Graphics and the Propeller. — Parallax Forums
SONIC the HedgehogSONIC the Hedgehog Posts: 321
edited 2012-02-06 18:26 in Propeller 1
So I've had my propeller for less than a month, but I didn't take me very long to figure out it had the capability for graphics, but have a few questions.
1) Assembly is faster than spin, so I would assume that it would be more efficient for displaying graphics?
2) when moving data to the display buffer to be outputted, should all the data be moved and then the screen refreshed, or should the screen be refreshed every so bytes of data?
    edited 2012-02-06 08:08
    Assembly is more efficient at display graphics, however SPIN is more than fast enough to manipulate many kinds of graphics being displayed with PASM.
    On the Prop, there are basically two ways to do graphics. One is standard bitmap graphics. A region of the HUB memory is used as the display buffer, which is scanned and displayed by a COG. One or more additional COGS contain PASM routines for graphics drawing. Line, point, shape, etc... A SPIN program controls the whole thing, essentially issuing commands to the PASM COGS doing the heavy lifting.
    Bitmap graphics can be single, partial or double buffered. (triple buffers are possible too, but not realistic on the Prop, due to memory constraints) A single buffer bitmap must either be drawn entirely during the TV / Display blanking time, or flicker will be seen by the user. An alternative is to draw very slowly, or only draw parts of the display, to avoid this.
    A partial buffer bitmap display spreads the screen drawing out over a number of video frames, using a smaller buffer. An entire screen is drawn over one or more video frames. The trade-off here is complexity and overall perception of display speed, along with image integrity. (tearing can be seen on some images that are animated and that cross a partial buffer boundary)
    Double buffer bitmap graphics are probably the easiest on the Prop, where an entire screen is drawn, then shown all at once while the next draw occurs in an off screen buffer. Memory cost is high for this one, often consuming most of the HUB memory.
    Bit-map graphics have been built to do two color, 4 color, 16 color, 8 bit or "full" color.
    A variation on the bitmap graphics is "character" type graphics, where the screen tiles are used to build a text screen, or simple graphics representation of things. A small region of HUB memory holds tile or character data, which is drawn to the screen dynamically, based on the tile list, which is a list of all the screen positions and which tile data is to be drawn in that position. The Parallax graphics driver does this to form bitmap displays, by stacking unique tiles to fill the screen. Other drivers, intended for text type displays, allocate less RAM, and only display 256 tiles.
    From there, various dynamic drawing schemes are possible.
    The basic method is the scan line driver. One COG builds the screen display, one scan line at a time. Those scan lines are built by other COGS in real time, as the display is being made. Sprite data exists in the HUB, and is drawn onto the screen based on a sprite list of positions, data values, image addresses. Using 4-5 COGS, a prop can generate sophisticated screen displays consisting of hundreds of sprites, with tens of sprites per line generally possible. Fewer COGS = fewer sprites per line.
    In general, you want to use PASM to setup the graphics engine you choose to use. For a bitmap display, two COGS can do a lot! One draws the screen to the TV, the other provides graphics assist to SPIN by doing things quickly, directed by the SPIN program, which basically runs the game.
    For the Sprite display / dynamic display method, it's generally the same, but the PASM requirements rise considerably as those drivers are difficult to write. The good news is we've got lots of them to choose from, most of which can be used for other projects besides the game they were written for.
    SPIN runs game logic, collects user input, builds list and can calculate (some) collisions plenty fast enough for games.
    Sound is about the same as video. One or more COGS are dedicated to produce sound, with SPIN triggering and defining the sounds.
    Graphics are all about time. The TV / VGA beam moves quickly, and needs the display data to be there at all times. The higher resolution the display is, the fewer things a COG can do during that time, meaning the cost for higher resolution, or more sprites or more colors is always more COGS in addition to more RAM.
    Sometimes it's good to express data in terms of number of bytes per refresh, though it more normally boils down to memory used and number of objects drawn. The core thing is time, with the rest being determined by the limits of the graphics system you are using.
    edited 2012-02-06 08:11
    (Edit: I see Doug has taken the time to provide some in-depth answers. Excellent!)
    I'd get a firm grasp on Spin before jumping into Assembly. (Something I'm STILL working on.) You can do this while working with projects you enjoy doing. (Propeller gaming) -- I'd start with some of the links I've already given you. I've opened a discussion around that 1-byte,per pixel driver (mashed_potatoes_TV.spin): http://www.gadgetgangster.com/forums/viewtopic.php?f=4&t=68 It was used recently in: Savage Wheels: http://www.gadgetgangster.com/forums/viewtopic.php?f=4&t=64 -- It's an excellent beginner driver.
