Need help selecting Windows computer for Eddie Robot
W9GFO
I'm trying to find a small, netbook sized Win7 computer that will go on an Eddie Robot.
Requirements:
Win7
Dual VGA output or VGA + HDMI or Dual HDMI
WiFi
Small
Good if it can run off 12VDC
I haven't come across a netbook with dual VGA.
An embedded computer might be better but I don't know where to look for them.
A small tower would also work but I want to avoid using an inverter.
Requirements:
Win7
WiFi
Small
http://www.mini-itx.com/
http://www.mini-box.com/site/index.html
http://www.mini-itx.com/store/default.asp?c=0¤cy=2
-dan
here's one that is even smaller..
http://www.via.com.tw/en/initiatives/spearhead/pico-itx/
Do you need the dual video for a second monitor or to duplicate what is on the screen? If you just need an extra screen you may want to look at some of the USB video cards to add an extra display. It may be an option since I don't recall seeing any notebook/laptop systems with dual video ports.
Robert
Also, I am wondering if a SSD is a necessity since the robot will be in constant motion.
http://www.mini-itx.com/store/?c=65#AT5IONT-I
Also, here are a bunch of "vechicle" powersupplies that should work.
http://www.mini-itx.com/store/?c=10#int
As for the SSD, I would get one, however a 2.5 inch HDD in a proper enclosure would probably be fine.
EDIT: Oh, and I think that motherboard is also solid-state, which is a big plus. Most netbooks aren't, they usually have fans in them I think.
I have one of these in an HP Microserver and it works nicely.
Link to PowerColor 5450 at NewEgg
I got mine on sale for $24 and free shipping
I also agree with the idea of SSD and a fan-less motherboard, just from a reliability standpoint.
If you are planning on running RDS4 do not try anything any less than the minimum requirements. I went the minimum, Panasonic CF-74, Intel Core 2 Duo at 2 GHz and 4 Gig of RAM. I am also using a port replicator for the CF-74 to get more USB ports. That setup is barely adequate.
The Kinect needs to be plugged into the highest speed USB port (it will not work on the replicator ports) and the Xbox remote unit needs full power USB to run.
The laptop battery is good for an hour or two on Eddie. If needed, I have an adaptor to charge the laptop from Eddies batteries.
Rick Brooks
If there's a lot of vibration it might be wise - alternatively anti-vibration mounts could help protect the machine.
