Anybody have problem with MCP3202 with Vdd=+5V ?
Asking because I'm getting ready to make another version of our Merlin board with an ADC instead of motor driver and have this question about the MCP3202...
Anyway, I'd like to power the MCP3202 with +5V, but the datasheet shows the digital input threshold as 0.7*Vdd minimum, which is 3.5 V.
I think I remember other chips rated for 0.7*Vdd not working reliably...
But, I think I see a lot of people here using it without problem...
Has anybody had problems at 5V and had to switch to 3.3V to make it work?
Still, I really don't like using things outside of their specified range...
But, I don't want to sacrifice the increased functionality just to be picky about specifications...
Maybe it's only 1 in 1000 chips that would have a problem.
BTW: I've noticed that a lot of chips I look at have the 0.7*Vdd specification. Must be something fundamental in their I/O...
Makes me wonder if we'd be better off running the Prop at 3.5 V...
Would using a MCP3208 instead of a MCP3202 cost much more? I find I can always use more ADC channels on my robots. Two just don't seem like they would be enough.
I was thinking maybe 1 for an IR proxy sensor was enough...
There are lots of sensors that give an analog output. The accelerometer in a Wii mote has three analog outputs (I keep intending on reusing some of these).
If you make your own force sensor from anti-static foam, an ADC could read the analog value from it. Those little thumb sized joysticks use two pots which give analog outputs. And you can never have too many knobs (pots read by ADC).
It seems like a lot of homemade sensors are analog.
I don't know if there is a big difference in price when you buy the chips in bulk, but I noticed the other day, the price difference for a 2-channel ADC chip verses an 8-channel ADC chip from Parallax's store, wasn't very much.
It's still rated at 0.7*Vdd, but hopefully it's just as forgiving as MCP3202...
No issue using the 3201 version. Used 5V because allows max sample rate. Only need to remember series 4.7k series resistor on data out line into prop.
FF
