Leadscrew-Driven Joints in Arm
Crude but effective! Fast forward to the 1-minute mark to avoid silly cartoon: http://www.youtube.com/watch?v=GdTX1fYzmYM
These leadscrew joints are bound to be a lot more accurate and durable than your average hobby servo joint on a homebrew robot arm. Probably stepper motors used here.
Daddy like. Could mod regular servos to do this. Make a continuous rotation servo out of it to drive the leadscrew, then mount the pot externally at the joint to measure the angle. Hmmm...
Duane! Martin_H!
Duane! Martin_H!
To think, earlier today I actually wondered if I should start adding background music to my YouTube videos. Now I know the aswer will be NEVER. You could have at least warned us about the awful music. (Not that the music itself was so bad, it just was way out of place in a robot arm demo.)
I think using an external pot with a continuous rotation servo has been patented by the guy at Servo City as well as adding a gear instead of a servo horn to a servo. Oh, no! I hope he doesn't see the S9254 servo thread. I show the gear I attached to the servo! Okay, enough about bad patents.
The threaded rod looks like it's practically in the center of each arm segment. The arm will likely have trouble reaching "into" things. I don't see one in my near future.
Isn't this too similar to a worm drive for your liking erco?
and it uses servos with custom sensors.
I'll be happy just stacking wooden cubes and stacking my wooden robots for ~$30 total, including the uC!
http://www.bot-thoughts.com/2010/01/unicorn-1-arm.html
http://www.scribd.com/Lima-1/d/3231860-Unicorn1-Robot-Articles-in-Radio-Electronics-
I wanted to build one back then (the arm part) but didn't really have the means.
Gotta love it!
Just finished a plastic mockup of one of the links today. Not terribly happy with the result, but plastic is cheap! :-)
Amanda
