ARE at the top most position.
  ' Lower Stairs Here
  SEROUT LCD, LcdBaud, ["Lowering Stairs...", LcdCR]
  DO UNTIL DOWN_LIMIT = 0
    HIGH DOWN_RELAY
    Stair_Timer = Stair_Timer + 1
    IF Stair_Timer = Safety_Timer THEN
      LOW DOWN_RELAY
      SEROUT LCD, LCDBAUD, ["Safety Overide", LcdCR]
      PAUSE 3000
      GOTO Main
    ENDIF
  LOOP
  LOW DOWN_RELAY
  SEROUT LCD, LcdBaud, ["Stairs Lowered...", LcdCR]
  PAUSE 5000
ELSEIF UP_LIMIT = 1 AND DOWN_LIMIT = 0 THEN ' Stairs ARE at the bottom most position.
  ' Raise Stairs Here
  SEROUT LCD, LcdBaud, ["Raising Stairs...", LcdCR]
  DO UNTIL UP_LIMIT = 0
    HIGH UP_RELAY
      LOW UP_RELAY
      PAUSE 3000
      GOTO Main
    ENDIF
  LOOP
  LOW UP_RELAY
  SEROUT LCD, LcdBaud, ["Stairs Raised...", LcdCR]
  PAUSE 3000
ELSEIF UP_LIMIT = 1 AND DOWN_LIMIT = 1 THEN ' Stairs are somewhere between the low and high positions.
  SEROUT LCD, LcdBaud, ["Stairs are in limbo.", LcdCR]
  GOSUB ALARM
  PAUSE 3000
ELSEIF UP_LIMIT = 0 AND DOWN_LIMIT = 0 THEN ' Error - Impossible for stairs to be in both positions, Short?
  SEROUT LCD, LcdBaud, ["Error", LcdCR]
  GOSUB Alarm
  PAUSE 3000
ENDIF
Alarm:
DO WHILE Alarm_Count < 1
  SEROUT LCD, LcdBaud, [$E6]      ' Play G
  SEROUT LCD, LcdBaud, [$E1]      ' Play D
  Alarm_Count = Alarm_Count + 1
LOOP
Alarm_Count = 0
RETURN
END
' -----[ End of File ]-------------------------------------------------------------------------
  • bsnutbsnut Posts: 521
    edited 2012-02-13 19:02
    Kevin,
    You have a cool idea to build a tree house with your children that is different from the basic tree house that I built in the late 70s.
    In order to do 4x4 matrix keypad, you will need all 8 pins that you don't want to use. Which leaves out a standard one that Parallax sells. But, their is a way to get around this problem, by multiplexing inputs for the "Up and Down Limit Switches, door / window contacts and the Manual switch to raise and lower stairs. You can do the same thing for the non analog outputs.
    You did a great and neat job with your code and think you will do good with any changes that you make in the code.
    edited 2012-02-13 19:05
    Lucky kids! Now I want one, but I don't have a big enough tree.
  • $WMc%$WMc% Posts: 1,884
    edited 2012-02-13 19:16
    kmc123
    Build it and we will help you code it!!!!!!!!!!!!
    Post some pics of the tree fort and I will send you a serial keypad and the code to use it.(really simple code)
  • kmc123kmc123 Posts: 33
    edited 2012-02-13 19:41
    Wow! Thanks Walt!!!
    I've got a bunch of pics at http://www.kevincook.net/Hobbies/Woodworking/TreeHouse/index.htm
    edited 2012-02-13 19:45
    Wow! That is one deluxe treehouse!
    edited 2012-02-13 22:34
    Kevin,
    That's what I said too, Wow. The Wow part was, from looking at your other page on the website, that you have an automated paintball gun that will protect the tree house. With a big thanks to Walt, you have a serial keypad to use with the tree house. I am wondering what will happen when someone enters the wrong combo on the keypad?
    BTW, I will be happy to help as well with code and designing a custom PCB for this project if you want.
    edited 2012-02-14 06:03
    Thanks EVERYONE!
    I sooo love this place!!! William - I am pretty sure I will use a water blaster on the turret instead of the paintball gun now :) We were trying out the paintball guns and man do they hit hard! I don't want anyone to get hurt, so I'm thinking water blaster :)
    edited 2012-02-14 17:14
    kmc123
    Saw the pics...,Great tree fort!
