Varicap Diodes
Hi there
I want to use a pin from the prop to control the voltage across a varicap diode. I need a nice big swing - say 10-2 Volts. Is there an easy way of doing this? I'm imagining some sort of PWM being used. Anyone got a clever idea/circuit?
Cheers
Richard
Cheers
Richard
Yes, it's an RX. If I go down your route I would need an 8 bit (or more) DAC (possibly serial) and ideally something that can control a higher voltage than the digital input. Does such a beast exist?
This looks useful:
http://www.analog.com/static/imported-files/data_sheets/AD5263.pdf EDIT: but way too expensive!
Cheers
Richard
{{ 12V  120Ω 100KΩ 100KΩ 100KΩ 0.1µF ┣────────────┳───────┳─────────┳─────── C for tank circuit DUTY_MODE pin ─SSM3K15CT 1µF 1µF ┌┘     Varicap }}
Duane J
The application is not part of an oscillator, it's a software controlled filter.
Regards
Richard
Not too sure what you mean Circuitsoft?
Regards
Richard