    OBC
  • SONIC the HedgehogSONIC the Hedgehog Posts: 321
    edited 2012-02-06 08:39
    Thanks so much!!!! One of these days I'm going to be as awesome and knowledgeable as you guys!
    edited 2012-02-06 09:57
    I'm going to stick with spin until I do get a grasp of it, but I just just got an idea. Would effencieny of my display be maximized if I used multiple cogs for moving the pixel data to the buffer, and then having another cog refresh the screen?
  • VIRANDVIRAND Posts: 656
    edited 2012-02-06 12:07
    To me it seems efficient enough to use double buffering since it doesn't take a noticeable amount of time to copy the whole drawing buffer
    onto the displaying buffer after each significant change to the screen bitmap. The common example is the GRAPHICS demo,
    the one with all the moving shapes and a huge counting digit. Its a good starting point.
  • trodosstrodoss Posts: 577
    edited 2012-02-06 12:29
    @Sonic,
    As Potatohead mentioned it is possible to have scan lines generated in separate cogs, generating video via alternating scanlines. There was a tutorial of that here:
    http://forums.parallaxinc.com/forums/default.aspx?f=33&m=288732
    To get adequate performance on a multi-cog driver, PASM is almost a requirement, and, as Potatohead mentioned, comes with added complexity.
    edited 2012-02-06 14:08
    edited 2012-02-06 15:27
    Thanks a bunch, I'm checking out all these links in different tabs as I type. PASM shouldn't be as complicated as it sounds as I have worked with assembly before. Is there any particular assembly that PASM is similar too?
    edited 2012-02-06 15:42
    PASM is the only assembly language I've ever learned so I don't know how it compares to other chips' assembly languages.
    When I was trying to learn PASM, I found JonnyMac's SpinZone articles really helpful.
    edited 2012-02-06 15:48
    Thanks for the help. Just read the forum about the driver. It provides alot of insight about the difficultly and how much it really takes to get a game on a platform, so I will do alot of reading over the entire course I write my program, and I will be sure to update progress. Thanks a bunch for the help.
    edited 2012-02-06 17:45
    @Sonic,
    If you are wanting to look at more graphics drivers you might look here. There are some more (and less) complicated than the one previously mentioned. I don't think making a game on the Propeller is any more difficult than any other platform. You might want to try to build something with one of these other drivers first, and then build your own "engine." I have no doubt that you can master PASM though, if you go that route. Definately though look at the Spin Zone article that Duane Degan mentioned. It is a nice introduction to PASM.
    edited 2012-02-06 17:50
    Thanks so much for the help I really appreciate it. I might just get my spin and sink down for a month two, and resurface with some new brekthroughs! Thanks a nubch for the help, and what I meant was how hard it is to make a game in general.:lol:
    edited 2012-02-06 18:13
    At a fundamental level, all of them. Going back to the 4004 and 8080 1970's vintage chips, as there were more transistors per chip, the chips ended up with more instructions. Going from the 8080 to the Z80, there were a huge number of extra instructions, but the interesting thing is that most of them didn't really add much value. There was sort of a backlash with the rise of RISC (reduced instructions) which had the benefit of making chips easier to learn.
    I find the propeller has much in common with chips like the 8080 - instructions you use over and over like jump, call, logical and, logical or, bitshifts and input/output and moving data. Learn just those and you are almost there.
    For me, the biggest change from the old-skool chips was that there are no registers. Instead of moving data into register A, then some more data into register B, then adding them, then moving the answer back out into memory, in the propeller, every location in memory is also a register. It means you can do things with less instructions.
    The two things that get me all the time with PASM i) watch out for leaving out the #, and ii) there is a big difference in the way you handle numbers more than 511.
    I love the unbridled enthusiasm - it is infectious!
  • CircuitsoftCircuitsoft Posts: 1,166
    edited 2012-02-06 18:18
    I actually notice quite a bit of similarity to ARM, though the prop doesn't have ARM's barrel-shifter, so you can't bit-shift data in the instruction. ARM is similar in that there's a limit to the size of an immediate number, though I think the limit is higher on the prop than on ARM; haven't done ARM assembly in quite a while. The fact that any instruction can be conditional is also sort of like ARM. The fact that any instruction can be set to produce any result or not, however, is quite unique.
    I actually got a lot out of reading the instruction coding table for the prop. You may too.
    @Dr_Acula, thanks!!!!! I think the one thng I would take time to get used to is the lack of registers, but I won't miss taking three instructions to move I single piece of data, then ten more to actually use it. My enthusiasm is a virus that will get inside your mind and cause you to spread even more enthusiasm and continue to learn more and more!
    @circuitsoft actually that is a great Idea. You sir are indeed quite the genius. But it's time for me to get my spin on, off to the data sheet! Thanks a bunch!
    I really appreciate all the help given!
