Gnu Emacs, a useful IDE tool, available now (and for over 30 years)
I just came across this forum yesterday, and I noticed that folks are waiting for a GUI IDE. I also saw another post titled "What editors are being used?".
I thought I'd take a moment to point out Emacs to folks who aren't familiar with it. Emacs was the original piece of the Gnu project (as in the Gnu C Compiler that propgcc is based on). Emacs was invented by Richard Stallman, who basically does *all* his work in it - it supports code editing, compiling, debugging, and a bunch more stuff.
Personally, I love Emacs, and it's been my goto text editor since 1977. If an Eclipse GUI for propgcc came out tomorrow, I'd say "that's nice", and keep using Emacs. I've used pretty much every IDE there is. When a particular IDE provides integrated features I can't live without, I still tend to do the bulk of my editing (and especially all the complicated editing) in Emacs (the macro facility is really quite useful) and just use the IDE for its unique features.
The most important features of an IDE for me are: (1) Electric editing (i.e. highlighting, indentation, paren/quote/brace matching, etc.), (2) One-touch compilation, (3) Quickly navigating from errors back to the source, (4) Symbol look up, and (5) Debugger integration. Emacs supports all of these, perhaps in a bit rougher form than "modern" IDEs, but still quite usable.
Emacs is extensive (it supports practically every language, even spin) - there's too much to even try to cover here, but there's tons of stuff on the web. Two good places to start are:
http://www.linuxjournal.com/article/5765?page=0,0
http://deep.syminet.com/emacside.html
A few details about using emacs with propgcc:
The fact that propgcc is a command line compiler makes it ideal to use with Emacs. Yes, you have to fiddle with the makefiles a bit or else write .bat command files to get automatic compiling, but IMHO (A) it's not that difficult and (B) every programmer should probably know about (or at least want to learn about) make systems.
Setting up Emacs to use propgcc is trivial. If your development system is Windows like mine is, just google for "gnu emacs windows download", then download and unzip the latest version and run it's "addpm" program to get it "installed" in Windows. There are prepackaged version for Mac and Linux too, just search for them.
I put the following into a file named "m.bat" in the same directory with my code:
****** Start of m.bat ******
@echo off
set path=c:\users\ted\propgcc\propgcc-0.2.2\bin;%PATH%
echo Running make all
make all
if errorlevel 1 goto end
echo Running make run (download to the prop) in a separate window
set keepWin=
if "%1%" == "" goto noarg
set keepWin=cmd /k
:noarg
start %keepWin% make run
:end
****** End of m.bat ******
Of course, I also had to set up a makefile. The demo programs all have makefiles, so I just copy them and customize as needed. I could have just thrown compilation commands into the batch file instead of running make.
To get one-touch compiling, I threw the following line into my .emacs file:
(global-set-key [f9] 'compile)
To compile, I just hit the <F9> key, then hit <enter> (the first time I run it, I change the default command "make -k" to my batch file "m" before hitting <enter>). The compile output appears in a window, and I can click on errors that come up to go right to the line with the error.
As you can see from the above batch file, if the compilation ran without error, the m.bat brings up a separate window to download the program to the prop and run it. I put the commands for downloading/running in the makefile, but again, you could just include the propeller-load command in the batch file. Here's my makefile's "run" rule:
BOARDFLAG = -b spinstamp
RUNFLAGS = -r -t19200 # Load ram and run, then open terminal
# how to run
run: $(NAME).elf
$(LOADER) $(BOARDFLAG) $(NAME).elf $(RUNFLAGS)
To get symbol lookup and symbol completion, I threw the following into my makefile:
TAGS: *.c *.h
etags $^
and I added TAGS to the default "all" rule, so I get new symbols with each compilation:
# default build target
all: $(NAME).elf TAGS
Of course, you have to know the proper Emacs commands to use symbol search and completion.
All this covers IDE features 1-4. Feature 5, debugging, is also supported in Emacs via GDB. If/when propgcc supports GDB, hopefully this will just work too!
This is all FYI, in case anybody is interested. I did a search on "Emacs" across all the forums, and it only generated 42 hits. This is comparitively uncommon (search for words like "blink" and the search will stop at 500). So with apologies to those folks who already know and use Emacs (or the vi, etc., users who don't want to), I figured Emacs could use a proper introduction to the forums.
- Ted
@echo off
make all
set keepWin=
set keepWin=cmd /k
:noarg
:end
# how to run
run: $(NAME).elf
TAGS: *.c *.h
etags $^
- Ted
I'm sure it was the inspiration for the original game of Zork - "You are in a maze of twisty little passages, all alike ..."
Ross.
Welcome to these forums!
Thanks for contributing this information for the widely used EMACS code tools.
--Steve
(sorry couldn't resist)
As it happens there is a Spin mode for vi/vim which looks very good. Sorry I don't have a link for it to hand but it was posted to the Propeller forum.
The cartoon strip was very funny though.
The old vi program is horrible; vim is much better.
heater, there is a spin syntax highlighter for emacs too.
You run 'mkid' (initially, and whenever you feel you need to) in the command line, which creates an ID file (valid for that directory and all its subdirectories. The way it works is that when referencing a symbol the tool will walk 'up' until it finds the first ID file, so you can distribute them as you like). Then I have id-utils.el loaded from my site-lisp (or could have used my $HOME/.emacs or $HOME/.xemacs directories). From then on Emacs or XEmacs will know about symbols and it's easy to hover over e.g. a function name and find all references to it. There's not need for any 'make tags' or anything in the Makefile, and it'll know about symbols in other directories too, as you wish (you decide by running 'mkid' up or down subdirectories to the appropriate level). So it's easy to work with setups where e.g. library code is elsewhere.
-Tor
