CogExplorer — Parallax Forums
CogExplorer
ReinhardReinhard Posts: 489
edited 2012-01-20 00:21 in Propeller 1
Hi,
just for fun I write this CogExplorer.
The propeller part of course is written with propgcc,
the pc part is written in C#.
I know this is not a pure issue for alpha test forum and hope nobody is angry about.
I do this because get more skill in C# also.
If anyone not a window user or have no .NET Framework ignore this or read the CogExplorer.doc for info. (contents sreenshots)
Thanks for tolerance:blank:
Reinhard
  • jazzedjazzed Posts: 11,803
    edited 2012-01-06 16:58
    People interface C# and other languages with propeller all the time. I consider this a perfectly valid exercise.
    Hover over COG or system register and display values in a tooltip would be "way cool." :)
    Thanks.
    --Steve
    Reinhard wrote: »
    Hi,
    Reinhard
  • ReinhardReinhard Posts: 489
    edited 2012-01-07 06:59
    Steve, Thank you for response,
    I do it with tooltips , because to avoid to many info on screen.
    With this way I can compress the info.
    Reinhard
  • Don MDon M Posts: 1,654
    edited 2012-01-19 15:39
    Reinhard- I was looking at your program. How do you install CogView.elf on the Propeller?
    edited 2012-01-19 16:29
    propeller-load -p7 -e -t CogView.elf ... replace 7 with your number of com - port...
    in the attached zip file you find mk.bat
    this compile, link and install it.
    for simple project I do not use make.
    best regards
    Reinhard
    edited 2012-01-19 17:20
    Sorry for my ignorance here but I guess I am totally lost with this. Evidently this isn't just some sort of spin program? Does it require some sort of C program?
    edited 2012-01-19 17:44
    This is over my head at this point. Need to make time some other day to get my head around all this. Sorry for the interruption.
    You are welcome
    it is right this is a small propgcc demo and for use it, you have to set the path
    or you start the PropGCC batch and work in the appeared dos box.
    Reinhard
    edit: if you not planned to modify something, you need only the propeller-load.exe in the bin folder
    for install the binary.
    974 x 597 - 90K
