I2C and Si570 Synthesiser
Hi there
I am starting to get to grips with I2C to program an Si570 synthesiser. I can see the Si570 device on the I2C bus and get an ack from it. However, I am having trouble reading from it. I am using Javalin's Object. I suspect I am feeding the register addresses wrongly. Any ideas? BTW I am new to this so use simple words! Thanks.
Debug o/p:
I2C Demo (v2)!
Scanning I2C Bus....
Scan Addr : %10100000, ACK
Scan Addr : %10101010, ACK
i2cScan found 2 devices!
EEPROM Present
Si570 Present
Si570 DEMO
Read Si570 Location=00007, data byte=00002
Read Si570 Location=00008, data byte=00002
Read Si570 Location=00009, data byte=00002
Read Si570 Location=00010, data byte=00002
Read Si570 Location=00011, data byte=00002
Read Si570 Location=00012, data byte=00002
Read Si570 Location=00013, data byte=00002
Read Si570 Location=00014, data byte=00002
Read Si570 Location=00015, data byte=00002
Read Si570 Location=00016, data byte=00002
Read Si570 Location=00017, data byte=00002
Read Si570 Location=00018, data byte=00002
Si570 demo done.
Debug o/p:
I2C Demo (v2)!
EEPROM Present
Si570 Present
Si570 DEMO
Si570 demo done.
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
_stack = 50
i2cSCL = 28
i2cSDA = 29
EEPROMAddr = %1010_0000
Si570Addr = %1010_1010 'AA
' EEPROM data base address - i.e 32K (assumes a 64kb eeprom installed!!)
EEPROM_Base = $8000
' debug - USE onboard pins
pcDebugRX = 31
pcDebugTX = 30
' serial baud rates
pcDebugBaud = 115200
VAR
long i2cAddress, i2cSlaveCounter
OBJ
i2cObject : "basic_i2c_driver"
'Si570Object : "Si570Object"
debug : "Debug_PC"
pub Start
' start the PC debug object
debug.startx(pcDebugRX,pcDebugTX,pcDebugBaud)
' setup i2cobject
i2cObject.Initialize(i2cSCL)
' pause 5 seconds
repeat 20
debug.putc(".")
waitcnt((clkfreq/6)+cnt)
debug.putc(13)
' i2c state
debug.strln(string("I2C Demo (v2)!"))
'demo the i2c scan
i2cScan
waitcnt(clkfreq +cnt)
repeat
' demo the EEPROM
if i2cObject.devicePresent(i2cSCL,eepromAddr) == true
debug.strln(string("EEPROM Present"))
'EEPROM_Demo
else
debug.strln(string("EEPROM Missing"))
waitcnt(clkfreq+cnt)
' demo the Si570 Oscillator
if i2cObject.devicePresent(i2cSCL,Si570addr) == true
debug.strln(string("Si570 Present"))
Si570_Demo
else
debug.strln(string("Si570 Missing"))
PRI EEPROM_Demo | eepromData, eepromLocation, ackbit
' demo the i2c Serial EEPROM (Microchip's 24LC512 (64kb))
debug.strln(string("EEPROM DEMO"))
' ***** EEPROM read/Write example *****
eepromLocation := EEPROM_Base
eepromData := 0
repeat 5
' write long
eepromData += 100
i2cObject.WriteLong(i2cSCL, EEPROMAddr, eepromLocation, eepromData)
' read long
eepromData :=0
eepromData := i2cObject.ReadLong(i2cSCL, EEPROMAddr, eepromLocation)
' debug
debug.str(string("Read Location="))
debug.decx(eepromLocation,5)
debug.str(string(", data="))
debug.decx(eepromData,5)
debug.putc(13)
' next
eepromLocation +=4
' slowit
waitcnt(clkfreq/20 + cnt)
' done
debug.strln(string("EEPROM demo done."))
PRI Si570_Demo | Si570Data, Si570Location, ackbit
' demo the i2c Serial Si570 (Microchip's 24LC512 (64kb))
debug.strln(string("Si570 DEMO"))
' ***** Si570 read/Write example *****
Si570Location := 7
Si570Data := 0
repeat 12
Si570Data :=0
Si570Data := i2cObject.ReadByte(i2cSCL, Si570Addr, Si570Location)
' debug
debug.str(string("Read Si570 Location="))
debug.decx(Si570Location,5)
debug.str(string(", data byte="))
debug.decx(Si570Data,5)
debug.putc(13)
' next
Si570Location +=1
' slowit
waitcnt(clkfreq/10 + cnt)
' done
debug.strln(string("Si570 demo done."))
Repeat 'Wait here
PRI i2cScan | value, ackbit
' Scan the I2C Bus and debug the LCD
debug.strln(string("Scanning I2C Bus...."))
' initialize variables
i2cSlaveCounter := 0
' i2c Scan - scans all the address's on the bus
' sends the address byte and listens for the device to ACK (hold the SDA low)
repeat i2cAddress from 0 to 127
value := i2cAddress << 1 | 0
ackbit := i2cObject.devicePresent(i2cSCL,value)
if ackbit==false
'debug.str(string("NAK"))
else
' show the scan
debug.str(string("Scan Addr : %"))
debug.bin(value,8)
debug.str(string(", ACK"))
' the device has set the ACK bit
i2cSlaveCounter ++
waitcnt(clkfreq/20+cnt)
debug.putc(13)
' slow the scan so we can read it.
waitcnt(clkfreq/40 + cnt)
' update the counter
debug.str(string("i2cScan found "))
debug.dec(i2cSlaveCounter)
debug.strln(string(" devices!"))
Regards
Richard
G3CWI
BTW Have you seen Phils work on demodulation of RF ? He has done some great work with the prop in this arena.
I am working on "relative" frequency addressing of the chip. This seems to be pretty good for the 3500ppm range and also makes the whole control of the chip really easy (once the initial maths are done). I have settled on 50Hz steps for my application, this just requires a simple add. The hard way involves 38 bit maths plus range selection for N1 and HS_DIV which would be too much like hard work!
I have looked at Phil's work although I remain to be convinced that the Propellor is an appropriate platform for serious RF DSP (hard hat on). For much the same reasons, I am going down the AD9851/Si570 route for RF generation. I know the Propellor can do it but... I want to play to the strengths of the Prop platform.
Cheers
Richard
G3CWI
Ray
VK2ZTZ
