P0 output
Hi.
I have question.
I did below code.
I checked P0 by oscilloscope.
There are low pulse(100nsec width) evry by 26usec.
Why low pulse?
And why every 26usec?
I have question.
I did below code.
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
PUB
cognew(@entry,0)
DAT
org 0
entry mov outa #0
mov dira,#1
mov outa,#1
Why low pulse?
I changed
org 0 entry mov outa #0 mov dira,#1 mov outa,#1 b nop jmp bIt output pulse(high=150nsec Low=100nsec).And why it become to low?
org 0 entry mov outa #0 mov dira,#1 mov outa,#1 b nop jmp [COLOR="#B22222"]#b[/COLOR]What your code is doing is jumping to the address in the memory location labelled 'b', not jumping to that literal address value. Since b is a nop, that memory location probably contains zero, which means your code is jumping back to 'entry'.
I understand it.
