BS2 to control OWI arm trainer
I've seen other similar posts but I can't seem to put my finger on exactly what I need to do to control this OWI robotic arm (simple DC with my BS2.
I've successfully driven one of the motors (the gripper) using a transistor and the 9V power from triggering a pin on the BS2, but I can't seem to get the same idea to work leveraging the 4 D Battery power in the arm itself. I've seen posts regarding using transistors, H-bridges, relays, etc... but would like to know the simplest and least costly of these options.
I already have the 2N2222 transistors and prefer to use them if possible (need some confirmation on how to wire them so I can leverage the Owi arm power, not the BS2 9V. If I need to buy an H-bridge, any suggestions on which one?
Thanks in advance!
Kevin
Thanks in advance!
Kevin
Anyway, you ought to be able to use relays in their place, or in parallel, it's up to you.
I don't know the current ratings of the OWI motors, but, depending, you might be able to get by with reed relays.
More details, Kev.
First, buy this right now before somebody else (or me) does: http://www.ebay.com/itm/OWI-Robotic-Arm-Edge-w-USB-Kit-/190634990957?pt=LH_DefaultDomain_0&hash=item2c62bb1d6d
$37 for the OWI edge robot arm AND USB computer interface. I have this and it works great. It will be gone within an hour, pounce right now or all is lost !
http://forums.parallax.com/showthread.php?106382-4-State-Relay-H-Bridge
