Initializing state change logic
Hello all,
The following code is used to report the state of an Active Low switch input on Pin 0. The only circuit is the switch and two resistors.
I'm having a problem getting this code to show the initial state of the switch if it is CLOSED. When I RUN the code, and the switch is OPEN, it displays correctly. If the switch is CLOSED when the code is RUN it doesn't show anything. Only after I OPEN the switch does it then show the state of the switch, and works every time thereafter...until I RUN the code again with the switch CLOSED.
This code represents just a snippet of a much bigger project that I'm working cleaning up. The same logic is used to check 16 inputs via a 74HC165 pair.
I've read about the Finite State Machine code on Tracy Allen's website at http://www.emesystems.com/BS2fsm.htm but I do not have enough variable space left for it. I would need 5 WORDs of space (5bits x 16 inputs) and I don't have it.
I tried adding the following lines (individually) before the Main label, but none helped. They only changed which state of the switch did or didn't work at initial code RUN.
Saved = 0
Saved = 1
Flag = 0
Flag = 1
Is there something I can do to have the initial state of the switch reported before I activate the switch?
falcon
switch PIN 0
temp VAR Bit
Saved VAR Bit
Flag VAR Bit
main:
temp = switch 'load temp with current door state
IF Saved = temp THEN 'if door saved = door current = no change set To false
Flag = 0 'no change ensure flag is cleared
ELSE
Flag = 1 'door changed states , set flag to true
Saved = temp 'save current state for compare next time through
ENDIF
IF Flag = 1 THEN
IF Saved = 1 THEN
DEBUG "NOT CLOSED"
ELSE
DEBUG "CLOSED "
ENDIF
Flag = 0
ENDIF
GOTO main
Saved = 0
Saved = 1
Flag = 0
Flag = 1
falcon
switch pin 0 previous var bit current var bit previous = switch ' initialize to current switch setting current = previous if current = 0 debug "initially open",cr else debug "initially closed",cr endif do previous = current current = switch if previous <> current then if current = 0 then debug "switch opened",cr else debug "switch closed",cr endif endif loopThe state machine on my web site is implementing what is called a "vertical counter" in order to scan an x-y keypad and to debounce 16 keys at once. If you don't have to debounce, and you don't need to scan a keyboard, the program only takes three state variables. As Mike pointed out, one is for the present state of the keys, one is for the past state, and I have a third one that flags changes of state, which is then decoded to decide what actions to take. The past-state variable has to be unique, but the current and changes variables can be aliased and used for multiple purposes.
I don't know how to answer your specific question about initialization. Explain more what you want to do. The routines detect changes in state of the keys, so it is not unusual to initialize the past-state variable to the actual current state of the switches. Then it detects subsequent changes. If the program needs to take immediate action when the program starts if a switch happens to be in its active state, then the past-state variable would have to be initialized to the not-active state.
So your code is starting out with "Saved" set to Closed. And if the door is closed, then the software sees no change!
I would "prime the pump" by reading the switch and loading Saved with the inverse of the switch value. Something like before the Main loop.
HTH,
--Rich
That code worked. It provided the initial state of the switch whether OPEN or CLOSED, which was what I was missing.
As I said, this was part of a much bigger program. I had to minimize it to the essentials to eliminate any other code causing the problem so it probably looks cluncky. I actually use a SERIN to receive 2 BYTES instead of a switch and the first line of code is really temp = Current1.BIT1. I substituted the switch to simplify it.
I don't know where that second reply went, but I didn't understand it anyway.
Tracy,
I didn't realize that code was to read the x-y keypad. I think you hit the nail on the head re: "...initialize the past-state variable to the actual current state of the switches". I'm going to work with your code too and see what I can come up with.
RiJoRi,
Your suggestion certainly did work (with the pump priming). I'm going to try that first since it is based on my existing code.
Thank you all for your help. One good reply would have been great but these three gives me more to study and try to understand different approaches to solving the same problem. That's priceless.
Not that I might not be back soon with another question...
falcon
