Raise Pin Voltage to headphones With Propeller
Hello All! I'm experimenting with propeller and playing wavs through a 3.5mm headphone jack(to headphones). I have the audio playing beautifully, but there is one problem the
audio is really quiet. I believe I need more than the propeller's usual 3.3V in order to get a volume acceptable for practical use. How can raise the voltage output to the headphone jack(pin 10 and 11 go to headphone jack). All help and suggestions welcome and appreciated.
Tyler
Tyler
It may also help to lower the impedance of your lowpass filter, if you can. What values of R and C are you using?
Are you using an existing object for this project or did you write your own? I had a problem with an existing object that seriously reduced the output. I then tried JonnyMacs sound object and the volume was much louder.
Bruce
Try JonnyMac's code at this location and see if it helps, http://forums.parallax.com/showthread.php?128129-cylon-eye-sound
Oh Bruce...
Thanks for the link to JonnyMacs piece.
That's a nice bit of work he did there.
Funny how things work out some times...
I was just starting to play with the wav objects in the OEX.
Somehow I had missed his.
Richard
Cheers,
Tyler
I don't actually believe it is in the OBEX, but it could be.
You can use powered PC speakers. Or, radioshack sells a little DIP8 audio amp...
Oooooppppsss. I had forgotten that my sound experiments included a LM4808M.
You could be lazy and use an OPA2677 as a unity-gain buffer straight from the output pin and have the filtering be done by the speaker itself, or have a filter of 1K/8.1nF and use a cheap amplifier (TDA1517P is nice and can be found in many powered computer speakers) to drive your speakers.