    I got the PM...I'll send the key pad out tomorrow.
    Have fun with it.
    Great work and effort!!!!!!!!!!:smile:
    edited 2012-02-14 18:04
    kmc123,
    Connecting a water blaster to that system that the paintball gun is connected to will diffidently get someone wet, so have fun with it:smile:
    edited 2012-02-16 02:49
    $WMc% wrote: »
    kmc123
    Have fun with it.
    Thanks Walt! I'll let you know when it arrives. Is there somewhere you can point me to for sample code or specs?
    edited 2012-02-19 13:27
    kmc123:
    I sent the key-pad and an example code to use it.
    The code is really generic, I wrote it for a "fit all application".(super simple)
    I threw in a few different resister that are handy to have around too.
    Using these resister in series with the I/O pins will help to avoid burning out an I/O pin on your stamp in the event of a coding SNAFU.
    I pride myself with the fact that I have never burned-out an I/O pin on a micro since I started playing with them in 2000'
    The other resister are for pull-ups/pull-downs and LEDs
    Please post some more PICs of your project as it progress's
    P.S. the key-pad only needs one I/O pin
  • Scott4Scott4 Posts: 45
    edited 2012-02-24 05:28
    Happend on this keypad design that I thougt was pretty nice. -Scott
    http://allaboutee.com/2011/07/15/one-ouput-keypad-circuit-design/
  • MoskogMoskog Posts: 556
    edited 2012-02-24 08:39
    Awesome project. But I didn't like those child-soliders pictures, even though they're using toy guns.
  • CatspawCatspaw Posts: 49
    edited 2012-02-24 15:04
    Well, I'll not attempt to totally understand your program. But, the first and most serious issue I saw was that you're stepping out of your subroutines. (If I'm reading everything correctly.) To me this is a cardinal sin.
    If you Gosub somewhere (IMO) you should always return to the calling statement from that sub.
    I noticed, for example, you Gosub checkmanual....and following the most simple path you then Goto authorized and from there in many places you Goto main...having never executed the return from the original gosub checkmanual.
    I would Gosub checkmanual...get a result and return, completing that thread...then gosub authorize....decide whether to authorize....etc.
    Also, I clean up my initialization by throwing it all into my first gosub and throw all that text down at the bottom of the listing. That helps show where the main program actually is.
    I think all of this can be broken down into steps/decisions easily enough. that's just my first take. of course, I've only been playing with Pbasic for a month or so.....so it's still hard for me to just read it like a romance novel.......o.k. bad analogy....i don't read those things.
    edited 2012-02-24 15:57
    Regarding the keypad you could save three pins by using a sequencer chip and one pin to clock it
    edited 2012-02-24 18:53
    Walt - I got it and have it working with the basic code you sent - THANKS SO MUCH!!!
    Is there any other code you know of to look at?
    Thanks again!!!
    $WMc% wrote: »
    kmc123:
    edited 2012-02-24 18:58
    I don't know how it is in Norway KjellO, but I grew up playing Army in forts, running around in the woods with toy guns, then BB guns. I then proudly served my country for 6 years and have no problems at all letting my boys do the same...
    edited 2012-02-24 19:02
    EXACTLY the kind of feedback I need - Thanks Catspaw!!!
    I'll look into that - I'm rewriting it for a BS2px right now - trying to get more code space...
    Perfect time for me to try your suggestions! (I know what I really need is the propeller, but that's such a leap for me right now - I want to get it going on the BS first)
    Catspaw wrote: »
    edited 2012-02-24 19:04
    Thanks skylight!
    The keypad Walt hooked me up with uses a 3 pin cable - (Ground, Power, and 1 i/o pin) - This is exactly what I needed...
    skylight wrote: »
  • BrianZBrianZ Posts: 28
    edited 2012-02-25 10:49
    Awesome tree house! Was fascinated reading about it and seeing your design. My first thoughts were "that's a ton of lumber to be hanging on so few bolts", so was relieved to see more supports added in the later pictures; though I'm not an engineer, just a "shouldabeenone". Great design though, and I bet your boys were pretty excited. What geographic area is this with all the wonderful wild rhododendron? I'm going to have to share this with my son - we built him one not quite so sophisticated when he was that age, but he's about to finish college now and we took the treehouse down while he was still in high school as it stopped being used and the trees were still growing and boards were bending. Sorry to bring this up, but have you ever considered that one day you may need to take it down? Have you ever considered adding a zip line such as http://www.backyardziplines.com/? Maybe too dangerous with a steep hill. My son and his friends loved that feature.
