Thermal info on P8X32A - how warm does a propeller chip get?
Wossname
My Propeller has been powered up and running for an hour or so and I just noticed that it feels slightly warm to the touch. Is that normal? Nothing else on the (perf) board is warm (apart from the voltage regulators but that's ok since they are running off 12v input).
All voltages are OK into the chip, only one cog is running and it's driving 4 LEDs through 470R resistors off 4 separate pins in a slow loop (1/8 second per loop).
I've had a look in the datasheet for the Prop chip and it seems only to include environmental temperature and how it affects the chip. I've never noticed the chip heating up before and I've made several propeller proto-boards before now.
I'd like to know how warm does this chip normally get just under it's own steam (so to speak) during normal operation.
I'd estimate the chip is probably 5 or 6 degrees C warmer than my cold hands (it's snowing outside!
I'm not overly concerned about this but I'm curious nevertheless.
So ideally you'd pull an unused input pin low (or high??) or tie it directly to one of the supply plains? Or set them as outputs even.
Hmm.
With the unused pins as inputs, factors such as board cleanliness and humidity will have an unpredictable effect, which isn't desirable.
You might want to make sure you have all Vdd and Gnd pins connected and nothing is shorted out somewhere.
The datasheet says 1W max power dissapation. If the prop were thermally isolated, it could conceivable get a little hot..
The Prop itself draw drawas about 10mA for one cog at 3.3V. So, that's about 33 mW.
The outputs have about 30 Ohm self-resistance and can output up to 300mA. That would give about 2.7W.
That is actually enough to be noticeable, now that I think about it...
See:
http://forums.parallax.com/showthread.php?131622-Resistor-values-for-64-GreyScale-VGA-output-from-the-Propeller&p=999486&viewfull=1#post999486
http://forums.parallax.com/showthread.php?135969-LED-Current-Draw-and-Resistor-Selection
27 ohm internal resistance, 470R so V=IR, I=V/R = 1.1/497 = roughly 2mA
W=IV = about 2mW dissipated in the chip per pin driving a led.
x4 leds is about 8-9mW. Not enough to get warm I'd guess. And less than the current consumption of the chip itself 33mW as calculated by Rayman above.
Is this a homebrew design or one of the pre-made boards?
If it is homebrew, are there bypass caps etc?
Most LEDs are full brightness at 20 mA. Four would be 80 mA.
Ooops, never mind, I see the 470 Ohms in the top post now...