    Is the keypad based on the same 1-pin design used in the article posted by Scott4? I'm wondering what the BS code looks like for that.
  • doggiedocdoggiedoc Posts: 2,252
    edited 2012-02-26 03:46
    Really awesome kmc123! My boys would love something like that but we don't have enough big trees. They'd be happy with just some camo netting, but I forgot to salvage any before I ETS'd from Fort Benning. Did you pick yours up while active duty or a military surplus store?
    edited 2012-02-26 11:31
    O.K. so here's another thot.
    In the .... IF Buf(1) = $4C AND Buf(2) = $18 AND Buf(3) = $2B AND Buf(4) = $6B AND Buf(4) = $55 THEN
    User = 10 ' Home Again Implant Chip....note that you checked Buf(4) twice....right here ^.
    Secondly....I kinda ran into this before. Rather than having a long logical test on each element of the array...well....there's a better way. I just can't think of it right now. There's just something not right about doing it that way.
    Another random thot....if you're running out of variable space (I have to go check about constants in that regard) note how the commands will be grouped....some having high nibble of $0x, some with $1x, $Fx etc. You can combine a high nibble with a low nibble to create the various groups and save a little. Like if cursor = $10.....cursor + $8, or cursor + $9
    uuhh....time to study my visual basic now.
    edited 2012-02-26 17:07
    Try This
    password  VAR  Word
    MAIN:
       DO
           GOSUB KeyPad
    '       do other stuff here
       LOOP
    KeyPad:
       SERIN keypad. Baud. [password]
       IF password = "562123"THEN UnLock  '  (kmc123)on the key pad
    '   IF password <>"562123"THEN access denied     'If you have an LCD display you can send a message
    RETURN
    UnLock:
     LOW 10            'energize the release device( for the Lock)
     PAUSE 4000     'for 4 seconds (4000 milliseconds)
     HIGH 10            'return the locking device state to locked after 4 seconds
    GOTO MAIN
    'access denied:
    '   SEROUT LCD. Baud, [message]
    '   PAUSE   2000
    '  GOTO MAIN
    END
    '$WMc%
    There is no other code for this key-pad, Other than what I sent you,That I know of. Its a one of type deal.It is very easy to use.
    If you need some more help with this. Just post it here on your thread,I'll be watching.
    edited 2012-03-08 09:16
    Thanks Brian!
    It currently has 20 lag bolts holding it up and I'm not sure of the shear strength of them, but even if it was only 400 pounds that would be 8000 pounds before it would fail, and I'm not going to be close to that weight, (And I'd be willing to bet that the shear strength of those bolts is way over 400 pounds)
    It's located at our cabin in Blowing Rock, NC - the rhodos are ALL OVER the place up there!!!
    I have NOT considered taking it down later - I don't even want to go there yet :)
    I set up a really nice 500 foot zipline for the boys and I'm thinking of moving it to the Treehouse location when it's all done, but right now it goes over a small pond which is really cool, and I really don't want to think of ANOTHER project yet :)
    Here is a video of my 94 year old grandmother going down the zipline (2 years ago) :
    http://www.youtube.com/watch?v=MDhGqPUDLfM
    I hope I can be like her when I'm 94!!!
    Oh - Yes - The keypad interpreter is a 1 pin design...
    BrianZ wrote: »
    edited 2012-03-08 09:20
    I had some when I ETS'd (Fort Carson Colorado) but that was YEARS ago and I left it at a hunting camp in the FL everglades...
    I bought the nets you see in those pics from an online surplus store and the shipping was almost as much as the nets!!!
    How old are your boys?
    doggiedoc wrote: »
    Thanks Catspaw! I'm still comparing each element and I'd love to learn a better faster way - If you ever think of it, please let me know...
    Catspaw wrote: »
